Transmission Flush after Cooler Upgrade - Diesel Forum - TheDieselStop.com
post #1 of 5 (permalink) Old 08-24-2018, 07:07 AM Thread Starter
Big Horn's Avatar
I have read the flush procedure by Mark and Smokey. And since I will be doing the Mishimoto 6.0 Cooler upgrade and blowing out hard lines my question is how many quarts of fluid would I need as I would be starting with a clean and empty— but larger capacity cooler- or would it be approximately same as the flush write up. Anyone having done the cooler up grade and flush together - feedback would be appreciated, thanks!
2002 F350 7.3L / 4R100 - 4WD CC DRW 8’ Box, AIH Delete, Gauges- Pyro, Trans Temp, Boost, Fuel Pressure, TS-6 tuner, Zoodad Mod, Mishimoto 31 row Trans cooler, Mobil 1 ATF, Trans return line ATF filter, Hutch/Harpoon Mod, Air Lift Load Lifter 5000 rear air springs, Rancho 9000 shocks, Timbrens on the front.
Big Horn is offline
post #2 of 5 (permalink) Old 08-24-2018, 01:17 PM
Mark Kovalsky's Avatar
My Photos: (6)
Approximately the same, possibly one more quart.
Mark
Former
Automatic Transmission Engineer 1988-2007
Mark Kovalsky is offline
post #3 of 5 (permalink) Old 08-24-2018, 03:34 PM Thread Starter
Big Horn's Avatar
Thanks Mark
Big Horn is offline
post #4 of 5 (permalink) Old 08-24-2018, 10:32 PM
I would do the flush before I put in the new cooler or bypass it so you are not running all the old stuff through the new cooler.
DENNY
DENNY is offline
post #5 of 5 (permalink) Old 08-25-2018, 12:26 AM Thread Starter
Big Horn's Avatar
Ouch! $ I was going to switch over to Mobil 1 ATF by Marks reccomendation on one of his posts. But then again, that little stock cooler (7 row?) can’t hold much fluid. I see your logic, makes sense.
Big Horn is offline
