Is a Transmission Gauge Really Necessary? - Diesel Forum - TheDieselStop.com
post #1 of 5 (permalink) Old 10-01-2016, 06:01 PM Thread Starter
I've got a question, I am getting in to some "light" tuning, going to be getting a TS Performance Chip just for a little more up and go. I have installed an EGT Gauge, but I don't really see the need for a transmission temp gauge for what I am doing. I've owned my truck since new, and it's been stock up till now, I've been towing bobcats and all kinds of heavy stuff without any gauges, no transmission problems or anything at all. I understand that the transmission will get a little warmer, but I will leave it in stock mode when towing, but I rarely tow anymore, just driving, do I need an transmission temp gauge?
02_7.3 is offline
post #2 of 5 (permalink) Old 10-01-2016, 08:21 PM
RT
RT's Avatar
The need for a transmission temperature gauge has nothing to do with buying a tuner. It's a general recommendation to all 4R100 owners no matter what mods they have.
Sent from AutoGuide.com Free App
RT is offline
post #3 of 5 (permalink) Old 10-01-2016, 09:58 PM
yan7gin's Avatar
Keeping an eye on the temperature is recommended to prevent some damage that may occur.
For me I prefer buy a gauge than a trans. Its also a good peace of mind when towing and you see that the temp are good
F350 2002 7.3
auto, 37/13.5/20 open country, Bushwaker cut-out flare, Bilstein 5100, Maxtow gauges (EGT, Trans temp, Boost), 4 inch diamond eye turbo back axel drop with BTM muffler, S&B intake, RR AIH plug, billet FPR with gold spring, CNCfab Sgt 1 HPOP, CNCfab HPOP line with cross over, CNCfab 4 line fuel kit, ARP heads stud, RDP plenum reinforcing insert, complete CAC intercooler boot kit, full engine seal and gasket kit, 360* turbo rebuilt, WWII, EGPV delete, dark blue CPS, Hydra chip with SDK tunes, Polished compressor manifold, HD coolant, 203* thermostat, Transgo HD kit, Energy suspension bushing kit, front and rear diff fully rebuilt with 4:88 gear ratio, Z36 powerstop heavy hauling brake kit, headlight relay mod, Fumoto drain valve AND STICKER
F350 2008 6.4 (sold)
TT 26' Springdale 2014
7x17 enclose trailer (shop) 2012
yan7gin is offline
post #4 of 5 (permalink) Old 10-01-2016, 10:08 PM
chuckster57's Avatar
Get a gauge. You'll be surprised how much warmer it gets when you start dragging stuff around.
chuckster57 is offline
post #5 of 5 (permalink) Old 10-05-2016, 01:39 PM
As stated, even on a stock truck a trans temp gauge is beneficial when you are towing. It is good, cheap insurance. You can prevent the trans from melting down if something goes wrong and causes the temp to increase. For the small price tag, it is a no brainer...
