Triple disk converter - Diesel Forum - TheDieselStop.com
post #1 of 17 (permalink) Old 01-12-2017, 01:24 PM Thread Starter
blue99stroker's Avatar
So my rebuilt triple disk ford converter bit the dust.
I'm currently shopping around for a new converter and was seeking some input.
I'm at probably 375-380 hp and have no plans of going higher.
Would a grob cover triple disk hold up well or do you guys think a billet cover is necessary.
Thanks!
blue99stroker is offline
post #2 of 17 (permalink) Old 01-12-2017, 01:42 PM
Sorry to hear that Blue. Why did it go out? How many miles did you get out of it. Your custom tunes part ways from the traditional lockup?
Just curious.
No input or direction to point you to a fancy one.
Maryland dieselnick is offline
post #3 of 17 (permalink) Old 01-12-2017, 01:55 PM Thread Starter
I've noticed a slight shudder the last 5k miles. Then it would slip under moderate load.
I could feel and watch it slip through the pcm. Eventually got p0741 for excessive slip.
It lasted about 105k miles. It was fords first run of triple disks in 2007.
post #4 of 17 (permalink) Old 01-12-2017, 02:09 PM
Where do you see it? You watch it's lock status as well as shaft speed?
post #5 of 17 (permalink) Old 01-12-2017, 02:11 PM Thread Starter
I was monitoring it using torque pro on my wife's android and our tablet too.
Ya I can had the parameters to see gear command, rpm and torque converter lockup on screen.
When it would lock up I could watch it jump from 0-250 Rpms when it's supposed to be locked.
post #6 of 17 (permalink) Old 01-12-2017, 07:14 PM Thread Starter
Wel I just went with a triple disk converter with the stock cover. Upgraded internals.
Let's hope it lasts!
post #7 of 17 (permalink) Old 01-12-2017, 07:27 PM
Wanna break that down for me?
And what brand?
post #8 of 17 (permalink) Old 01-12-2017, 09:19 PM Thread Starter
I went with PDQ. They are local and John woods uses them in all his builds so they have a good rep.
Break which part down?
I went to the shop and saw my trans torn apart Again. That torque converter sounded like marbles rolling around lol.
post #9 of 17 (permalink) Old 01-19-2017, 07:19 PM
Googs's Avatar
Hey blue , I went all the way with my converter , I know I costs $ but if you tow heavy it's worth the extra dollars to have a triple plate and a billet front cover fitted.
It's horses for courses, in this case you have to decide dollars v's what you do and how you drive you truck.
03 F250 4x4 CC 7.3ltr 4R100HD rebuilt, 160,000 Klms
GTP38R , Turbo-master , IH Bellowed up pipes, RiffRaff CAC boot kit, AIH delete, .
4" Turbo back exhaust ,Banks power elbow, LPG (Gas over diesel) DP F6 tuner, 40hp tow, 60hp tow, 80hp tow, 60hp, 80hp, 120hp race, Decel, 1200 RPM.
RiffRaff 6637 intake ,pre filter, Snorkle
Custom made trans cooler with twin thermo fans ,water to oil cooler
Scangauge 11,AutoMeter Trans temp, pyro ,Water/Oil temp, Fuel Pressure, Boost.
Longrange 120 ltr fuel tank and transfer pump, 15,000 lb winch, Warn winch bar, Lightforce HID spot lights, HID headlights, Black Widow Drawer System, Snugtop Canopy with gull windows, Fr & Rr ARB Diff locks, Hornblaster Train horns, Post fuel pump filter, RiffRaff FRx and HPx , Bilsteins x4, Onboard compressor , Air tank and water traps, Billet door handles, Alpine headset, Alpine overhead DVD player, Rockford Fosgate sub, Alpine amp and CD changer.
Googs is offline
post #10 of 17 (permalink) Old 01-20-2017, 07:59 AM Thread Starter
Dave! Welcome back!!
I wanted the billet cover but the wait was really long
post #11 of 17 (permalink) Old 01-20-2017, 04:54 PM
Googs's Avatar
Thanks mate, good to be back .
What did you end up fitting or are you still waiting?
Googs is offline
post #12 of 17 (permalink) Old 01-20-2017, 06:24 PM Thread Starter
It's a triple disk with upgraded bearings and stator.
Basically everything but the billet cover
post #13 of 17 (permalink) Old 01-22-2017, 04:04 PM
Googs's Avatar
You will be fine with that set up blue , you don't tow real heavy for any long distance.
Distance + weight = heat
Googs is offline
post #14 of 17 (permalink) Old 01-22-2017, 06:51 PM Thread Starter
Thanks for your insight Dave!
One day I'll get a big toy hauler. Until then nothing big lol
post #15 of 17 (permalink) Old 08-23-2019, 06:43 PM
69mach1377's Avatar
Hey blue,
How is that converter holding up?
Was there a part number or something? Their website offers little help.
2000 F250 XLT 4x4 SC 7.3 w/Auto Tranny w/ TC L/U Sw & shift kit, 3 autometer gages, Super Zoodad, PHP Hydra chip, 4" DP/Exhaust w/dual 3.5" outlets, 275/70/18 Kumho AT51s on 8.5" rims, 08 AlumDiffCvr, Bilsteins, 31 row trans cooler, WW, BPV delete, AIH delete, hutch, harpoon and billet FPR (70psi), trans cooler bypass delete by accident, rear air bags, Jimmijammers.
Jayco 26BHS elite, no RV parks...just the woods if possible.
See my album for a recent pic.
69mach1377 is online now
