Truck is sick. Pulling 18k - Diesel Forum - TheDieselStop.com
post #1 of 25 (permalink) Old 08-11-2018, 02:11 PM Thread Starter
Texas_proud77836's Avatar
I’ve heard y’all say to keep it in 5th and not 6th but with 4.33s I’m running crazy rpms.
Question is how does y’all trucks do running 18k up a hill. Going down a hill hitting 70 then going up the next one flooring it to go about 57mph..... needs something. I’ve got a turbo kit but maybe injectors to. Am I asking to much from this old truck?
Texas_proud77836 is offline
post #2 of 25 (permalink) Old 08-11-2018, 06:52 PM
2000F250-7.3's Avatar
What is done to the truck. A set of stage one injectors would wake it up good.
2000 F250 7.3 4inc exhaust, Ts 6 pos chip witch custom tunes, Built 4R100 w billet triple disc converter, 6.0 trans cooler and deep tans pan, CCV mod, 4 gauge pod A piller,Boost,Trans temp,EGT,fuel pressure AFE intake,RIFFRAFF Frx fuel Rail dead head fix black spring,High Flow banjo bolts,High Flow CVD Fitting, Harpoon mod,Diesel site adrenaline HPOP,AIH Plug,Plenum Reinforcing Inserts. FULL FORCE DIESEL STAGE 1.5 single shot injectors, Garrett powermax GTP38R and blank pedestal, RIFFRAFF Intercooler CAC Boots with complete clamp kit , scanegauge 2
2000F250-7.3 is online now
post #3 of 25 (permalink) Old 08-11-2018, 09:54 PM
oilcan1001's Avatar
PHP Hydra chip worked wonders for me, but my 5'er is only about 11k loaded
2001 F-350 Lariat 4x4
CC, SRW, LB, AT
New radiator
6.0 OEM 26 row trans cooler
AIS intake
Edge Insight
Hydra with stock PHP tunes
2004 Sandpiper by Forest River - 11,000 lbs fully loaded
Andersen Ultimate 5th Wheel Hitch
oilcan1001 is offline
post #4 of 25 (permalink) Old 08-12-2018, 10:17 AM Thread Starter
Ya she pulls 10-12k pretty good it’s just when you get into the heavier things. Then hay catches so much air it’s like dragging a tarp.
Truck only have exhaust, air intake and edge chip. I’ve got everything for a turbo upgrade just really need to get to it. 160/30 full force injectors right?
post #5 of 25 (permalink) Old 08-12-2018, 01:18 PM
Originally Posted by Texas_proud77836 View Post
Ive heard yall say to keep it in 5th and not 6th but with 4.33s Im running crazy rpms.
Question is how does yall trucks do running 18k up a hill. Going down a hill hitting 70 then going up the next one flooring it to go about 57mph..... needs something. Ive got a turbo kit but maybe injectors to. Am I asking to much from this old truck?
Yea, 57mph pulling 18k up a steep hill is about all I can do. You're probably gonna need the injectors plus the turbo kit.
2001 F350 XLT 4X4 crew cab, dual rear wheels, long bed, black, 7.3l turbo diesel, automatic transmission, 4.10, shift on the fly, running boards, sliding rear window, 38 gal fuel tank, Odyssey extreme 65-PC1750T batteries, Michelin LTX-MS2 rear tires, Sumitomo Encounter front tires, Shell Rotella Ultra elc, 11,500 gvwr, 20,000 gcwr, 7500 gvw, completely stock, 114,000 miles when purchased, now has 240,000 miles, repairs so far: two starters, batteries, cps, brakes, tires, alternator, ball joints, locking hub, wheel hub, AC compressor, serpentine belt, power steering pump, driver's side window, ignition switch, o-ring, Spectra premium radiator, water pump, fan clutch, fan blades, thermostat, thermostat housing, tensioner. Stolen twice so far, but recovered both times with major damage.
DonWarkentin is online now
post #6 of 25 (permalink) Old 08-12-2018, 04:42 PM
69mach1377's Avatar
What are 'crazy rpms', in number form?
2000 F250 XLT 4x4 SC 7.3 w/Auto Tranny w/ TC L/U Sw & shift kit, 3 autometer gages, Super Zoodad, PHP Hydra chip, 4" DP/Exhaust w/dual 3.5" outlets, 275/70/18 Kumho AT51s on 8.5" rims, 08 AlumDiffCvr, Bilsteins, 31 row trans cooler, WW, BPV delete, AIH delete, hutch, harpoon and billet FPR (70psi), trans cooler bypass delete by accident, rear air bags, Jimmijammers.
Jayco 26BHS elite, no RV parks...just the woods if possible.
See my album for a recent pic.
69mach1377 is offline
post #7 of 25 (permalink) Old 08-13-2018, 08:16 AM Thread Starter
5th gear 60 mph 2800rpm you’re not gonna see 70mph without getting into the 3 grand in 5th.
post #8 of 25 (permalink) Old 08-13-2018, 08:19 AM Thread Starter
I think it’s just underfueled needs a turbo build. I let someone drive it awhile back and he stalled it in 2nd... I can pull out from a stop light in second if it’s slightly down hill... but he was acting like it was a normal thing back when he m
Owned his 7.3 to skip first gear.... idk
post #9 of 25 (permalink) Old 09-16-2018, 10:18 AM Thread Starter
69 Mack my crazy numbers is 2800 rpm at 56 mph in 5th.... so there’s no way you’d be about to go 70mph without going into 6th gear.
I noticed this the other day pulling 8k of Fertalizer. I had my headphones in and just let it rip. Truck sounded like it was gonna blow up when I took a plug out of my ear but I just said oh well.
post #10 of 25 (permalink) Old 09-16-2018, 06:45 PM
69mach1377's Avatar
Well redline is what, about 3300? I heard it's pretty hard to over rev these engines but yeah, I guess headphones and prayers are your best bet. lol
post #11 of 25 (permalink) Old 09-17-2018, 10:18 AM
blue99stroker's Avatar
F450-f550’s have to run 2800 just to drive on the freeway
Your not going to hurt it at 2800.
The max gvwr according to the owners manual is 20k
So grossing 25-26k only maintaining 57mph up hill is pretty good
Ditch the edge chip and get some better tunes.
160/30’s are going to require an upgrade clutch and definitely a turbo upgrade for towing heavy.
At a minimum a billet wheel and 1.0 turbine housing.
Also, towing wih more power just wears down the rest of the truck if your towing in a hot tune
99.5 f250 7.3 4x4- 277k FF 160/30, Hydra w/SDK Tunes, S&B CAI, 4" Exhaust, Van turbo w/Riffraff Billet wheel, Autometer Gauges, Built Trans, Trucool Max, 08 Tow Mirrors.
Dads-2000 f250 7.3 4x4- 118k K&N Intake w/Amsoil Filter, 4" Exhaust, Autometer Gauges, Superchip 1705 (Tow Safe), BD Billet Wheel, TruCool Max, 08 Tow Mirrors.
blue99stroker is offline
post #12 of 25 (permalink) Old 09-18-2018, 08:48 AM
I forgot to add what do your egts look like foot to floor with 18k behind you going up a hill?
post #13 of 25 (permalink) Old 09-18-2018, 09:50 AM Thread Starter
Ya.... I’ve got a turbo kit in a box with the ebpv delete I’ve been been meaning to get to it but it won’t happen till winter. I’ll also be getting 160/30 single shots with a ts programmer for them from DP when I do the turbo..... but ya your other question, I’m not sure on egt, I rarely drive the truck and mostly just mess with adding things during the winter. I will say that the factory gauge was running hot, but soon as a sit at a traffic light for a few seconds it goes back down. I don’t believe it’s accurate. If it is I’m relying on the cast iron to keep everything together till I get my turbo stuff put on. I hear the edge chips run hot,I know it’s not the best. I just try to let off the gass going down hills to help the engine cool.
post #14 of 25 (permalink) Old 09-18-2018, 10:27 AM
RT
RT's Avatar
If you don't have a true EGT gauge on this truck - you need to get one. Towing that heavy stock you need one and if you do ANY performance mods at all, you REALLY need one. Remember, aluminum melts at 1221 F., and you can get there pretty quick if you aren't careful.
RT is offline
post #15 of 25 (permalink) Old 09-18-2018, 12:14 PM
Ya that’s kind of scary towing that heavy with edge tunes.
I imagine you were 1500-1600 degrees for awhile lol
Your going to need a larger turbine housing. The 66mm diy kit isn’t enough.
And skip the TS with custom tunes. Most of the time you need revisions and you would have to send the chip back in meanwhile your truck is parked.
Get a hydra with custom tunes.
From SDK, 1023 diesel, jelibuilt, gearhead.
Do the research. Not just on this forum. Powerstroke.org, Facebook groups, powerstroke nation etc etc you will find the recommended tuners very different than the old posts on this forum.
Your looking at 325 for the hydra then 100-200 bucks for tunes that will be emailed to you.
Then If you need revisions they email them to you for free
