Truck is too Loud - Diesel Forum - TheDieselStop.com
post #1 of 5 (permalink) Old 06-05-2013, 10:34 AM Thread Starter
lone_star_dsl's Avatar
Truck is too Loud
I've had my truck for nearly 11 years now. I bought it when I was 20 and thought I would be the coolest kid in town if I had a truck that was loud. A decade later, I have a wife and a son, a fifth wheel that we use nearly every weekend through the summer and a truck that will drive it's occupants insane with noise. I guess I'm moving on to a "seen and not heard" mentality.
Since my truck suffers from turbo surge, which is why I bought the WW to begin with, would adding an ATS ported housing and re-installing the factory compressor be any quieter than what I have now while keeping me surge free?
If not, are there any other suggestions? My ultimate goal is to have as quiet an interior as I can get. I've done a lot of reading about Dynamat installs as well as the Excursion hush panels but I don't think either of those would help with the screaming turbo whistle.
2016 RAM 3500 Big Horn, CC LB, DRW, 6.7 CTD, 4wd, Aisin trans
Gone but not forgotten...
2002 F-350 SRW
Lariat, Crew Cab, Long Bed
4X4, Auto Trans, Tymar Intake
Wicked Wheel, Zoodad Mod
DP Tuner - 60E, 80E, 40T, 80T, Decel
05+ Harley Headlights
6" Upper and Lower Windshield Brows
ISSPRO Gauges, Edge Insight CTS
Sold at 206,000 miles
lone_star_dsl is offline
post #2 of 5 (permalink) Old 06-06-2013, 02:42 AM
For noise reduction, I did the snowman mod and that really helped. It's just putting a can koozie (or however you spell it) around the steering shaft against the firewall. I've also read that there is also a new (upgraded) seal that will help reduce noise too. All that being said, it didn't reduce the turbo noise much...just the diesel clatter.
The only thing I can really think of that would reduce the turbo noise would be a different intake. Maybe and AIS, or the stock box again. I know when i went to an open element the turbo noise increased quite a bit.
Hope this helps a bit and that other will chime in soon.
2000 F350 lariat, crew cab, long bed, 4x4, 3.73 limited slip
LASB turbo from Irate Diesel
Bellowed up-pipes
4" turbo back exhaust
Gauges (EGT, Trans Temp, Boost)
AFE Stage 2 XP Pro Guard 7
DP Tuner F6 (no start, stock, 80e, 60e, 60t)
AIH delete and CCV mod
F650 Dash with Carling switches
2002 Headlights with FX-R HID bi-xenon projector retrofit and 50W 5000K bulbs
53fordguy is offline
post #3 of 5 (permalink) Old 06-06-2013, 09:22 AM
444-4D's Avatar
I'd put the OE wheel back on the turbo, install an AIS intake, and get some tuning that doesn't surge.
444-4D is offline
post #4 of 5 (permalink) Old 06-10-2013, 11:29 PM
This doesn't make any sense to me. From my experience, no tune will eliminate surge.
I will agree that ais will help quiet the turbo whistle.
Ats housing and/or ww2 should help as well. It is amazing how much quieter excursions are on the interior, not sure whats so different
03 F350 7.3L Auto CC LB Dually 410's (LS Rear)
PHP/Beans tuned/250/100 FF inj's, BTS Tranny, Strictly Diesel complete fuel system with RR & FB delete, Pius LASB from Irate, Swamps HVHF IDM.
Autometer Nexus Guages, 4"MBRP, DieselSite Coolant filtration system/billet housing/HP X-Over line. Baldwin PA2818(6637) RR Boots/CBillet Plenums, ('06) 26 row Tranny & PS Cooler, LarryB's Genuine Denso Starter
INFRNL is offline
post #5 of 5 (permalink) Old 06-14-2013, 03:50 PM
My Photos: (5)
ATS housing and AIS, which is what I have, is very quiet. I also have dynamat. Aside from the exhaust, it is pretty damn quiet. Of course that does not include in the winter, when it is loud as hell and sounds like it wants to explode. Having said that, if the turbo has to come out for any reason, I might ad the WW2, which is supposed to spool very fast. That will give it a little more whistle, from what I am told.
2002 F-250, PSD 6-speed, CC, short bed, 4X4, Toreador Red w/ Silver accent, A.R.E mx cap, Weld Super Single II and 33s in the summer, x-springs, F-350 blocks and badges, AIC, proflaps, ITP intank mod, AirDog with 3 micron filter, isspro guages and TTM, scangauge, husky liners, alarm, xm stereo,stull 5399-p grille, centramatics, ccv mod, AIS Air Filter, Southbend CON O, Detroit Truetrac LSD, coolant filter, 203 stat with billet housing, blackcloud intake heater plug/boost fitting, reese titan hitch, fabcraft PTO cover/temp sender port, prodigy brake controller, ITP Boost Annihalator, oilguard bypass filter, Mag-Hytec rear dif, bilsteins, hellwig rear stabilizer bar, ATS housing, non-ebpv pedistal and exhaust flange, magnaflow 3.5dp exhaust, ITP reg return, turbomaster wastegate controller, and ceramic coated bellowed up pipes, PHP 50t and 80p, currently 127,000 miles.
clydesdale is offline
