TS 6 position chip, is it programmed? IF NOT? - Diesel Forum - TheDieselStop.com
post #1 of 3 (permalink) Old 05-05-2017, 09:50 PM Thread Starter
Pulled my PCM, code is NVK3, bought my TS chip from Riffraff. They asked year model and manual or AT. Pulled chip out of package and card that came with chip doesn't show a default code? If I install and it is blank what will happen. Want to put it in and head home for MO, at my dads in KY.
99,7.3workhorse is offline
post #2 of 3 (permalink) Old 05-06-2017, 07:29 AM
greenskeeper79's Avatar
If it's blank or not programmed correctly the truck may not start. However, if that's the case you can just remove the chip and drive home on the stock PCM until you get things figured out.
Gunga galunga...gunga -- gunga galunga.
97 F-250 CC 4x4 7.3L PSD E4OD
99 F-250 CC 4x4 7.3L PSD ZF6 E99 CALI DELETE
ROTELLA 5W-40, MOBIL1 ATF, PENNZOIL SYNCHROMESH
greenskeeper79 is offline
post #3 of 3 (permalink) Old 05-06-2017, 11:31 AM Thread Starter
Thanks, Riffraff answered my e mail last night, says it is programmed. Ill put it in and see how she works. Is it possible they do their own programming? Good to know I can just remove it. I remember guys talking about having to have dealer reflash thiers for some reason?
