Turbo boost - Diesel Forum - TheDieselStop.com
post #1 of 2 (permalink) Old 02-28-2005, 10:06 AM Thread Starter
Turbo boost
What kind of numbers are you guys pushing with your stock turbo? Does this increase when you unplug the wastegate? For some reason I can't seem to get above 19 psi with or without the wastegate unplugged. The problem is when I put my chip in which is a TS four position chip, I am running some really hot EGT's and I think this is due to the lack of boost. Even under the lowest setting of 50, I can still hit 1200+ easily even on flat land.
Also I have blown off the EBPV three times and have fixed and replaced the clip but what could this be caused by?
Thanks for your help, Jared
2002 F-250 PSD, 4x4, black, K&N Intake, 4" downpipe to dual 5" tips straight out, clear corners, three pod a-pillar mounted Autometer Carbon Fiber series gauges, Stull Billet grille, TS Performance 4 position chip, White Knight Back-up Lights, Stainless Steel Door Handles, Wicked Wheel, window tint, and weathertechs.
aznhashi is offline
post #2 of 2 (permalink) Old 02-28-2005, 10:14 AM
Re: Turbo boost
Check all your boots. Especially the 2 orange ones under the Y pipe. Sounds like you have a leak somewhere.
'01 F-350 Oxford White, 4x4, Auto, CC, LB, DRW - Lots of stuff
'85 F-250 Reg cab 4x4 6.9 - The new puller.
psychostroker is offline
