turbo upgrades - Diesel Forum - TheDieselStop.com
post #1 of 3 (permalink) Old 01-04-2010, 06:16 PM Thread Starter
Ryanspowertroke's Avatar
turbo upgrades
I'm lookin to do some turbo upgrades on the cheap. It's a daily driver so not lookin to do anything huge. Thinkin like wicked wheel, gutted ebv, like to be nonwastegated but whats the cheapest and easiest way.
2000 F-250 7.3L
8" Lift with traction bars
325/80/16 ProComps
DP Tuner High idle,60t,80eco,120r,140ag
DIY Tymar Intake
4" MBRP straight piped
foil delete, zoodad mod, 10K mod, aih delete
Glow Shift guages they suck but they were free
Ryanspowertroke is offline
post #2 of 3 (permalink) Old 01-06-2010, 04:02 AM
fredwilliamson's Avatar
ATS and other vendors make turbo housings. They are better quality, help against turbo surge, allow safer higher boost pressures. Not sure if theres any more pros for uprgrading these, but im sure someone will chime in soon with greater knowledge.
As far as wicked wheel....it appears to be a "love it or hate it" upgrade. Some say it helps build boost faster and makes the whistle louder and gives more hp. But then again others say its a waste of time. I would do a search for it and do a little research before dropping the $$$.
Gutted ebpv....I removed my ebpv equipped turbo pedal assembly and replaced it with a non-ebpv pedistal out of an econoline van only because mine was leaking oil severely. This didnt give any performance gains however at the same time i replaced my turbo outlet with a non-butterfly outlet and theoreticly the exhaust is unrestricted as it leaves the turbo to the tail pipe. The only down side to this is living in az we dont really have cold winters but when im in Oklahoma it takes forever for the heater to heat up.
Hope this helps.
2006 Ford F350 cab-chassis Lariat ZF6. 4x4, crew cab, 9' cm er body.
fredwilliamson is offline
post #3 of 3 (permalink) Old 01-06-2010, 09:06 AM
My Photos: (19)
You may also look into changing the outlet housing. I do not know what this will do exactly as I haven't researched it enough yet. However, I hear it can do good things.
DP-Tuner 80T, 160cc single shots, GTP38R turbo, Ceramic coated IH up-pipes, coolant filter, 6637, DIY exhaust brake, openair CCV, propane, SBC DD all ceramic clutch, ISSPRO EV boost/pyro/HPOP pres./rear end temp, 4" lift, traction bars, 255/70R22.5 tires, York air compressor, 16 flashy lights, 12 strobes, 12 switches on console, 9 switches on the dash, 7 two-way radios, 5 air horns, laptop, siren, 105 gal. in-bed fuel tank, Kennesaw Mountain front bumper
'86 H-D Sportster - 16" apes, custom paint, custom pipes to fishtails, single fire ignition, leather saddle bags on custom brackets, bagger fender, solo seat, home made luggage rack, all LED rear lights
BTBBT is offline
