Turbo Upgrades - Diesel Forum - TheDieselStop.com
 1Likes
  • 1 Post By blue99stroker
post #1 of 9 (permalink) Old 08-23-2018, 07:02 PM Thread Starter
Turbo Upgrades
So I installed a wicked wheel 2 and a 1.0 A/R housing. I tightened my waste gate to keep it closed. the hose to it hasnt been there forever. the other end is plugged. I am curious though, I was under the impression these two upgrades would lower egt and increase boost. I was pulling my fifth wheel today and I kept getting hot. over 1250 egt and only about 15 psi boost. I was in the stock tune. I had removed my diablosport off the truck
2001 Ford F250 4x4 CrewCab 7.3 Automatic, 4 inch MBRP exhaust, Diablosport Predator, Edge evolution (monitor only), Cold Air intake,
Andrew Hubert is offline
post #2 of 9 (permalink) Old 08-28-2018, 10:58 PM
yan7gin's Avatar
The bigger housing will lowe egt but also lower boost while dropping drive pressure witch is a good thing.
But that boost is low for the WW2. I run 33 psi with the 1.15 housing with about 38 drive pressure.
I would do a boost leak test and look around your up pipe for leak.
Is your red line still hook up?
F350 2002 7.3
auto, 37/13.5/20 open country, Bushwaker cut-out flare, Bilstein 5100, Maxtow gauges (EGT, Trans temp, Boost), 4 inch diamond eye turbo back axel drop with BTM muffler, S&B intake, RR AIH plug, billet FPR with gold spring, CNCfab Sgt 1 HPOP, CNCfab HPOP line with cross over, CNCfab 4 line fuel kit, ARP heads stud, RDP plenum reinforcing insert, complete CAC intercooler boot kit, full engine seal and gasket kit, 360* turbo rebuilt, WWII, EGPV delete, dark blue CPS, Hydra chip with SDK tunes, Polished compressor manifold, HD coolant, 203* thermostat, Transgo HD kit, Energy suspension bushing kit, front and rear diff fully rebuilt with 4:88 gear ratio, Z36 powerstop heavy hauling brake kit, headlight relay mod, Fumoto drain valve AND STICKER
F350 2008 6.4 (sold)
TT 26' Springdale 2014
7x17 enclose trailer (shop) 2012
yan7gin is offline
post #3 of 9 (permalink) Old 09-05-2018, 12:25 AM
1.0 a/r housing is stock size
You most likely have boost leaks. Search for the boost leak detector and check up pipes at collector (should get bellowed up pipes no matter what), check all boots at intake spider, plenums, and intercooler.
2000 F-250 4x4 SuperCab Short Bed 7.3 w/ 280,xxx mi - 4" Pro Comp - Redhead - 37x12.50x17 BFG A/T KO - 3.73 Gears - CTS2 - Hydra - FFD 238cc/80%
KC38r 366 - Adrenaline - Irate Fuel System w/ Sump - 4"Exhaust - K&N CAI w/ S&B Filter - FFD Bellowed Up Pipes - AIH Plug - RiffRaff Plenums & Boot Kit
mcnance865 is offline
post #4 of 9 (permalink) Old 09-05-2018, 10:20 AM
blue99stroker's Avatar
1.0 is not stock turbine size.
.84 is
You need more fuel to keep that bad boy spooled up.
15 psi stock is normal but not it’s a bit laggier due to the bigger housing
99.5 f250 7.3 4x4- 277k FF 160/30, Hydra w/SDK Tunes, S&B CAI, 4" Exhaust, Van turbo w/Riffraff Billet wheel, Autometer Gauges, Built Trans, Trucool Max, 08 Tow Mirrors.
Dads-2000 f250 7.3 4x4- 118k K&N Intake w/Amsoil Filter, 4" Exhaust, Autometer Gauges, Superchip 1705 (Tow Safe), BD Billet Wheel, TruCool Max, 08 Tow Mirrors.
blue99stroker is offline
post #5 of 9 (permalink) Old 09-06-2018, 12:53 AM Thread Starter
I do not have the red hose hooked up anymore and I tightened the spring on the. Wastegate. I have bellowed up pipes. If I tune the truck at all to add more fuel it doesn’t make anymore boost just egts. Sorry it took so long for me to reply. I was out of town
post #6 of 9 (permalink) Old 09-06-2018, 10:01 AM
.84 is
Yes, I don't know what I was thinking... stock is .84
post #7 of 9 (permalink) Old 09-06-2018, 11:30 AM
Andrew it sounds like you might have low fuel pressure or Icp then.
When you add fuel boost levels should come up.
Most guys see 28-32 psi with the ww2 and tuning.
Now subtract 5 psi or so from the max reading to get what your max should be with the 1.0 turbine housing
post #8 of 9 (permalink) Old 09-07-2018, 05:41 PM Thread Starter
I have a fuel pressure gauge on the truck, never been below 55 psi. I will have to get out my laptop and watch the pressures on the icp. Will that pull a code? I don't have any yet. Could my injectors be on there way out?
post #9 of 9 (permalink) Old 09-07-2018, 09:53 PM
You can use torque pro and a WiFi adapter with an android device
You want to read duty cycle and Icp. After heavy throttle for 5 seconds
Andrew Hubert likes this.
