Turbo to X-pipe o-ring? - Diesel Forum - TheDieselStop.com
post #1 of 7 (permalink) Old 02-19-2011, 08:47 AM Thread Starter
Got an easy question...
I just installed a 38R turbo the other day. I was reading the directions and noticed it said to reuse the o-ring mentioned in the title. The only problem is that I didn't have one, or it came off in the parts washer and I never saw it. After looking around for part numbers, it appears that only the '94-early '99 trucks had this part... can someone confirm this (or debunk this)? I really didn't want to track one down at the dealership if it wasn't needed.
My other assumption, is that it appears to have no boost leaks right now. I am getting about 22lbs of boost with the WG red tube connected, and about 26lbs with the same red line disconnected and plugged. Plus, the EGT's seem normal, and the 38r really appears to have cleaned up the black smoke on my DP +120 setting.
Thanks!
Tow Rig: 2000 F250 CC - ISSPro Gauges - BTS Tranny - 6637 intake - Muffler Delete - DP-Tuner (80eco-60tow-120race) - GT38R - Tekonsha Prodigy - 5" MBRP exahust.
Toy: '94YJ - LT1 - TH400 - Atlas 4.3 - 42" Iroks - D60/D70
Corn_Smuggler is offline
post #2 of 7 (permalink) Old 02-19-2011, 03:53 PM
lariat 7.3's Avatar
Send a message via AIM to lariat 7.3
i have a 2000 and i deff have an o ring there
2000 f 250 4x4. ccsb
just hit 218,000
38R with Turbo Master
238/80% hybrids
Riff Raff FRx
5 inch miter cut stack
remote start.
Autometer C2 series gauges.
5.5 inch lift with blocks and shackle drops
DIESELSITE HEAVYDUTY BOOTS ALL AROUND.
ITP in tank kit-awesome! frame mounted pre-filter
20 in diamo rims-33in toyo A/T
DP-TUNER F6- no start,stock,60 tow codes, 80E codes, 120 race codes
DIY TYMAR with donaldson filter.
AIH cut off
hood insulation removed
always bright overhead display
05 style headlights with 14k HID'S
08 leather front seats
bypass oil system
running on WMO!
DIESEL SITE coolant filtration
Denso HT gear reduction starter. Soo fast!!!
Wish List..... BTS....Stage 3 hybrids.... Push rods and Spings!!
lariat 7.3 is offline
post #3 of 7 (permalink) Old 02-19-2011, 05:07 PM Thread Starter
It sounded right that there was one, just thrown off by the 94-99 next to most of the part numbers I found. That, and everything seemingly normal with regards to boost leaks.
Maybe I'll gain a little power and lower some EGT's? Thanks for the reply.
post #4 of 7 (permalink) Old 02-19-2011, 05:48 PM
lariat 7.3's Avatar
yeah i;d think itd leak there because its metal to metal with no sealing factor
just hit 218,000
238/80% hybrids
Riff Raff FRx
remote start.
AIH cut off
bypass oil system
running on WMO!
post #5 of 7 (permalink) Old 02-19-2011, 06:46 PM Thread Starter
Called the dealership with the 94-99 part number and they tracked down the 2000 oring. will be interested in seeing the difference.
post #6 of 7 (permalink) Old 02-20-2011, 02:10 PM Thread Starter
Here's the part number for my 2000 7.3 in case anyone comes across this searching. Ford: F81Z-9E436-AA and it was $8 and change at my local dealership. It's listed as a "gasket" on the plastic parts bag, even though it's simply a rubber o-ring.
Also, for the record, it made a little more boost with it in there, but not a whole lot more. It does appear to have brought back a lot of the black smoke, which makes me wonder why it was so clean without the o-ring.
post #7 of 7 (permalink) Old 02-21-2011, 12:38 PM
My Photos: (19)
Have you tried the diesel o-rings site? The guy seems to sell any o-ring you could need for our trucks. Here, go here. I don't see it on his site, maybe give him a call?
DP-Tuner 80T, 160cc single shots, GTP38R turbo, Ceramic coated IH up-pipes, coolant filter, 6637, DIY exhaust brake, openair CCV, propane, SBC DD all ceramic clutch, ISSPRO EV boost/pyro/HPOP pres./rear end temp, 4" lift, traction bars, 255/70R22.5 tires, York air compressor, 16 flashy lights, 12 strobes, 12 switches on console, 9 switches on the dash, 7 two-way radios, 5 air horns, laptop, siren, 105 gal. in-bed fuel tank, Kennesaw Mountain front bumper
'86 H-D Sportster - 16" apes, custom paint, custom pipes to fishtails, single fire ignition, leather saddle bags on custom brackets, bagger fender, solo seat, home made luggage rack, all LED rear lights
BTBBT is offline
