Up-pipes / Turbo 360 Bearing rebuild - Diesel Forum - TheDieselStop.com
post #1 of 2 (permalink) Old 08-22-2019, 02:24 PM Thread Starter
Tazzman's Avatar
Been a bit. Been reading allot about up-pipes so will be going with Riffraff Bellow Up-pipes. Not allot of black soot but at idel I can feel the air coming out at the Y connection. will also be doing the Ebpv delete. as small oil leak there plus from Pedestal O-rings. And the AIH delete.
Also when turbo is out was going to upgrade the wheel with Riffraff Billet Compressor wheel ,and was going to rebuild with the 360 degree bearing kit from Riffraff. I also do tow a 8,000 lbs trailer. I can get EGT up there.
Question: do I need to have the turbo balanced after rebuilding it with the 360 bearing kit and new compressor wheel?
truck is in sig, its a 02 7.3 with 307.650 miles. also has a slow hard start with no smoke at start up or well running, also no codes, runs good after warmed up. per edge cs2 after oil warmed to over 120 starts to run.
Well working my way to the turbo, I was thinking of taking off the valve covers off and checking the injectors, making sure the oil is flowing on all 8. as these are still the original injectors. as not sure if I have injector problem. Lost alot of boost, acceleration, MPG. Also read I think said exhaust leak can cause some of these problem, but the hard start.
From reading hope I can do this in a weekend. If not just read use allot of PB buster and its a PITB job replacing Up-pipes, but most all take my time. Thanks.
02 F250 4x4 7.3 / 3.73 gear stocked Crew Cab Long bed.(306,650 miles on her) SP diesel exhaust brake and TC lock - not using the TC lock.
Riffraff:
FRx and HPx installed whit 306,550 miles.
1993 F350 7.3 IDI Ex cab dually long bed(Sold)
Tazzman is offline
post #2 of 2 (permalink) Old 08-23-2019, 02:29 PM
2000F250-7.3's Avatar
Sounds like your on the right track with some updates I would have it balanced with the new wheel. Some guys put a new wheel on and donít have problems. You might consider the KC turbo rebuild kit it comes balanced and upgrades both the exhaust side and compressor side of the turbo with a 360 thrust bearing. Up pipes leaking can cause a drop in mpg and boost pressure and increased egtís if bad enough. With that many miles on injectors they with cause cold start issues ruff idle lack of performance mpg problems as well if money is there might be a great time to do new injectors.
2000 F250 7.3 4inc exhaust, Ts 6 pos chip witch custom tunes, Built 4R100 w billet triple disc converter, 6.0 trans cooler and deep tans pan, CCV mod, 4 gauge pod A piller,Boost,Trans temp,EGT,fuel pressure AFE intake,RIFFRAFF Frx fuel Rail dead head fix black spring,High Flow banjo bolts,High Flow CVD Fitting, Harpoon mod,Diesel site adrenaline HPOP,AIH Plug,Plenum Reinforcing Inserts. FULL FORCE DIESEL STAGE 1.5 single shot injectors, Garrett powermax GTP38R and blank pedestal, RIFFRAFF Intercooler CAC Boots with complete clamp kit , scanegauge 2
2000F250-7.3 is offline
