Upgrade? More whistle and performance? - Page 4 - Diesel Forum - TheDieselStop.com
post #46 of 60 (permalink) Old 02-01-2011, 10:42 AM Thread Starter
maxtrax's Avatar
The WW are already balanced though right? If the shaft is balanced then the system should be balanced too.
So you are saying a ported housing is a better alternative than the WW?
2000 F-250 7.3L Turbo, 200K Miles, Extended Cab, Custom Brush Guard, ARE topper, 4" MBRP Exhaust, TS6 Chip with DPS Tunes, Gauges, 6637 air filter, harpoon and hutch mods, banjo bolt mod, fuel bowl mods, Riff Raff FRx, HPx, CCV mod, EBPV delete, bypass oil filter
maxtrax is offline
post #47 of 60 (permalink) Old 02-01-2011, 12:08 PM
My Photos: (19)
The Ported housing is MUCH better than the WW. Some have reported that they haven't completely eliminated surge with the WW. However, those that have the housing, have all said it completely eliminated their surge.
DP-Tuner 80T, 160cc single shots, GTP38R turbo, Ceramic coated IH up-pipes, coolant filter, 6637, DIY exhaust brake, openair CCV, propane, SBC DD all ceramic clutch, ISSPRO EV boost/pyro/HPOP pres./rear end temp, 4" lift, traction bars, 255/70R22.5 tires, York air compressor, 16 flashy lights, 12 strobes, 12 switches on console, 9 switches on the dash, 7 two-way radios, 5 air horns, laptop, siren, 105 gal. in-bed fuel tank, Kennesaw Mountain front bumper
'86 H-D Sportster - 16" apes, custom paint, custom pipes to fishtails, single fire ignition, leather saddle bags on custom brackets, bagger fender, solo seat, home made luggage rack, all LED rear lights
BTBBT is offline
post #48 of 60 (permalink) Old 02-01-2011, 05:19 PM
mwe-maxxowner's Avatar
Send a message via AIM to mwe-maxxowner
The ww may already be balanced, but I doubt it. What needs to happen is the wheel needs to be balanced ON the shaft. The wheel and shaft need to be balanced as an assembly. Your wheel/tire is balanced as a single unit. Then, you get new tires put on. This throws it all off and needs to be rebalanced. Same scenario.
87 f250 4wd LB ex cab 460 bored .60 edelbrock intake, towing cam glasspacks-6 mpg 8 on good day- my pride & joy once towed my '85 j-co j-crane 28' 5er
99 F250 7.3(engine stamped june of '99) 250K white ex cab lb, 2wd
jl audio slash 4ch amp, jl 8" sub, focal components front, infinity coax rear, 10 disc changer
-tymar intake, no muff
-bullydog egt, autometer boost
-f5 chip w/80t, 80e, 60t, 100, 140 extreme(140 is amazing!)
Garrett 38r
Chrome fender trim, 265 nitto terra graps, nerf bars, billet grille, '06 headlights, chrome door handles, louvered 5er tailgate
mwe-maxxowner is offline
post #49 of 60 (permalink) Old 02-01-2011, 06:46 PM
RIStroker2000's Avatar
Send a message via AIM to RIStroker2000
i hear all here.. my input.. didnt balance my turbo.. but my new wheel had a gouge.. almost a rotor like marking where i bet it was 'machined balanced' all good so far
2000 7.3 Extended Cab Long Bed Lariat...
nothing crazy, it carries alot of weight, it tows alot.. has all the 'usual' upgrades plus some..
she breaths well, has extra air and fuel
RIStroker2000 is offline
post #50 of 60 (permalink) Old 02-03-2011, 04:16 PM Thread Starter
maxtrax's Avatar
I've heard that the stock turbo wheel provides better air output with a ported housing anyway. Is that true?
maxtrax is offline
post #51 of 60 (permalink) Old 02-03-2011, 05:01 PM
Yes. The ww is supposed to be a less efficient wheel. I'm only speaking from research, but I've seen this stated many times. WW will flow a little less air, and not cure surge as well as the ats housing. But, the ww is crazy cheap, compared to the ats housing. I bought one that'd never been installed for 35 bucks, and never put it in due to concerns about balancing. Very happy with my ats housing.
Garrett 38r
post #52 of 60 (permalink) Old 02-03-2011, 10:45 PM Thread Starter
maxtrax's Avatar
Yeah, I am looking for a used ats housing. I figure if I can find one used it will be just as good as anything new. Not like a turbo housing can really wear out.
maxtrax is offline
post #53 of 60 (permalink) Old 02-04-2011, 03:47 PM
Exactly. A used housing will definitely be as good as new. If you remember, there was someone earlier in this thread who had a used ats housing for sale, and I will have one up for sale hopefully within the next couple months. Entire turbo with banks big head actuator too if anyone's interested.
Garrett 38r
post #54 of 60 (permalink) Old 02-05-2011, 12:24 AM Thread Starter
maxtrax's Avatar
PM sent. I am going to be patient about getting one as money is a little tight right now. Anyone else that has an inside scoop on a ported housing let me know as I am looking for a used one.
maxtrax is offline
post #55 of 60 (permalink) Old 02-05-2011, 05:12 PM
Conner's Avatar
ive been very happy with my ats housing, but i also have ww installed. put the ww on when i rebuilt the turbo. the stock made more boost with the housing, but the ww came with my rebuild kit. only reason i have it on. stock was destroyed when the turbo came apart. warped shaft and all. but i would suggest going with the ats, youll be way happier in the long run. or go with both and make it sound like a 6.0, i love the way mine sounds. i can deal with a little less boost. i havent checked it with an actual boost gauge but according to my insight monitor it lost about 9 psi. but i also need lower boots. the wheel just makes noise but the housing cures the surge. my .02 worth.
1999.5 F350 7.3L 6 speed ext. cab 4x4 flatbed. magnaflow 4in exaust. php chip stock, lope 65 tow 80 eco 100 140hp with insight monitor. Snow performance stage 3 water/meth, ats ported compressor housing. wicked wheel, ccv mod, diy tymar air filter. southbend clutch and flywheel.
dyno on 10-23-2010 at 357 hp and 800 tq at the wheels.
1986 F-250 H/D 6.9l non-turbo, 4x4, 4 speed manual, 3.55 ratio, 4 in. exaust to 5 in tip. no soup bowl,homemade front bumper, flatbed, JVC cd player, Galaxy DX919 cb with Wilson 2000 antenna and 900 watt Texas Star Linear. IF IT DONT BLOW SMOKE IT AINT RUNNING
I WORK FOR CUMMINS AND DRIVE A POWERSTROKE!
Conner is offline
post #56 of 60 (permalink) Old 02-06-2011, 05:05 AM Thread Starter
maxtrax's Avatar
Ok. I figured the housing seems like a better option. If I ever rebuilt the turbo in the future it will be easy enough to install the WW later. I would rather have the surge fixed now than just make noise.
maxtrax is offline
post #57 of 60 (permalink) Old 02-21-2011, 09:19 AM
I installed the AFE stage II and 4 in downpipe in hopes of lowering the EGTs when the chip is on while towing in the mountains. Neither lowered the EGTs a bit and the surge started. Installed the ATS ported housing and the wicked wheel. The surge is gone and the whistle is very noticeable. However none of this helped the EGTs. Since I have a six in lift and 37 in tires, I installed 4.56 gears. This helped a little but the EGTs are still there when towing the toy hauler in the mountains. So I did all this and I still have to tow in stock setting or watch the EGT gauge constantly. I think the 7.3 is just under powered. When the POS dies I'll be smart and get a duramax like my buddies and pass all the powerstrokes towing up the mountain passes.
Ozutah is offline
post #58 of 60 (permalink) Old 02-21-2011, 09:42 AM
What kind of boost are you running? You may have problems yielding high egt's. Also, ats housing AND WW will give a small drop in boost pressure, and small drop in performance.
You can say what you want, but my truck is not underpowered with basically only an intake and tune. It's very quick for a truck, and hauling my camper (which is not all that heavy at 10k, I'll admit) gets up to speed very quickly, and will handle any hill you throw at it. EGTs stay easily at or below 1250.
Maybe you're just expecting too much with 37's? Or maybe you have a boost or exhaust leak, or maybe a leak and expecting too much? What kind of tunes do you have?
Garrett 38r
post #59 of 60 (permalink) Old 02-21-2011, 12:15 PM
Sorry but I'm new to diesels,what is the foil delete? Why do it? Thnx,Brian
'00 F250 7.3, Ext. Cab, 8' Bed, 4" MBRP Turbo back, DIY Intake,172k and counting
bmart23 is offline
post #60 of 60 (permalink) Old 02-21-2011, 01:12 PM
If you search it, you'll find a lot on it. Basically, it's using some elbow grease and a solvent to remove the 'foil' wrap around the intercooler tubes. Supposedly, they provide some insulation against the turbo noise, and removing it will allow you to hear the turbo more. Other than that no benefit.
Garrett 38r
