Upgrade suggestions - Diesel Forum - TheDieselStop.com
post #1 of 7 (permalink) Old 12-20-2018, 06:31 PM Thread Starter
Upgrade suggestions
Looking for the right route to go with my truck. I currently have the transmission out getting a stage 1 sam wyse. So while it was out I was going to do bellowed uppipes, 360 rebuild, KC S3000 turbine, KC billet wheel, deleted outlet, deleted pedestal and possibly HPOP lines and 4 line fuel feed. Would this be a waste on stock injectors and should I have any worries about factory head studs? I really have no plans for injectors unless one fails someday.
Thanks for any input. I'm new to the diesel building word.
PS. already have hydra and gauges. Forgot that
Sent from my iPad using Tapatalk
loganhorse is offline
post #2 of 7 (permalink) Old 12-20-2018, 07:32 PM
I don't know your mileage, but you could also replace glow plugs.
2002 F350 7.3 psd supercab dually 2wd, AIS, Moog joints, Bilstein, Michelin Defender LTX, Dieselsite coolant filter, red ELC, prepump spin-on fuel filter, 254,500 miles, hutch/harpoon mod, marinco mod, scan gauge ll, Zoodad, Dieselsite boots, pedestal delete, CNC Fab w/ crossover oil lines, 6.0 trans cooler, replaced oil pan, Walker BTM, Denso starter
1974 CJ6 ... off the frame needs work
2013 Expedition... wife's car
Panhead ... 53 motor, 51 tanks, B grind cam, S&S carb, points, drum brakes ... It doesn't just sit in the garage
panhead george is offline
post #3 of 7 (permalink) Old 12-20-2018, 08:16 PM Thread Starter
220k
post #4 of 7 (permalink) Old 12-21-2018, 01:16 AM
klhansen's Avatar
My Photos: (180)
If you're going as deep as the turbo and pedestal, definitely replace glow plugs. Cheap insurance.
), AIS,
regulated return,
klhansen is offline
post #5 of 7 (permalink) Old 12-21-2018, 01:46 AM
When you say 4 line fuel feed do you mean a regulated return system?
DENNY
1999 F350 AUTO 4x4 CC LB DRW 4.10
DENNY is offline
post #6 of 7 (permalink) Old 12-21-2018, 06:57 AM Thread Starter
DENNY
What I was referring to was off CNCFab.
post #7 of 7 (permalink) Old 12-21-2018, 10:28 AM
Ya that is a fuel return system, good upgrade. You may run into some issues with that driver side rear fitting and the new turbo, just keep and eye on that area as you put it together. When you have all this out good time for a O-ring kit in the fuel filter.
DENNY
DENNY is offline
