Upgrading injectors and what else? - Page 2 - Diesel Forum - TheDieselStop.com
post #16 of 22 (permalink) Old 12-03-2018, 09:09 AM
blue99stroker's Avatar
It’s random. Pull the plug and check
99.5 f250 7.3 4x4- 277k FF 160/30, Hydra w/SDK Tunes, S&B CAI, 4" Exhaust, Van turbo w/Riffraff Billet wheel, Autometer Gauges, Built Trans, Trucool Max, 08 Tow Mirrors.
Dads-2000 f250 7.3 4x4- 118k K&N Intake w/Amsoil Filter, 4" Exhaust, Autometer Gauges, Superchip 1705 (Tow Safe), BD Billet Wheel, TruCool Max, 08 Tow Mirrors.
blue99stroker is offline
post #17 of 22 (permalink) Old 12-08-2018, 08:51 PM
I may have missed something, but it doesn't matter what chip you have now. If you change injectors, you will need new tunes.
I run FFD 250/100 injectors and I'm around 500hp or so on PMR's without issue. The tuner of choice will safely tune for pmr's so you don't do damage. I have ran several different tunes (PHP, Beans/no limit, powerstruck, etc) they all play nice with the pmr's. I just picked up a forged rod motor, but that is going in a project truck with a ZF6, so no reason to go full bore. If the forged rod motor was in front of my BTS, I could get a bit more and better tuning since there would be less worry.
238 or 250/100 would be a good choice if you want to max out what you have, but i would probably just do 238's. I think they tune better than the 250's. I have always had smoke while idling issues with my 250's, but it still passes emissions without issue.
If you want to spend money for injectors and supporting mods, you can do 238's or 250's. If you don't want to upgrade HPOP, etc, go with 160/30 or similar. I think 238's require upgraded fuel system as well.
EDIT: just went back and reread some things
there is a plug just behind the oil filter that requires a 5/16" square tool. I custom made one from square stock. There are plenty of youtube videos that show exactly what plug it is and what to look for. Basically if you see a nut, you have forged, if it's a bolt head you have PMR. My 01 manufactured in 00 has forged rods. all obs 7.3l have forged rods.
you need to set a solid goal for power wanted. if you do 238/250 100's no need for push rods/springs unless you are pushing over 40-45lbs of boost. if you run 200% nozzles you will want to do springs/rods. 250/200's will be in the 600hp range and you would want a borg warner S468 turbo with a Irate Diesel T4 mounting kit
for fuel upgrades, I use a strictly diesel kit on my dually, I went with an Irate kit for my new project. There are other good kits out there or you can build your own.
for clutch, you will probably want the south bend 650hp dual disc clutch, that is what was recommended to me. your 400hp clutch should hold up as long as you are easy on the truck. It will surely let you know otherwise.
03 F350 7.3L Auto CC LB Dually 410's (LS Rear)
PHP/Beans, 1023, SDK, GH tuned/250/100 FF inj's, Irate T4 w/369SXE, Swamps HVHF IDM, BTS Tranny, Strictly Diesel complete fuel system with RR & FB delete.
Autometer Nexus Guages, 4"MBRP, DieselSite Coolant filtration system/billet housing/HP X-Over line. Donaldson Blue(6637)/AFE BHAF, RR Boots/ Billet Plenums, ('06) 26 row Tranny & PS Cooler, LarryB's Genuine Denso Starter
INFRNL is offline
post #18 of 22 (permalink) Old 12-10-2018, 12:11 PM
brian42's Avatar
Originally Posted by blue99stroker View Post
PIS was sold and you will be hard pressed to find anyone who sells their injector now.
Quality has gone way down.
It is a bummer about PIS. They were great when Tim was the owner
I bought my injectors just before P.I.S. changed hands to Gray's Diesel Performance.
Customer service was atrocious and I'll sell my truck for $1 before I go back there. Luckily my injectors were built before the move and I haven't had an issue with them.
Don't forget to check any inspection/smog requirements. The bigger you go the harder it will be to get them past any state testing.
FWIW I'm happy with my choice. I have a T-500 HPOP but could run my injectors on a healthy stock pump.
I think my sticks are good for ~425-450 Hp but don't plan to go over 350 Hp for my needs/wants/desires.
The Money Pit
2003 F-250 7.3L PSD FX4 CCSB, Dual Alternators - 160/80 SS, T500, FRx, 6.0 IC & TC (w/Derale), S&B, RR 4/4 Wheel, EBPV-less, RR OCR, IH Up-Pipes, Hydra (PHP & GH), ISSPRO Gauges, FTVB, 4" MBRP, H&H, Racor PS120, 140A Alternators, North Stars, Dynatrac, XRF, ATS Springs
brian42 is offline
post #19 of 22 (permalink) Old 01-03-2019, 07:18 PM
Swamp_Fox's Avatar
What kind of drivability can I expect with 200/30 hybrids, a 38r w/WW2 and a Hydra for tunes? I am starting to research for replacing my injectors within the next few years. I am good with 350-400hp. I don't want anymore. I will tow a travel trailer/fifth wheel camper or maybe a small utility tractor in the future. Most of my daily driving would be unloaded highway miles to and from work. Would be great to get a mileage bump as long as I do my part by watching my foot. Would I be good with the suggested setup I made. I would also be buying an Adrenaline HPOP and sorting out my fuel system. Thanks for any feedback.
2002 F250 Lariat 4x4 Crew Cab Short Box 7.3L
Swamp_Fox is offline
post #20 of 22 (permalink) Old 01-03-2019, 09:24 PM
I would guess chance of getting improved MPG is very poor. Let me know if I am wrong.
DENNY
DENNY is offline
post #21 of 22 (permalink) Old 01-04-2019, 09:06 AM
FYI do not put any aftermarket wheel in a garret 38r.
Unless you get it balanced 400+ dollars it will die in 10-15k miles. This has happened to a lot of people.
For 350-400hp you only neee 160/0 or 160/30
A healthy stock hpop works as does a healthy stock fuel system.
I would do a modified valve body and larger cooler if your an auto at a minimum as wel.
post #22 of 22 (permalink) Old 01-04-2019, 06:42 PM
Swamp_Fox's Avatar
Thanks for the info. I am thinking Full Force on the injectors. I will try and do as much work as I can myself. I want to keep this truck as long as I can.
