Want to chip my 00 7.3L, but have tranny issues - Diesel Forum - TheDieselStop.com
post #1 of 9 (permalink) Old 12-22-2009, 12:47 PM Thread Starter
itorchedparis's Avatar
So when I bought my 2000 F-250, it had an edge w/ attitude chip already installed. There is an issue with my tranny that makes it shift hard from 1st to 2nd gear. With the chip installed and the added HP, the problem was HORRIBLE. I took the chip out and the problem is still there but not nearly as bad. I want to chip my truck with DP tuner or PHP, but am afraid it will only cause my tranny to act up again. Any suggestions/comments?
2000
F250 7.3L Lariat, Crew Cab/Short bed 4x4. AFE stage II intake. Magnaflow 3.5DP/4" SS exhaust. Isspro gauges (EGT, Boost, Trans Temp, Fuel Pressure) AIH Delete with riffraff boost fitting adapter, Foil delete, Muffler Delete, CCV Mod, Rebuilt HD Tranny with BTS valve body. 6.0 tranny cooler, ported compressor housing, turbomaster wastegate controller, garret high flow outlet, Non EBPV pedestal, dieselsite boot kit, Marinco mod, HPX mod, Sinister Diesel regulated return system, DP F6 tuner (60 tow, 80 econo, 120 race, High idle 1200, Drive Thru) Warn Hubs, 08 tailights, 05-07 front end conversion, 08-11 rear end conversion, Line-xed rocker panels/wheel wells/bumpers.
itorchedparis is offline
post #2 of 9 (permalink) Old 12-22-2009, 12:53 PM
tattoocharlie's Avatar
My Photos: (5)
tranny
well if your having an issue with your tranny you need to resolve it before rechipping your truck.is your o/d light flashing?if so theres a code stored which will lead you to the problem.anytime you add hp to your tranny it gonna put an added stress on it and can bring on early failure.
2002 f250 lariat 7.3 220k(motor has 190k)
original 4r100 tranny....220k and counting
knock on wood....
red elc good for 150k
4r100 1-2 2-3 3-4sonnax accumulator valves,.427 sonnax line pressure mod valve
4.125"yes thats 4 1/8" diy tymar intake(size matters...lol)
AIH delete,ccv delete,zoodad mod,
4" exhaust no muff
built my own leafs for 4.0 of lift!!!!!!
18" xd bronze revolvers with 325 nittos to wrap them
isspro pyro and boost guages on pillar mount....
tattoocharlie is offline
post #3 of 9 (permalink) Old 12-22-2009, 03:21 PM
Feedback Score: 3 reviews
X2..how many miles on the trans..fluid clean..
caryt is offline
post #4 of 9 (permalink) Old 12-22-2009, 06:58 PM
blueknight7's Avatar
You can try changing the fluid and filter, but, it might be like closing the barn door, after the horse got out. You will need to take care of the tranny issues first, then gauges, before any chip, programer.
"White Moose", 2001 F-250,XLT,Auto, Super Cab, 4x4. Early PSD, build date: Aug. 16, 2000, no PMR. AIS, AIH delete, Zoodad, CCV mod. (not any more), BTM, GOS headlite harness upgrade, harpooned fuel tank, B&W gooseneck hitch, Firestone air bags. 6.0 Tranny cooler, pillar mount, with Isspro pyro, boost, and tranny temp. Trailer Towing Mirrors, Bilstein Shocks, 03 Clear Headlights, HP Crossover line, DP Tuner F-5 switch: High Idle, 20 hp. tow, 40 hp. tow, 80 hp. tow, 80 hp. econ. drive thru. 200,000+ miles and still running strong. No mech. diode tranny. Changed to the 2002 model ,before it left the dealership. 25 ft. 24k Horse Creek, flat bed gooseneck.
blueknight7 is offline
post #5 of 9 (permalink) Old 12-23-2009, 01:40 PM Thread Starter
133,000 miles...I'm gonna change the fluid here shortly, so I'll see if that makes any difference. The OD light is not flashing. I want to upgrade the torque converter also, so i'll wait till i have enough cash and just pull the tranny and replace the TC all at once
2000
post #6 of 9 (permalink) Old 12-24-2009, 04:32 AM
BLOWINSMOKE99STROKE's Avatar
if you pull it and replace the TC, rebuild it too. The TC is the most expensive part of the deal. do it right the first time and you wont regret it.
EARLY 99 F350, CREW CAB, LONG BED. 4X4 7.3L AUTOMATIC. EDGE JUICE W/ ATTITUDE. 4" EXHAUST, NO MUFFLER, 6" TIP, COLD AIR INTAKE, BD: CCV KIT (WON ONLINE, THANK YOU BD). DVD PLAYER, PS2, IN DASH TV, POWER INVERTER, 2-10" INFINITY SUBS IN PORTED BOX. CLASS 5 REESE TOW PACKAGE, FLIP UP GOSENECK HITCH. CB/PA, WITH DUAL TRUCKER WHIPS. TOW MIRRORS, AND CAB LIGHTS, RECON LED TAILGATEBAR W/ REVERSE LIGHT, BUG GUARD AND WINDOW VISORS. 05 GRILL AND HEADLIGHT SWAP, 08 TAILGATE, 285/75 BFG ALL-TERRAINS, SHACKLE LEVELING KIT, AND BILSTIEN SHOCKS. 5% TINT ALL THE WAY AROUND, AND 50% ON THE WINDSHEILD.
SOON TO COME: 08 TAIL LIGHTS, CLEAR CABLIGHTS, RECON ESCALADE STYLE 3RD BRAKE LIGHT, STROBE LIGHTS, PROJECTOR BACKUP LIGHTS, 33X12.50 BFG ALL TERRAINS ON BLACK DICK CEPEK 17" RIMS, EDGE EVOLUTION PROGRAMMER (STACKED), RAPTOR HIGH PERFORMANCE FUEL PUMP, HIGH PERFORMANCE HPOP, POSSIBLY 10" STACKS!
BLOWINSMOKE99STROKE is offline
post #7 of 9 (permalink) Old 12-24-2009, 08:30 AM
kampinguru's Avatar
I know that some programmers do increase the line pressures a little to keep the tranny from self destructing and that will contribute to harder shifts. If you have the transmission rebuilt first, check with the maker of the chip you want to buy and see if they adjust the line pressure at all. The tranny builder can take that into account when they rebuild the tranny. If you have the chip already, it is easier for the tranny guy to tune the valve body to make the shifts clean with your chip.
2000 F250 Lariat S/C SB 4X4 Off-Road
7.3L PSD
2005 Cedar Creek 30RLBS
PullRite Superglide Hitch
Firestone Ride-Rite Airbags and Dual Commander II
LINE-X, Mag-Hytec Diff Cover, Autometer 3-gauge kit, AFE Stage 2 Intake, boot kit, coolant filter kit, A/C heater bypass.
DP Tuner F5 (40HP Tow, 80HP econ, 100HP Race)and ATS Housing
Magnaflow Performance 4 inch turbo back exhaust
BTS tranny
kampinguru is offline
post #8 of 9 (permalink) Old 12-24-2009, 10:46 AM
JimTJr's Avatar
My Photos: (20)
Virtually all chips, tuners change trans shift points or line pressure I think....
Most good tuners (People) will make it a good thing,,,,,
Jim T.*48* SLAPS Co-Founder, 30.8 yrs RETIRED UAW 6/01/06, Now an ART (Specialists Flight Chief) with the USAFR 414th MXS Seymour Johnson AFB.
New truck, 2011 F-350 SRW LB CC. White Platinum Lariat! 4x4
JimTJr is offline
post #9 of 9 (permalink) Old 12-24-2009, 01:30 PM
Best is have your tuner remove any additional pressure..best left to a VB. Great add is a BTS VB setup for your mods.
caryt is offline
