Weird noise after S&B cold air intake install - Diesel Forum - TheDieselStop.com
 1Likes
  • 1 Post By blue99stroker
post #1 of 3 (permalink) Old 04-05-2017, 08:43 AM Thread Starter
kench's Avatar
So when I let off the go pedal, I get a cross between a cat hissing, and whoosh of air coming from the truck. It lasts for like a second.
I thought maybe I was hearing turbo noise that I couldn't hear before the 4" turbo back exhaust, but then I read it is air coming out of the larger aftermarket intake.
Can anybody confirm that?
It is really loud when shifting into OD/4 under load while pulling my toy hauler.
Sounds similar to this guy's video:
2001 F-350, 7.3L, Crew Cab, 4x4, Dually.
202,000 miles, and going strong.
4" Turbo Back MBPR Exhaust
S&B Cold Air Intake
DP-Tuner F5 Chip
6.0 Trans Cooler
It likes to pull a 44' 3" 2016 XLR Thunderbolt 420AMP Toy Hauler
ISSPRO 3 gauge (pyro, boost, trans) pillar install.
Located on Long Island, NY
kench is offline
post #2 of 3 (permalink) Old 04-05-2017, 12:52 PM
blue99stroker's Avatar
It's normal. It's just air coming back out.
The stock box does it but it's enclosed so you don't hear it.
It's not the wastegate. The wastegate doesn't make noise.
kench likes this.
blue99stroker is offline
post #3 of 3 (permalink) Old 04-07-2017, 06:26 PM
yan7gin's Avatar
^ like blue said.
The only downside is you may want to floor it and let your foot off the pedal just so you can hear that noise 😂
Sent from AutoGuide.com Free App
F350 2002 7.3
auto, 37/13.5/20 open country, Bushwaker cut-out flare, Bilstein 5100, Maxtow gauges (EGT, Trans temp, Boost), 4 inch diamond eye turbo back axel drop with BTM muffler, S&B intake, RR AIH plug, billet FPR with gold spring, CNCfab Sgt 1 HPOP, CNCfab HPOP line with cross over, CNCfab 4 line fuel kit, ARP heads stud, RDP plenum reinforcing insert, complete CAC intercooler boot kit, full engine seal and gasket kit, 360* turbo rebuilt, WWII, EGPV delete, dark blue CPS, Hydra chip with SDK tunes, Polished compressor manifold, HD coolant, 203* thermostat, Transgo HD kit, Energy suspension bushing kit, front and rear diff fully rebuilt with 4:88 gear ratio, Z36 powerstop heavy hauling brake kit, headlight relay mod, Fumoto drain valve AND STICKER
F350 2008 6.4 (sold)
TT 26' Springdale 2014
7x17 enclose trailer (shop) 2012
yan7gin is offline
