Weird static when lights/blinker on - Diesel Forum - TheDieselStop.com
post #1 of 3 (permalink) Old 10-01-2016, 03:17 PM Thread Starter
Usmc1968's Avatar
Ok, so I recently upgraded my headlights with some SPPC aftermarket ones. They only came with the headlight bulb so I added the parking and turn bulbs (used LED). I suffered from hyper-flashing so I replaced the Flasher relay with a NOVITA EP27. That fixed the hyperf-lashing but now whenever I turn on the lights or use a blinker I get static coming across the radio. Sometimes so bad I have to turn the radio off. Any ideas what needs to be shielded or replaced? Thanks in advance.
2000 F250SD Lariat, CCLB 7.3
Semper Fi
"It does not require a majority to prevail, but rather an irate, tireless minority keen to set brush fires in people's minds."
Samuel Adams
Usmc1968 is offline
post #2 of 3 (permalink) Old 10-01-2016, 10:12 PM
yan7gin's Avatar
Did you try using ferrite choke on + and - of the lights?
Sent from AutoGuide.com Free App
F350 2002 7.3
auto, 37/13.5/20 open country, Bushwaker cut-out flare, Bilstein 5100, Maxtow gauges (EGT, Trans temp, Boost), 4 inch diamond eye turbo back axel drop with BTM muffler, S&B intake, RR AIH plug, billet FPR with gold spring, CNCfab Sgt 1 HPOP, CNCfab HPOP line with cross over, CNCfab 4 line fuel kit, ARP heads stud, RDP plenum reinforcing insert, complete CAC intercooler boot kit, full engine seal and gasket kit, 360* turbo rebuilt, WWII, EGPV delete, dark blue CPS, Hydra chip with SDK tunes, Polished compressor manifold, HD coolant, 203* thermostat, Transgo HD kit, Energy suspension bushing kit, front and rear diff fully rebuilt with 4:88 gear ratio, Z36 powerstop heavy hauling brake kit, headlight relay mod, Fumoto drain valve AND STICKER
F350 2008 6.4 (sold)
TT 26' Springdale 2014
7x17 enclose trailer (shop) 2012
yan7gin is offline
post #3 of 3 (permalink) Old 10-02-2016, 06:19 AM Thread Starter
Usmc1968's Avatar
yan7gin-
Nope, but I will now..Will post results. Thanks!
Semper Fi
Samuel Adams
Usmc1968 is offline
