What do these wires go to? - Diesel Forum - TheDieselStop.com
post #1 of 2 (permalink) Old 02-24-2011, 05:38 AM Thread Starter
navycranes's Avatar
I have a 2002 Excursion.
Under my hood just near the brake fluid reservoir there are these 4 wires that come out of the wiring harness that runs along the firewall. They are red, white, blue, and black.
Are these wires part of some MOD that was done and then removed before the previous owner traded it in? I thought thatís what they might be until I looked under the hood of my buddies Ď05 F-250 and he has them too.
Please take a look at the photo and let me know if you know what these wires go to.
Robert
The Truck:
2002 Excursion 4X4, 4R100 ,
Griffin CS Programmer, Zoo-dad, Dieselsite 203 Thermostat, Baldwin Oil Bypass, Baldwin in-line Transmission Filter, DIY Tymar w/Donaldosn filter, Red Head Steering Box, 6.0L Tranny Cooler, 4" MBRP turbo-back exhaust, AMSOIL, KENWOOD DVD/GPS entertainment system and always looking to do more....
The Trailer: 2005 Keystone Outback 28RSS, 8,000 GVW
navycranes is offline
post #2 of 2 (permalink) Old 02-24-2011, 08:01 AM
My Photos: (19)
Those are builder access wires, stock, put there by Ford. You will find the other end of them under your dash near the fuse panel. All they are is a built-in through-firewall wire run. Guys use them to hook up gauges, lights, anything that needs a wire through the firewall. But, here's the nice part. Under the dash, you will also find two more wires. They will have a molded cap on the end. These wires are power sources, one constant 12V, the other is a key-on source. You'll notice they aren't the biggest wires, so if you do use them for anything more than a few lights you'll want to use them to trigger a relay and run a larger gauge wire from the battery.
DP-Tuner 80T, 160cc single shots, GTP38R turbo, Ceramic coated IH up-pipes, coolant filter, 6637, DIY exhaust brake, openair CCV, propane, SBC DD all ceramic clutch, ISSPRO EV boost/pyro/HPOP pres./rear end temp, 4" lift, traction bars, 255/70R22.5 tires, York air compressor, 16 flashy lights, 12 strobes, 12 switches on console, 9 switches on the dash, 7 two-way radios, 5 air horns, laptop, siren, 105 gal. in-bed fuel tank, Kennesaw Mountain front bumper
'86 H-D Sportster - 16" apes, custom paint, custom pipes to fishtails, single fire ignition, leather saddle bags on custom brackets, bagger fender, solo seat, home made luggage rack, all LED rear lights
BTBBT is offline
