What will cause an injector to stay wide open for 30 seconds upon deceleration. - Diesel Forum - TheDieselStop.com
post #1 of 6 (permalink) Old 02-28-2005, 06:34 PM Thread Starter
I have been having problems with my truck smoking excessively and an intermittent rough idle. We have found that injector #7 is staying grounded or open for 30 - 40 seconds after decel. This is flooding cylinder #7 and causing excessive fuel consumption and smoke. Any ideas? I have Hypermax Stage 1+ split shot injectors with no chip until
problem is found. The injectors just came back from Hypermax so I am thinking wiring problem or electrical. You can see the mods in the sig.
Huck
02'Excursion PSD LTD, 4x4, Hypermax Stage 1+ Injectors, Hypermax H2E, Hypermax Tapercore, Hypermax 5", Suncoast, Air Raid, TS Chip, Pioneer DVD & Nav., XM, XTANT Amps & Subs in Rear Doors, Boston Seperates, PS2, 2 6" Drop Down Screens, Hellwig Sway Bar, Carbon Fiber Ultra Lite Gauges, 3" DR lift, 295/75/16 Nittos, Bilsteins & Steering Stab., (Burned To the Ground)
01' Excursion PSD Ltd. 4x4, Oxford White,3.73 LS, BTS Trans, 6.0 L Cooler, Pioneer Nav, ADS/U.S. Amps, JL Audio Seperates & Subs, Viper Remote Start, Tymar, 315/75/16, Pro Comp Stab., Bilsteins, TS 4 Pos. Chip, Hypermax Combo Gauge, 4" Exhaust, V & B Code Springs
05 Excursion 4x4 6.0L
05' F250 CC, SB, 4x4 Harley, Blue, 4 Buckets (SOLD)
00' F350 CC 4x4 Lariat Dually, BTS Trans, (SOLD)
00' 40' American Tradition Motorhome 8.3L Cummins
88' Porsche 930 Turbo Cabriolet 450 HP
99' Mercedes E300TD
Huckster is offline
post #2 of 6 (permalink) Old 02-28-2005, 06:51 PM
fordmastertech's Avatar
Re: What will cause an injector to stay wide open for 30 seconds upon deceleration.
This sounds ugly. [img]/ubbthreads/images/graemlins/eek.gif[/img]
Any codes in the PCM?
I would check for wires that are possibly chaffed in the engine, PCM and IDM harnesses that are grounding when the engine moves on deceleration.
Shorted UVC wire harness?
You said the injectors just came back from Hypermax, did this have this problem before you removed them?
[img]/ubbthreads/images/graemlins/shrug.gif[/img]
2000 Excursion Limited 4x4 Dark Satin Green Arizona Beige 7.3 DIT, AXDO, 3.73 LS, DP Tuner F5, TERMINATOR II w R-IPR, Adjustable Boost Regulator, Turbomaster, EBPV Delete, Air Dog, ITP Regulated Fuel Return, Fuel Cooler, Tags 1&2, Harpooned Tank, Magnaflow XL Exhaust w Aeroturbine 4040L, Sonnax/Tricumulator, 8 Autometer Sport Comp 4 Gauge A Pillar 4 Gauge Overhead, Ford APCM, Crimestopper Remote Starter With Remote Fast Idle, Ford AIS w Zoodad, W Code Front Modified B Code Rear springs, Rancho RS9000X, Rancho 5406 Stabilizer, Hellwig Rear Sway Bar, BFG Rugged Trail TA, V10 Trans Cooler w Dual Electric Pusher Fans, Coolant Filter, IAH Delete, (((XM))) Line Of Fire Light, Ford Cab Lights, 05 Headlights w GOS Conversion Harness, Jimmi Jammers, 03 Lighted Painted Tow Mirrors w C-BETR, PSD Badges, Pullrite Hitch, Prodigy Brake Controller, Born 01/29/00
fordmastertech is offline
post #3 of 6 (permalink) Old 02-28-2005, 06:59 PM Thread Starter
I bought the truck from an auction with all the mods on it. I took the engine out and put forged rods in it and balanced the bottom end and put head studs in. I also sent the injectors back to Hypermax to have them gone through. The truck had numerous wiring issues we found when working on. I stripped all electronics and gauges etc. out and rewired everything. Hypermax said they found problems with 2 injectors and flow tested all the others and installed new o-rings. Quite a few wires were rubbed raw. We fixed all we found and the truck runs great but just smokes a little at idle and excessively under load. I am boosting 35lbs and egt's are in check. As of now I don't have a chip in it until the problem with #7 is fixed. There are numerous codes in the PCM but the injector codes are high and low side codes on #6 and #8 I believe. I will recheck them and post all codes. Could it be an injector wiring harness problem, or an IDM problem? Any ideas are appreciated. I have an ex Ford Diesel Mechanic who now works at my buddies shop working on it. He has access to all Ford's computers etc. at night.
Huck
99' Mercedes E300TD
Huckster is offline
post #4 of 6 (permalink) Old 03-01-2005, 09:19 AM
Check the wire harness under the valve cover, I bet the connection is loose, get the clips to hold them in place.
2001 white F250 sc xlt psd," DI regulator kit, DI BIG fuel system, DI Mine-Me injectors, DI ATS BB Turbo, DP Chip,DI Valve Pressure Release,DI-adjustable IDM mod ",Terminator 2 HPOP R-IPR, APR studs, 910 valve springs, BTS Trans&Converter,6.0 Intercooler, AFE Stage 2 with zoodad,Power Elbow, Bully Dog full 4" exhaust with 5" tip,Fluidampr, hx mod,203t-stat, CCV mod, Fumoto Oil Valve,Cool-Max Trans Cooler, Autometer Phantom Gauges,Bilstein shocks, Rancho5406 stablizer, Edge 4" lift kit, Rear RoadMasters active suspension, EGR Slotted & Crossed Drilled Rotors with Carbon/Kelvar brake pads, Welds Cheyenne 8s, Roll & Lock bed cover, Sylvania SilverStar 9007& 9005s, Chrome Billet Grill, 2003 Clear Headlights, APC Clear corners, APC Euro rear lens, APC gas & brake peddles, Acetone Badges, Chrome Door & Tail Gate Handles, Oakley Seat Covers, Viper alarm, Cyclops Fuel Cut-off alarm.
joediesle is offline
post #5 of 6 (permalink) Old 03-01-2005, 03:11 PM Thread Starter
They are going to replace the under valve cover gasket w/wiring harness tomorrow and lets hope that is it.
Huck
99' Mercedes E300TD
Huckster is offline
post #6 of 6 (permalink) Old 03-01-2005, 07:20 PM
I have seen more than a few that the valve train rubbed the wires insulation off causing shorts. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
