when are the upgrades too much - Page 2 - Diesel Forum - TheDieselStop.com
post #16 of 21 (permalink) Old 01-03-2010, 03:39 PM Thread Starter
ok i understand ALOT of people on here dont like the k&n drop in filter. I don't have that. i have the complete kit and a prefilter sock on it. my question to anyone out there is... would the afe pro guard 7 filter fit onto my k&n system?? from, what i've seen online the dimensions are very close if not the same. anybody know if i am right or way off on this? basicly, is the bottom of the filter about 4in in diameter. the part that connects to the intake hose?
flguy1215 is offline
post #17 of 21 (permalink) Old 01-03-2010, 10:02 PM
I beleive I have seen people actually do that. I jsut can not recall if it was the AFE PRo7 used in the stage II or was the 6637 filter. I think they both fit the same. Can not remember if there was any modifing but I have seen it done. What is the out and inside diameter of the KN tube. You are also correct that Kn is not as bad as the drop in as it eliminates the issue of air pass around the filter but it still has a bad filter weave setup or whatever the technically name for it is. What I do nto get is they have owned the industry in the past why they woudl jsut sit on the tech and not advance it!?!
Unless you jsut hate the looks of the 6637 type filters take alook at the one AFE has out. Its their 5R tech version. MFG#24-9104
Here is one pic:
This filter outflows any other filter on the market and has more filtering surface area as well. Is washable and has a re oil schedule of 40K-50K miles. SO same service as the 6637 but you do not need a new one and flows more at less vacuum. Also does nto have issue with rain and water.
TARM is offline
post #18 of 21 (permalink) Old 01-03-2010, 10:54 PM
losfinch's Avatar
Well, I guess some would say, "Why mess with perfection?" ....but not me!
Early 99 F350 4X4 CC 7.3 Auto. A.R.E. Topper, bed carpet/bench inserts, Rhino grill guard, AIS w/sleeve, Fuel filler mod, GOS headlight harness, 02-04 Headlights, Rancho HD stabilizer, 06 Telescoping/heated mirrors with C-Btr Mirrors, Hella FF1000, Htr Bypass valve, front receiver hitch, Quadzilla XZT gauges, ITP Pre-pump/In-tank mods, Pioneer P5000UB w/XM radio, 4 Infinity Kappa 682.7cf, Fumoto valve, FIAMM Highway blaster horns, SS HPX, IDM mod, DP F5 (Stock,Drive-thru,60T,80E,120,80E-Mountain,1200), Walker BTM, RR, Dieselsite BRV, BTS Tranny (2nd one :-), 31 row tranny cooler, Bilstein shocks, Amsoil bypass oil filter, Stancor HD Glow Plug Relay, billet thermostat housing, front & rear parking cameras, Aux reverse lights, Heated Seats.
Security: CrimeGuard Alarm with remote notification, DIY jimmi-jammers, door cylinder locks and linkage removed, padlocked rear bench seat hinge, PCM, DIY "pitstop" switch.
losfinch is offline
post #19 of 21 (permalink) Old 01-04-2010, 01:53 AM
Maintain's Avatar
I've ran the same tymar filter for 30k miles. I pull 60+ psi of boost out of it still. Take the filter off and I see MAYBE 1-2 psi difference. PS, this is 60+ psi of boost out of a 75mm charger. The stock charger is somewhere around 54mm IIRC. What that means is that I'm pulling WAY more CFM.
Tymar FTW!!!!
2001 F250 CC/SB Platinum
11.62 @ 115.79
SWAMPED
Maintain is offline
post #20 of 21 (permalink) Old 01-04-2010, 10:52 AM
Feedback Score: 3 reviews
Nothing has been proven to outflow AND outclean a Donaldson filter the Tymar system uses.
caryt is offline
post #21 of 21 (permalink) Old 01-04-2010, 11:11 AM
Diezel Dawg's Avatar
Tymar FTW!!!!
I agree TYMAR FTW!!!
Very true Cary. I love my TYMAR intake. i have had both AFE kits, stages 1 and 2. and now the TYMAR and liek it bets, it does make the turbo alittle louder, well doesnt make it louder, but u can hear it more now
Ken
99.5 7.3L PSD 4x4
WOP GQSSB TURBO
Tyrant Diesel Tunes
TYMAR Intake
Casserly 250cc Hybrid Injectors
BTS
496 hp 985 tq!! 16 Apr 11
13.74 sec in 1/4 mile @ 98.5mph
PNWFDE#2
Diezel Dawg is offline
