WW2 vs bd billet wheel - Diesel Forum - TheDieselStop.com
post #1 of 15 (permalink) Old 06-06-2013, 11:30 PM Thread Starter
What are the differences (performance wise) between the wicked wheel 2 and the bd billet compressor wheel. If anyone has one or the other any feedback would be great, tryin to figure out which would have the best performance. Thanks in advance.
2001 F-250 Lariat, 4x4, Short bed, Supercab, Auto trans, 7.3L Powerstroke, Built trans, 6637 intake, BD billet compressor wheel, 4inch MBRP turbo back exhaust, Straight piped, Glowshift guages, PHP 6 pos. chip, Leveling kit, Rancho RS5000's, Nitto Trail Grappler 35's, N-Fab prerunner bar.
Built
Tough
Kd8324 is offline
post #2 of 15 (permalink) Old 06-07-2013, 10:01 AM
terryf350's Avatar
BD wheel
I dont know. havent seen BD or anyone do any dyno runs. Have you searched?
I am curious why you would bring this up rather than just order one with proven data?
Terry
2016 F350 Lariat Shortbed CrewCab 4x4 6.7.
B&W, Hellwig Bigwing swaybar 7271, Bedrug, Husky X Act Contour floormats. Fumoto F106N, Bullrings, Ford wheelguards.
20 Foot Cimarron Gooseneck Horse Trailer
Sold:
2003 F350XLT Shortbed CrewCab 4x4 7.3l 6 speed. 3.73 LS, 9900# GVWR Package. 333,000 miles
1991 F250XLT Supercab 4x4 7.3l E4OD 250,000 miles.
terryf350 is offline
post #3 of 15 (permalink) Old 06-07-2013, 10:16 AM Thread Starter
because the other could out perform that proven data and i was seeing if anyone knew if it would.
Built
Tough
Kd8324 is offline
post #4 of 15 (permalink) Old 06-07-2013, 11:23 AM
I have the WW2 and all I can compare it to is the stock compressor wheel. I can say it makes a big performance difference in my truck. The bottom end response is much better, the spool up is much better. You can feel the difference.
Griz
02 F250, 4X4, 4R100, 3.73, B&M Transmission Pan, Edge CTS Digital Gage, Tymar 4" Exhaust, Tymar Intake & HPX & TS 6 Position Chip. IH Bellowed Up-Pipes, RiffRaff AIH delete plug, Riffraff FRx Kit. 6.0 Transmission Cooler. Dieselsite Coolant filter & Transmission filter & 203 Thermostat & WW2 & TurboMaster & inter-cooler boots. BD CCV filter. Driven Diesel Fuel Tank Mod & Pre-Pump Filter. John Wood's valve body.
Griz is offline
post #5 of 15 (permalink) Old 06-07-2013, 12:21 PM
I second Griz's opinion. Ww2 is an awesome upgrade for a stock turbo.
02 CCLB Drw
AirAid intake, 4" exhaust, FullForce stage 1.5,
PHP Hydra with GearHead tunes, Van turbo, Wicked Wheel 2, Edge Insight CTS, Riff Raff Hrx & Frx
Injector cup tools in Lima, OH
barnhartal is offline
post #6 of 15 (permalink) Old 06-07-2013, 08:20 PM Thread Starter
But is there a noticeable difference between the bd billet wheel and the ww2
Built
Tough
Kd8324 is offline
post #7 of 15 (permalink) Old 06-07-2013, 11:03 PM
If the billet wheel spools up faster than the OEM one, I'd be interested. Driving a manual transmission, I lose boost every time I shift.
Also, I wouldn't want to leave that billet wheel bare, I'd look into getting it type II hard anodized.
2002 F-250 CCLB 4x4 XLT, 7.3, ZF-6 with Midwest Short-throw shifter, ESOF, 3.73 R&P, HPx line, FRx, Racor prefilter before pump, Amsoil bypass filter, Coolant filter too
txgp17 is offline
post #8 of 15 (permalink) Old 06-07-2013, 11:47 PM
It does spool much faster.
What do you think about your short throw shifter?
02 CCLB Drw
post #9 of 15 (permalink) Old 06-08-2013, 12:00 PM
All I can say is the WW2 is a big improvement over the stock compressor wheel. I have no experience with any other wheels so I can not answer your question.
Are you not happy with your BD compressor wheel?
Griz
Griz is offline
post #10 of 15 (permalink) Old 06-08-2013, 02:23 PM Thread Starter
Well I just got it installed not to long ago and it performs very well but i was wondering if the ww2 out performed the bd wheel becuase ever since the ww2 came out all people have said its amazing, and since I do not have any experience with the ww2 I was wondering if they were pretty closely matched or if the ww2 blew it away. And from what im hearing about the ww2 im starting to believe that the ww2 does out perform the bd wheel.
Built
Tough
Kd8324 is offline
post #11 of 15 (permalink) Old 06-08-2013, 02:29 PM Thread Starter
but the reason i bought the bd wheel instead of the ww2 was because the bd wheels blades were all the same height which i *thought* would mean it pulled more air than the mismatched height blades on the ww2.
WW2
Vs.
BD Wheel
Built
Tough
Kd8324 is offline
post #12 of 15 (permalink) Old 06-08-2013, 11:37 PM
I don't want 35 lbs of boost, I just want a moderate amount of boost real fast. I'd thought about a GTP38R with a .85 A/R housing, but they're out of my price range.
And I love the short-throw shifter, made my truck more easier and smoother to drive.
txgp17 is offline
post #13 of 15 (permalink) Old 06-09-2013, 11:00 AM
Here is what Bob Riley from Dieselsite said: "It depends on what you do with the truck. If you intend to keep stock injectors in it, youd be happier with the Wicked turbo. The bottom end response will be much better, the spool up much better. If you intend on going with larger injectors, Id go with the GTP38R."
Griz
Griz is offline
post #14 of 15 (permalink) Old 06-10-2013, 11:05 PM
I was under the impression that the WW2 was just a wheel from an earlier style turbo, and that it was actually less efficient than the OEM 99-02 compressor, but I certainly could be wrong. And I don't experience surge problems at all, if I did I'd probably opt for a ATS ported compressor housing.
txgp17 is offline
post #15 of 15 (permalink) Old 06-10-2013, 11:16 PM
The WW2 is a redesigned compressor wheel.
Griz
Griz is offline
