Your Max Boost...Really - Diesel Forum - TheDieselStop.com
post #1 of 40 (permalink) Old 04-12-2012, 06:03 PM Thread Starter
Question Your Max Boost...Really
There are a few of us (all with stock injectors but all with different, aftermarket turbos and other various mods) that have been in a discussion for a while regarding chips, turbos and max boost. We are all seeing different boost numbers that are anywhere from 24 psi to 32 psi+.
Give us a little help:
What turbo do you have?
Who's chip?
What is your max boost on your most powerful tune?
I'm not trying to start some sort of competition. I'm just interested in real numbers so we can start tracking down issues if need be.
Thanks for your input.
2000 PSD Excursion Limited owned since new, Mickey Thompson Classic II Wheels, V Code Springs Front, Modified B Code Springs Rear, Rear Hellwig Sway Bar, 3 Autometer Gauges On The Pillar, DP Tuner 40hp tow, 80hp tow, 80hp Econo, 140hp Extreme, High Idle Tune, Custom 4" exhaust and muffler, Custom Tranny with TCS 3 Disc Converter, K&N FIPK Intake, Garrett GTP38R Ball Bearing Turbo.
ColoradoEX is offline
post #2 of 40 (permalink) Old 04-13-2012, 07:09 AM
With a stock turbo and injectors - PHP tunes and boost fooler, I can hit 30 on the 140 setting. It will spike for only a second or two though. Under fairly hard acceleration, between gears, steady pressure it holds around 24.
This truck is pretty much maxed out for stock injectors and turbo. 4" turbo back - cold air. T500. Hutch/Fass/regulated return. AIH/EBPV delete. HPX/zoodad/ccv/bellowed/plenums. As mentioned above, PHP Pheonix and boost anialator.
stage3-7.3 is offline
post #3 of 40 (permalink) Old 04-13-2012, 11:23 AM
wallen's Avatar
With a 38R and DP 80 Econ i hit 29 accelerating on freeway on ramps
03 F250 Lariat 7.3 4x4 CC SB, Autometer Pyro,Boost,Trans, DP F5 80 Econ, 80 Tow, 60 Tow, Decel, 120 Race, Tymar intake, 5 in MBRP, Garrett GTP38R, Stage 1's, Terminator HPOP
wallen is offline
post #4 of 40 (permalink) Old 04-13-2012, 02:21 PM
Stock turbo, Stock injectors, DP Tuner with 80 Eco and 60 tow, both max between 23 to 25 pounds. I've never had it go any higher than that.
Steve
2000 F350 XLT PSD 4X4, 6spd, ESOF, 4.10ls, Super Cab Dually, Tow Pkg, Camper Pkg, Off Road pkg, Western Diesel Power Chip(DIED), AutoMeter EGT, Boost gauge, ITP HP oil crossover, and ITP Fuel Pressure regulated return system. DP-Tuner F5 chip with No Start, Stock, 60 Tow and 80 Economy.
2001 Polaris 500HO ATV.
sthoge is offline
post #5 of 40 (permalink) Old 04-13-2012, 02:51 PM
rammertide07's Avatar
Send a message via MSN to rammertide07
Stock injectors, stock turbo, with TS (75 & 100hp) and PHP (Mainly run 140hp) tunes...32psi
2001 F350 7.3 4x4 CC SRW/ Aeroforce Interceptor/ BD Thruster II/ Bellowed Up-Pipes/ 4" turbo back straight exhaust / CCV Mod /DIY 6637/ TS chip reburned with PHP tunes/160/stock FFD/PowerSlot rotors and green EBC pads/
/MM Hubs/Hood/HPx/FRx/
rammertide07 is offline
post #6 of 40 (permalink) Old 04-13-2012, 08:41 PM
so it looks like PHP puts out more boost than DP?
I have a non-ball bearing turnbonetics which is supposed to flow more than stock (equivilent to a 38R), stock injectors.
DP tuner, 80econo,120race 23-25lbs is most I ever got. Currently lost a few lbs and trying to figure it out.
I used to be able to set off the ses light on 120 race, but cant get enough boost anymore.
@ Rammertide; you make me miss my TS chip, but that was in a 99 F350 CC. Not sure if I would get better results than my DP. I had the original TS programming and never had high EGT's like I do now. I can't even run a qtr mile run without having to back off the throttle.
03 F350 7.3L Auto CC LB Dually 410's (LS Rear)
PHP/Beans, 1023, SDK, GH tuned/250/100 FF inj's, Irate T4 w/369SXE, Swamps HVHF IDM, BTS Tranny, Strictly Diesel complete fuel system with RR & FB delete.
Autometer Nexus Guages, 4"MBRP, DieselSite Coolant filtration system/billet housing/HP X-Over line. Donaldson Blue(6637)/AFE BHAF, RR Boots/ Billet Plenums, ('06) 26 row Tranny & PS Cooler, LarryB's Genuine Denso Starter
INFRNL is offline
post #7 of 40 (permalink) Old 04-13-2012, 09:16 PM
Sounds like your ebpv valve could be causing problems [maybe a sooted up ebps tube or bad sensor] or a boost leak.
post #8 of 40 (permalink) Old 04-14-2012, 12:33 AM
I do not want to clutter this thread with off topic info, but I am working to find the issue.
I replaced the EBP sensor a couple years ago, checked it a couple weeks ago. afaik it works and clean. tube is clean and excellent shape. tested for boost leaks and only found leaks on my plenums and fixed. no soot/leaks on exhaust that I can find. Currently have my ebpv unplugged, so it should be always opened. I can verify that it is in the open position.
I have posted in a couple spots of what I have done and working to figure it out. No luck so far.
Thanks for the recommendations though.
INFRNL is offline
post #9 of 40 (permalink) Old 04-14-2012, 12:38 AM
timmygarret's Avatar
Feedback Score: -1 reviews
stock turbo and injectors, 110hp bully dog chip..29psi on a good day.....
2000 F250 4X4 Super Duty V8 7.3L Powerstroke. 125,000 miles and counting
Extended cab Lariat, Auto. 6 position bully dog chip. Tymar intake. MBRP 4in exhaust, 6in tip. Strictly Diesel Boost Fooler, HPOPX and Riff Raff FRX, Cobalt gauges pyro, trans temp, boost. Zone 2.5in front leveling kit, Rode Master rear overload springs. Grill Guard, Mud Flaps, and Lots of LED lights!
timmygarret is offline
post #10 of 40 (permalink) Old 04-14-2012, 11:28 AM
with my mods. now only 22-26psi(dp-tuner 80 econ) With stock turbo (80 econ) 26-28psi wheel did have a little damage I noticed when the turbo was out. Now I have to watch egts going on to highway. Pedal to the floor egts get hot very quickly. I think I have a boost leak. Matt
2000 F250 crew cab long box
Banks exhaust, bighead, trancommand, boost gauge trans temp, pyrometer(post turbo)
Dp-Tuner 60& 80econ 60& 80 tow
Strictly diesel overboost annihilator
jobeperformance intake
dieselsite 203 t stat, coolant filter, evans coolant
38r with bank-bighead installed, diesel site non ebv flange international up-pipes coated, diesel site engine boot-kit, non-ebv pedestal
strictly diesel regulated fuel return kit 65psi.
new fuel bowl
CMF+ intake
isspro ev2 pyrometer(pre turbo), fuel pressure, coolant temp, HPOP gauge
1985 M1009 soon to be installed banks sidewinder turbo.
Matthew Harris is offline
post #11 of 40 (permalink) Old 04-15-2012, 12:39 PM
Supa Duty's Avatar
DP 80 econ or 120 race, 24 psi max. I am also one of those trying to find out where the boost is. I have a stock turbo with a wicked wheel, 4 inch MBRP exhaust, stock injectors, no leaks anywhere and lots of fuel pressure and ICP. My egts do not ever go over 1250, no matter how long I hold the pedal to the floor. When I had my 200 powerstroke with a Western Diesel programmer, I easily made 20-30 psi consistently with a stock turbo and injectors. My current truck has a lot more work done to it, and is not nearly as powerful.
2001 Crew Cab 4WD. Isspro Boost, Pyro and Trans gauges, custom cold air,external CCV, 4inch MBRP exhaust, Wicked Wheel, Terminator T-500 HPOP,Riffraff Diesel FRX regulated fuel return, Riffraff HPX HPOP crossover,Swamps voltage mod to IDM,Boost Fooler, PHP Hydra from Tony Wildman, Sonnax shift kit, auxiliary trans cooler, Alpine electronics.
Supa Duty is offline
post #12 of 40 (permalink) Old 04-15-2012, 02:50 PM
Stock turbo, stock injectors. I run PHP tunes, and my max boost in 80 DD, 100 Performance, and 120 Race is 24 psi.
2000 F-250 SC/SB/4x2 7.3l/ZF-6/6637/Riffraff Frx/Hpx/4" MBRP exhaust/PHP Tunes/ISSPRO EV2 gauges/Hutch mod
FSJPat is offline
post #13 of 40 (permalink) Old 04-15-2012, 03:40 PM
25-35psi, whenever you want to push the pedal down.
Turbonetics full ball-bearing turbo, ebpv delete.
AIH delete, boost regulator/bypass valve.
Custom Spearco intercooler.
EGT's 1200-1300 max (loaded or towing).
Single shot injectors (173/175)-Swamps.
Custom tunes by Jonathon (Swamps).
Tymar style intake, 4" turbo-back with hi-flow turbo outlet.
STEVE.
'08 F350 CrewCab, DRW, 4x4, Lariat, Cab/Chassis. Intake, Exhaust (delete), IDP Tunes.
Work Truck with Style!
'02 F350 CrewCab, DRW, 4X4, Lariat, 6spd. Modded to the max
200k mi.
'95 F350 SuperCab(1st Powerstroke) DRW, 5spd., XLT: Purchased New, Sep 2004;
300k mi., R.I.P. on I-80 in central PA.
'86 F350 Reg.Cab,6.9L,4X4, XLT, Cab/Chassis. 200k mi., SOLD. And still working the job w/ new owner.
RacerPuller is offline
post #14 of 40 (permalink) Old 04-16-2012, 03:20 AM
Stock turbo with wicked wheel and Big Head, stock injectors, on DP 80E 30psi and will hit 32psi on 120R. Mostly run in 60E and can hold 30psi with a load.
2000 F250 7.3L Auto. CC 4X4 Lariat SB, 3.5 Fab Tech lift, 16X10 Typhoons 305/70/16 BFG's, AFE Stage2, Banks Big Head, Banks Exhaust, Bellowed up-pipes, Quadruple gauges, Wicked Wheel, Trans Go shift kit, Eaton TrueTrac, DP-Tuner F5, Stock, 60T, 60E, 80E, 120R.
JamieWS6 is offline
post #15 of 40 (permalink) Old 04-16-2012, 01:14 PM Thread Starter
Thanks everyone, with the mods listed in my sig, I'm seeing 26-27 psi in the 140 DP Tune at sea level and at over 6500 feet (both tested this weekend). It does seem that, with a few responses, the DP tunes produce a little less boost than some others. I do like the power the truck has.
