Your Max Boost...Really - Page 3 - Diesel Forum - TheDieselStop.com
post #31 of 40 (permalink) Old 04-20-2012, 10:04 AM
ToMang07's Avatar
Send a message via Skype™ to ToMang07
Stock Turbo with OEM wheel, Wastegate unplugged and red line plugged, I hit 32psi on my 120hp "Race" tune from PHP.
With my setup in my sig, I can hit 26-27 pretty quick in any setting but stock, but the TM dumps it at 27.
02 F350 CCSB 4x4 SRW 7.3L, DIY-6637, PHP Phoenix-(STK-80dd-100P-120R-65T-40T) 4" TB-409SS MBRP, GS 3 in 1, EGT/Boost/Tranny, Fisher 8' MM2. Tymar HPX, NON-EBV Pedestal, Turbo Master, Wicked Wheel, RR-Plenums/clamps, 203*TS and Billet Housing, ELC, Fumoto, CCV Dumped, Foil, AIH, and EBV, Pontoons All Missing...~AE w/Ford Pack~
Capable of buying discounted Amsoil...
ToMang07 is offline
post #32 of 40 (permalink) Old 04-20-2012, 06:01 PM
Are you guys running stock turbos getting any surge? I can see no surge with WW, but some are fully stock with tunes. Even with me only hitting 22lbs, I can get the stock turbo to surge.
@ Stage 3: I can assure you that my bellowed up-pipes (roughly 2 yrs old IIRC) are not leaking. I even rechecked today to make sure the bolts are tight. I cannot speak for SD though. I have no soot anywhere and I definitely do not have soot where they connect to the manifolds. I pulled my manifolds to have them resurfaced and saw no soot leaking at the connection. Maybe when I do some other work, I will go ahead and pull them apart at the "y", but I am positive there are not leaking.
I did a test on my manifolds similar to boost leak test and found they still leak even after resurfacing. Going to repull them and add gaskets; if this doesn't fix them, then I will buy new manifolds. I still haven't seen my boots from RR, but hopefully those will help too; even though I cannot detect any leaks.
Sorry to get off topic, this info should be in SD's or my thread.
03 F350 7.3L Auto CC LB Dually 410's (LS Rear)
PHP/Beans, 1023, SDK, GH tuned/250/100 FF inj's, Irate T4 w/369SXE, Swamps HVHF IDM, BTS Tranny, Strictly Diesel complete fuel system with RR & FB delete.
Autometer Nexus Guages, 4"MBRP, DieselSite Coolant filtration system/billet housing/HP X-Over line. Donaldson Blue(6637)/AFE BHAF, RR Boots/ Billet Plenums, ('06) 26 row Tranny & PS Cooler, LarryB's Genuine Denso Starter
INFRNL is offline
post #33 of 40 (permalink) Old 04-22-2012, 06:57 PM
With my Tony tune on 140, ez on all the way, and the Edge all the way I hit 32 at the most. Thats with stock injectors.
2001 f250 7.3 2wd ext cab 6 speed(built by Frank) 235000mi 6" lift xd803 black wheels 35" nitto trail grapplers Tymar filter K&N intake tube 4" turbo back ss exhaust Tony Wildman burned 6pos. (stock,highidle,40hp,80hp,120hp,smoke)flip chip edge cs edge ez(given to me!!not bought) GTP38R ww foil del zoodat tuff country front bumper/with 2 6" piaa >>> Working on projector HID retrofit right now
1999 f350 7.3 duelly almost stock!!! 311000mi Tymar intake 305/70/16 Mt ALOT MORE TO COME!
DBillstein is offline
post #34 of 40 (permalink) Old 04-24-2012, 08:23 PM
Send a message via AIM to PSD POWER007
The wastegate actuator spring in stock form is VERY weak. My truck would barely make 20psi peak in stock form and hold 16-17psi steady. I could hear it start to blow open about 10-11psi. Now after shortening the arm creating more pre-load on the spring, I can make about 28psi and hold 25psi steady running the DP 80hp Econ tune. The WG now will start to blow open about 20 psi. Stock everything except banks intake, Dieselsite Boots and Magnaflow 4" turbo back. I'm thinking of getting a Big Head just for an even stronger spring pre-load.
2003 Ford Excursion Eddie Bauer 4x4 7.3L Powerstroke
BASB w/ billet wheel, DIY Tymar, Full Force 180/80's, Adrenaline HPOP, RiffRaff FRX, Magnaflow TBE, DP-Tuner F6 custom tuned, Bilstein shocks, 05 Harley HL with HID conversion, Edge Insight CS, Dieselsite BRV, Factory 20" wheels, Dieselsite turbo boots, Johnny Lightning VB, 6.0 tranny cooler
2008 Subaru WRX STI
305whp/369wtq
PSD POWER007 is offline
post #35 of 40 (permalink) Old 04-27-2012, 03:15 PM
With 140 dp tune ww bighead wastegate 6637 4" turbo back and stage 1 injectors I can hit 38psi wot and hold it in stock tune i hit 21 and thats wot
2002 Black and silver CC 4x4 F250 short bed auto xlt. Tinted windows 4" straight pipe turbo back with 7" tip. DIY Tymar intake banks big head waste gate. Triple Pillar pod with Pyro boost and tranny temp. Dp tuner stock, 20t, 60t, 80e, 140ex, low idle tune. Dp's stage 1 single shot injectors. Zoodad mod.
armyguy88 is offline
post #36 of 40 (permalink) Old 05-03-2012, 03:19 PM
I would get 25 psi with the mods in my sig when on the 80E setting. That being said, i'm only making 20 now since the turbo shaft has play in it. I'll let you guys know what i get one i get my new turbo and install it.
2000 F350 lariat, crew cab, long bed, 4x4, 3.73 limited slip
LASB turbo from Irate Diesel
Bellowed up-pipes
4" turbo back exhaust
Gauges (EGT, Trans Temp, Boost)
AFE Stage 2 XP Pro Guard 7
DP Tuner F6 (no start, stock, 80e, 60e, 60t)
AIH delete and CCV mod
F650 Dash with Carling switches
2002 Headlights with FX-R HID bi-xenon projector retrofit and 50W 5000K bulbs
53fordguy is offline
post #37 of 40 (permalink) Old 05-03-2012, 04:12 PM
This is the same as me, but I do not think I have excessive play in the impeller shaft (although I have never checked a new turbo either).
Will be interesting to see what you results are. Did you ever decide on a turbo?
INFRNL is offline
post #38 of 40 (permalink) Old 05-04-2012, 01:12 AM
I decided to go with a setup from Irate Diesel. Its a modified S300 that is done by Pius at Bell turbo. It was down to either the GQSSB of this turbo, and after doing quite a bit of research i decided to pull the trigger on this one. I'll let you guys know how things go once i get it and get it installed.
Bellowed up-pipes
post #39 of 40 (permalink) Old 11-15-2012, 06:58 PM
I can get roughly 32lbs with a superchips and some minot tweeks big head waste gate and 1.0 housing.
572ysc is offline
post #40 of 40 (permalink) Old 12-01-2012, 03:27 PM
RocDoc's Avatar
Towing 6000lbs up the grade on hwy 247 into Barstow, I can hit 26lbs with a stock 220,000 mile engine, 4" exhaust, DP 80hp flash, and AIS intake.
2000 XLT, 4x4, SC, SB, Snugtop Shell, 4" lift
4" MBRP, ISS Pro Gauges, 80hp DP-Tuner flash,
AIS w/Zoodad, 315-16's, AIH delte (boost sensor port), coolant filter.
Bangin' stereo, Randy Ellis light bar, 4-130w lights, Airbag
RocDoc is offline
