'2000 XLT Door Locks - Diesel Forum - TheDieselStop.com
 3Likes
post #1 of 20 (permalink) Old 08-30-2018, 02:36 PM Thread Starter
69mach1377's Avatar
My electric locks don't work well enough...and were not remote anyway.
1. Is there a quick repair for the stock locks?
and/or
2. Is there an upgrade available to get remote locks?
They make noise but don't lock or unlock like they used to and this is causing problems...
2000 F250 XLT 4x4 SC 7.3 w/Auto Tranny w/ TC L/U Sw & shift kit, 3 autometer gages, Super Zoodad, PHP Hydra chip, 4" DP/Exhaust w/dual 3.5" outlets, 275/70/18 Kumho AT51s on 8.5" rims, 08 AlumDiffCvr, Bilsteins, 31 row trans cooler, WW, BPV delete, AIH delete, hutch, harpoon and billet FPR (70psi), trans cooler bypass delete by accident, rear air bags, Jimmijammers.
Jayco 26BHS elite, no RV parks...just the woods if possible.
See my album for a recent pic.
69mach1377 is offline
post #2 of 20 (permalink) Old 08-30-2018, 03:59 PM
2000F250-7.3's Avatar
Sounds like the door lock actuators are worn out and need replaced. You can check rock auto or amazon for replacement.
2000 F250 7.3 4inc exhaust, Ts 6 pos chip witch custom tunes, Built 4R100 w billet triple disc converter, 6.0 trans cooler and deep tans pan, CCV mod, 4 gauge pod A piller,Boost,Trans temp,EGT,fuel pressure AFE intake,RIFFRAFF Frx fuel Rail dead head fix black spring,High Flow banjo bolts,High Flow CVD Fitting, Harpoon mod,Diesel site adrenaline HPOP,AIH Plug,Plenum Reinforcing Inserts. FULL FORCE DIESEL STAGE 1.5 single shot injectors, Garrett powermax GTP38R and blank pedestal, RIFFRAFF Intercooler CAC Boots with complete clamp kit , scanegauge 2
2000F250-7.3 is online now
post #3 of 20 (permalink) Old 08-30-2018, 04:38 PM
ArcticDriver's Avatar
I replaced mine with Autonation Ford about 3 yesrs ago.
I don’t recall Ford being much more expensive.
SOLD:
ArcticDriver is offline
post #4 of 20 (permalink) Old 08-30-2018, 11:47 PM
If you do a search, guys would pull the stock lock and had a nice fix for them. First one takes a bit after that it is not bad.
DENNY
1999 F350 AUTO 4x4 CC LB DRW 4.10
DENNY is online now
post #5 of 20 (permalink) Old 08-31-2018, 12:56 AM
Stock upgrade for remote locks.
I researched this a few months back. There is a VSM (Vehicle Security Module) box behind the radio with three plug-in connectors that require a 10-mm deep socket to access.
You typically need to get them flashed at Ford for around $120.
My notes indicate the P/N costs about $220 and is possibly: 4C7Z15604AC
***Please confirm P/N before ordering.***
This might atleast give you a direction to further search. Please let me know what you find.
https://parts.autonationfordwhitebea...em-4c7z15604ac
I hope to find a used one from a wrecker. Denver is full of guys parting them out.
But this VSM would be jn addition to your current issue of worn out actuators.
SOLD:
post #6 of 20 (permalink) Old 08-31-2018, 09:17 AM Thread Starter
69mach1377's Avatar
Thanks for all the input, I'll check into it and make a plan.
I wonder if there is an aftermarket option also?
post #7 of 20 (permalink) Old 09-01-2018, 11:01 AM Thread Starter
69mach1377's Avatar
post #8 of 20 (permalink) Old 09-01-2018, 12:14 PM
My power door locks work again. They hadn't worked in years. Once I put in the new Odyssey batteries, they started working again. I guess these batteries have so much power that the door locks work even though the actuators are weak. That was an unexpected bonus of the Odyssey batteries.
2001 F350 XLT 4X4 crew cab, dual rear wheels, long bed, black, 7.3l turbo diesel, automatic transmission, 4.10, shift on the fly, running boards, sliding rear window, 38 gal fuel tank, Odyssey extreme 65-PC1750T batteries, Michelin LTX-MS2 rear tires, Sumitomo Encounter front tires, Shell Rotella Ultra elc, 11,500 gvwr, 20,000 gcwr, 7500 gvw, completely stock, 114,000 miles when purchased, now has 240,000 miles, repairs so far: two starters, batteries, cps, brakes, tires, alternator, ball joints, locking hub, wheel hub, AC compressor, serpentine belt, power steering pump, driver's side window, ignition switch, o-ring, Spectra premium radiator, water pump, fan clutch, fan blades, thermostat, thermostat housing, tensioner. Stolen twice so far, but recovered both times with major damage.
DonWarkentin is offline
post #9 of 20 (permalink) Old 09-01-2018, 02:30 PM
Next you’re going to be telling us those AGMs regrow bald spots.
SOLD:
post #10 of 20 (permalink) Old 09-01-2018, 09:24 PM
Wink
Hadn't thought of that. Maybe I should try hooking them up to my head.
ArcticDriver likes this.
post #11 of 20 (permalink) Old 09-01-2018, 10:16 PM
That is great on the door locks. To funny on the bald spot and good luck.
post #12 of 20 (permalink) Old 09-02-2018, 10:15 AM Thread Starter
69mach1377's Avatar
Looks like the cheapest thing to do is just replace the actuators, not sure I would rebuild 18 year old plastic pieces. I called a local stereo shop who said given good actuators already, 180 to convert to keyless entry and 230 gets that and an alarm system. 70 for each actuator, all are installed prices.
post #13 of 20 (permalink) Old 09-02-2018, 10:32 AM
First actuator was a time consuming PIA. Other side was much easier...Lol
But I would gladly pay $70 for someone else to install them. I seem to recall my hands were scraped up like a feral cat attacked me.
I wonder if that aftermarket alarm system is a decent security system?
SOLD:
post #14 of 20 (permalink) Old 09-02-2018, 01:22 PM Thread Starter
69mach1377's Avatar
I'm sure I could do it myself but the video kind of discourages me, not of fan of many small parts in confined spaces.
Then the issue of getting quality actuators...been burned recently on stuff claiming to be oem but then it's not.
I'll visit them and see what they offer. What makes a decent system?
post #15 of 20 (permalink) Old 09-03-2018, 04:40 PM Thread Starter
69mach1377's Avatar
Funny how when you show up in person the price goes up...$125 per actuator now. I think I'll do it myself.
The alarm system quoted was the basic code alarm unit. It all added up to over $450.
Now to find good actuators...
  Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > 1999-2007 Upgrades and Aftermarket - General
