Added a LED Volt gauge - Diesel Forum - TheDieselStop.com
post #1 of 1 (permalink) Old 08-16-2019, 12:42 PM Thread Starter
Big Horn's Avatar
Finally got around to it. Ran a “hot all the time” fused (1A) wire to an on/off rocker switch and to the LED voltmeter. Wanted to be able to turn it off for night driving and such, but the line showed what it’s supposed to - the voltage at rest (12.4), glowplugs engaged (11.6), voltage after starting (10.5), and increasing and holding steady after glowplugs cycled off (14.0) The readout looks clean in person but really glares the image on the camera.
2002 F350 7.3L / 4R100 - 4WD CC DRW 8’ Box, AIH Delete, Gauges- Pyro, Trans Temp, Boost, Fuel Pressure, TS-6 tuner, Zoodad Mod, Mishimoto 31 row Trans cooler, Mobil 1 ATF, Trans return line ATF filter, Hutch/Harpoon Mod, Air Lift Load Lifter 5000 rear air springs, Rancho 9000 shocks, Timbrens on the front.
Big Horn is offline
  Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > 1999-2007 Upgrades and Aftermarket - General
