Adding Additional Switch for Factory Fog Lights - Diesel Forum - TheDieselStop.com
post #1 of 3 (permalink) Old 02-09-2019, 11:14 AM Thread Starter
Cool Adding Additional Switch for Factory Fog Lights
I want the ability to turn my 2001 factory fog lights on without the headlights or parking lights, yet keep the factory switch functional. I'm thinking along the line of adding a switch with a relay that will power the lights on demand. Will this cause any issues by sending power back thru the factory harness/switch?
2001 F250 CC 4x4 7.3
  • ATS Exhaust
  • Riffraff Intake
  • PHP Hydra Chip
  • 285/75R16 Toyo Open Country R/T
  • Access Bed Cover
  • 05-07 Harley Headlights with Morimoto 55w D2S 5.0 Projectors / 80mm RGB Halos / RGB Demon Eyes / Morimoto Bluetooth Controller
  • Raptor Style Grill
The Grand Pooh-Bah is offline
post #2 of 3 (permalink) Old 02-09-2019, 06:10 PM
Big Horn's Avatar
If I’m following you, the fog light switch would be turned off, through the headlight switch pull knob—so nowhere for it to back feed if your tying into the 12 v supply at the fog lights that runs along the front bumper. By all means fuse but I’m not sure why you’re using a relay unless you’re wanting to use a very small wire to trigger the relay and pick up 12v power nearer the front of the truck. Not unusual for more than one 12v Supply tied into same circuit (example: 12v bilge pump on a watercraft)- one for float switch and another for manual on/off. I recently had my fog lights out from the front of my truck (2002) but don’t remember what gage the wires were—IMO, if I was going to do it that’s where I’d tap in with a fused wire of the appropriate size/and a switch. Get some other opinions from the guys on here but see no reason why it wouldnt work. My Boat doesn’t have a computer to worry about 😉
Note: on classic cars the use of a relay is often used when upgrading to halogen headlights as the oem wiring will not handle the amp load of halogens safely- but will trigger relay off/on and then picking up a heavier gage 12v wire, supplied from a fused distribution block/battery to the relay on the power in/ and on the out providing power , which is what I’ve done on my 59
Big Horn is offline
post #3 of 3 (permalink) Old 02-09-2019, 09:29 PM
Big Horn's Avatar
Here is a 12v ampacity chart— length/amp/gage
http://assets.bluesea.com/files/reso...on_chartlg.jpg
Big Horn is offline
  Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > 1999-2007 Upgrades and Aftermarket - General
Similar Threads
Adding LED lights to the bed using the dome light switch pvdecker 1999-2007 Upgrades and Aftermarket - General 12 03-27-2014 07:41 AM
Service Manual on CD Kanman 1999-2007 General Questions 8 09-30-2005 09:35 AM
Can you wire aftermarket fog lights to factory switch? Flightnurse 1999-2007 Upgrades and Aftermarket - General 3 09-13-2005 02:06 PM
Adding Factory Fog Lights to 04 F250 sprduty04CC 1999-2007 Upgrades and Aftermarket - General 0 03-02-2005 11:22 AM
