Alarm wiring question - Diesel Forum - TheDieselStop.com
post #1 of 12 (permalink) Old 12-30-2016, 10:31 PM Thread Starter
We're trying to wire up an alarm system in my son's 2000 F250 SuperCab.
We can't seem to figure out how to wire it into the power door locks.
We've found schematics identifying the truck wiring, but can't seem to figure out how to interface the alarm wiring with the truck's.
TIA
2002 F250 CC SRW 4x4, 315/75R16, 4" exhaust
dtrojcak is offline
post #2 of 12 (permalink) Old 12-30-2016, 11:03 PM
yan7gin's Avatar
that may help you
F350 2002 7.3
auto, 37/13.5/20 open country, Bushwaker cut-out flare, Bilstein 5100, Maxtow gauges (EGT, Trans temp, Boost), 4 inch diamond eye turbo back axel drop with BTM muffler, S&B intake, RR AIH plug, billet FPR with gold spring, CNCfab Sgt 1 HPOP, CNCfab HPOP line with cross over, CNCfab 4 line fuel kit, ARP heads stud, RDP plenum reinforcing insert, complete CAC intercooler boot kit, full engine seal and gasket kit, 360* turbo rebuilt, WWII, EGPV delete, dark blue CPS, Hydra chip with SDK tunes, Polished compressor manifold, HD coolant, 203* thermostat, Transgo HD kit, Energy suspension bushing kit, front and rear diff fully rebuilt with 4:88 gear ratio, Z36 powerstop heavy hauling brake kit, headlight relay mod, Fumoto drain valve AND STICKER
F350 2008 6.4 (sold)
TT 26' Springdale 2014
7x17 enclose trailer (shop) 2012
yan7gin is offline
post #3 of 12 (permalink) Old 12-30-2016, 11:36 PM Thread Starter
I found a site that had that info, but I'm confused on how to connect the alarm to those wires.
From what I have found, Ford F-series trucks use a different type of lock system than most other vehicles.
They require an additional relay for alarms to interface with the truck.
Crutchfield sent the relay with the alarm, but didn't give instructions on how to connect the relay between the alarm and the truck.
dtrojcak is offline
post #4 of 12 (permalink) Old 12-30-2016, 11:57 PM
yan7gin's Avatar
What alarm do you have? I just install autostart on my 2002 and it came with 1 relay witch was for the starter killer. the rest was only to tap into the oem wiring
F350 2002 7.3
yan7gin is offline
post #5 of 12 (permalink) Old 12-31-2016, 12:48 AM Thread Starter
CodeAlarm CA1153
Crutchfield sent a 451M relay module with it, but the instructions are confusing me.
Apparently, F-series trucks require this extra relay.
dtrojcak is offline
post #6 of 12 (permalink) Old 12-31-2016, 01:35 AM
yan7gin's Avatar
Is you kit look like the one in the pic? if so the relay should be for the starter killer and just tap the right wire into the doors wire. I'll have a look into the manual tomorrow see if I can help more
F350 2002 7.3
yan7gin is offline
post #7 of 12 (permalink) Old 12-31-2016, 07:16 AM Thread Starter
Yes it looks like that.
I have the starter relay.
Crutchfield sent an additional relay as well, a 451M relay.
Apparently these trucks have an oddball locking mechanism and require the extra relay.
dtrojcak is offline
post #8 of 12 (permalink) Old 12-31-2016, 01:59 PM
yan7gin's Avatar
I look quickly this morning and yes you need that relay to switch the polarity. your alarm will activate the doors lock with the (-) and our doors lock are (+) activated. So you need to switch the signal from (-) to (+)
you could also make your own using 2 relay
F350 2002 7.3
yan7gin is offline
post #9 of 12 (permalink) Old 01-01-2017, 01:29 AM Thread Starter
So I need to cut the wires between the switch and lock, and connect this relay to the cut wires?
dtrojcak is offline
post #10 of 12 (permalink) Old 01-01-2017, 02:30 PM
yan7gin's Avatar
I'm no sure how your new relay is wired and i'm on my phone right now. Will dig abit later when i get home. But you should be able to jut tap into the wire that as your lock or unlock signal. Not between the switch and lock but before the switch. All my wire where located close to the steering column. If i recall the wire that i use is the one coming out of my vsm but you have an 01 so no vsm. Maybe coming out of your gem? Don't remember if the gem controls doors lock.... ill have a look later
Sent from AutoGuide.com Free App
F350 2002 7.3
yan7gin is offline
post #11 of 12 (permalink) Old 01-01-2017, 03:42 PM
yan7gin's Avatar
POWER LOCK PINK/YELLOW (TYPE C), See NOTE #2 See NOTE #2
POWER UNLOCK PINK/LIGHT GREEN (TYPE C), See NOTE #2 See NOTE #2
Vehicles with FACTORY KEYLESS ENTRY are a TYPE "B" Door locking system, wire are located in a GREY Molex plug on the RIGHT side of the Steering column, vehicles without FACTORY KEYLESS are a TYPE "C" Door locking system, when doing TYPE C Locks, use the DRIVERS side SWITCH when TESTING. Wires are located in the DRIVERS DOOR HARNESS.
F350 2002 7.3
yan7gin is offline
post #12 of 12 (permalink) Old 01-04-2017, 12:04 PM
I think I used Schotch lock taps when I did my Ford OEM auto start alarm 10 years ago. It is hard to remember that far back, but I think I tapped in right before the wire went through the tube to the door??
2006 F250 Lariat Supercrew, ESOF 4x4, 18" tires, FX 4, HD Alt., block heater, Integrated Trailer Brake Controller, Upfitters, power rear window, cab lights - delivered 10/25/05
Ford Remote Start; High idle mod; Timbren load levelers, Scangauge II, Blue Spring upgrade, Quick Start 200 amp large frame alternator, 2 batteries January 2010; GPCM replace October 2011; 2 EGR valves; EGR Cooler replaced 12/30/11; Performance Machine & Mfg. coolant filter added 1/2/12; Rotella T6 5W40 oil; turned rotors, replaced brake pads for 1st time 1/7/12 101K miles; GPCM, both subharnesses and all 8 glowplugs replaced 1/5/13 at 118,000 miles; 2 Ford batteries replaced under battery warranty twice, the latest 9/18/2015; FICM power supply board replaced with Dorman board 11/20/13. Coolant flushed and replaced with Prestone ELC 9/27/14. STC fitting 10/19/14; Dummy Plugs 11/8/14; Turbo rebuilt 11/29/14; cold side CAC tube and boots replaced with metal tube 1/24/15; replaced hot side boots 1/30/16.
Ford06 is offline
  Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > 1999-2007 Upgrades and Aftermarket - General
