android phone app for gauges - Diesel Forum - TheDieselStop.com
post #1 of 10 (permalink) Old 09-08-2019, 03:47 PM Thread Starter
Not sure if I'm asking in correct forum. I did a search but no recent postings. I'm looking to get some kind of app that is like the torque pro, to read my early 1999 E350 (van) Is the Torque Pro the best deal going or is there better ones for the buck? And do they show more sensors now? Will I be able to get all parameters? such as fuel pressure? Tranny temp? LPOP ? HPOP? EOT ? ECT? etc...
Also are some more user friendly than others?
1999 E350 7.3psd , XLT , 15 pass/ext , purchased 6/6/05 w/255k on odo, 8/05 added BTM/straight pipe,5/06 BTS,1"shimmed front coil springs,Michelin XPS 235/85 16 R.,FredGroeske2"rear wheel spacers,1-1/2" rear sway bar,AIC,3 A-pillar guages, Tekonsha envoy,coolant filter,4 pos dp-tuner,In-tank mod & harpooned,dahl-100 prepumpfilter,Scan-guage,Bilstein shocks.
bork is offline
post #2 of 10 (permalink) Old 09-10-2019, 12:52 PM Thread Starter
No one? using these?
bork is offline
post #3 of 10 (permalink) Old 09-10-2019, 01:37 PM
JJEdwards's Avatar
I use the Torque app. Don't have experience with any others. I also use a laptop, Forscan and an OBD2 cable to check other parameters that Torque can't.
2000 7.3 PSD 4x4 Auto Trans., CC, short box 207,500 miles.
PHP Hydra, Bilstein 5100's, Bilstein steering stabilizers, Auto Meter 3 gauge pod--EGT, Trans Temp & Boost, Deep Trans Pan, Rotella ELC and T6 oil, DieselSite 203*, Riffraff Billet wheel, 4" turbo back MBRP 5" straight pipe, Donaldson 6637 blue, 20" Fuel wheels wrapped with 37" MT's
Security: Ravelco (for the pro's), Viper (for the rookies), The Club 1100 Steering Wheel Lock (visual deterrent).
JJEdwards is offline
post #4 of 10 (permalink) Old 09-10-2019, 01:38 PM
JJEdwards's Avatar
The Scangauge 2 is in the near future.
post #5 of 10 (permalink) Old 09-10-2019, 07:29 PM Thread Starter
Have a scan gauge original . Not enough info? What does your torque pro not show?
bork is offline
post #6 of 10 (permalink) Old 09-10-2019, 07:51 PM
jleedog's Avatar
Scangauge 2 will give you EOT and Trans temp, but can not give you ECT and fuel pressure because there is no sending unit for those. So you would need to use a gauge and install a sending unit because IIRC the ECM does not read for those so a OBD app will not work for those parameters. HPOP and LPOP I am not sure about.
2002 F250 Super Duty Crew Cab 7.3L Lariat 2WD 131,000mi; 4in turbo back custom exhaust, Garrett GTP38R turbo, Riffraff intercooler boots, Dorman Up-Pipes, Ford Severe Duty AIS, 31 row 6.0 transmission cooler, Scangauge II, ISSPRO EV2 Boost-EGT-Trans temp-Fuel pressure Gauges, DP T-5 Tuner (stock ,60HP tow, Decel, 60HP highway econo, 80HP city econo), Dieselsite coolant filtration, Max Air A/C mod, foglight mod, AIH delete, LED interior, back up camera, hid foglights.
I have AE if you are in San Diego area and need help. Send PM
jleedog is offline
post #7 of 10 (permalink) Old 09-10-2019, 08:31 PM Thread Starter
OK, thanks, thats what I need to hear. Does the Torque Pro show LPOP & HPOP ?
bork is offline
post #8 of 10 (permalink) Old 09-10-2019, 08:49 PM
jleedog's Avatar
HPOP and ICP are the same I think. LPOP does not have a sending unit if I remember correctly. Scan gauge 2 will read ICP and IPR. and much more.
jleedog is offline
post #9 of 10 (permalink) Old 09-10-2019, 09:29 PM
Andrew G's Avatar
Here's the Scangauge page listing the xgauges for our trucks. Some of the general Ford / Lincoln gauges work, but there is also a list of 7.3 specific xgauges further down the page. Some things can't be done, like jleedog said. You need to install senders and separate gauges for LPOP, Coolant, and EGT.
https://www.scangauge.com/support/x-...ncoln-mercury/
99.5 F250 7.3 PSD Supercab Shortbed 4x4 on 315 75 16s
Front leveling springs, Hutch and Harpoon mods, A pillar 3 gauge pod with DiPricol Trans, Boost and EGT, Scangauge II, CNC Fab HPOP and HPX lines, Riffraff FRX, 2004 Heated and Lighted mirrors
Andrew G is offline
post #10 of 10 (permalink) Old 09-10-2019, 11:15 PM Thread Starter
Andrew G, thanks, good info. I'll have to figure what version I have & maybe mail back for the upgrade.
bork is offline
  Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > 1999-2007 Upgrades and Aftermarket - General
