Backup camera for 2001 XLT - Diesel Forum - TheDieselStop.com
 1Likes
  • 1 Post By 350sd
post #1 of 11 (permalink) Old 08-21-2019, 04:27 PM Thread Starter
I need to have a backup camera for a couple of reasons. 1) I keep hitting things when I back up, and 2) I pull trailers and one would be useful in hitching up and keeping me from jackknifing the trailer.
Need one with a video screen, that's very weatherproof, and doesn't cost over $100.
Any suggestions?
vineyridge is offline
post #2 of 11 (permalink) Old 08-21-2019, 06:12 PM
Big Horn's Avatar
It’s on my list of upgrades as well, though I’ve been looking at name brands in the $275 - $300 range. I just did a google search (back up camera double din radio) and there were a couple (not name brand- Chinese?) sold by Wally World in the 100$ range but not sure about their quality. Maybe someone has bought one of the low end brands that they can give a review on.
2002 F350 7.3L / 4R100 - 4WD CC DRW 8 Box, AIH Delete, Gauges- Pyro, Trans Temp, Boost, Fuel Pressure, TS-6 tuner, Zoodad Mod, Mishimoto 31 row Trans cooler, Mobil 1 ATF, Trans return line ATF filter, Hutch/Harpoon Mod, Air Lift Load Lifter 5000 rear air springs, Rancho 9000 shocks, Timbrens on the front.
Big Horn is offline
post #3 of 11 (permalink) Old 08-21-2019, 06:44 PM
I have been looking at a rear cab light camera AND a rear hitch camera. I would like to mount a monitor between the visors on the headliner. With two cameras I can check the load anytime while I am driving. I have not installed anything yet because I am not sure how to mount anything on the headliner.
2002 F350 7.3 psd supercab dually 2wd, AIS, Moog joints, Bilstein, Michelin Defender LTX, Dieselsite coolant filter, red ELC, prepump spin-on fuel filter, 260,000 miles, hutch/harpoon mod, marinco mod, scan gauge ll, Zoodad, Dieselsite boots, pedestal delete, CNC Fab w/ crossover oil lines, 6.0 trans cooler, replaced oil pan, Walker BTM, Denso starter, bellowed up pipes, rebuilt oil cooler, billet dip stick adapter, HD glow plug relay
1974 CJ6 ... off the frame needs work
2013 Expedition... wife's car
Panhead ... 53 motor, 51 tanks, B grind cam, S&S carb, points, drum brakes ... It doesn't just sit in the garage
panhead george is offline
post #4 of 11 (permalink) Old 08-21-2019, 07:39 PM Thread Starter
I just found this on Amazon and think I will save up for it. You can have as many as four cameras going at the same time. That means I could have one on the back of the trailers, one inside the horse trailer (maybe), and one for the truck. The extra cameras are not cheap, though.
It gets incredibly good reviews on Amazon, but I haven't yet checked for independent reviews.
post #5 of 11 (permalink) Old 08-22-2019, 01:39 AM
ck out Brandmotion.com I have used them & have no complaints @ all 1 on my 2008 f-350 & 1 on my 2012 jeep wrangler both work great. you need to be sure with the cheaper 1 out there you end up replacing them more then once & in turn you spend more in $ & x
pitstop likes this.
2014 F-350 XLT 4x4 6.2L, SILVER, AUTO TINTED/W, BURLWOOD DASH FROM A LARIAT, FORD NAV-SYNC,AFTER MARKET DUAL BATTERY,EXTRA HEAVY DUTY ALTE, 275/75/65R18 BFG/A/T ON CAST ALUM WHLS,READY LIFT 2.5" FRONT 5" REAR,HEWLING REAR SWAYBAR, 7.5'FISHERM/M, SILVER/MT WITH BLK PINSTRIPE,new carbon fiber AIC covers
350sd is offline
post #6 of 11 (permalink) Old 08-22-2019, 04:16 PM
Tazzman's Avatar
I installed the Hopkins Smart Hitch Camera and Sensor System. might not be the bast, but it works good has two settings one for backing up / and the hitch for trailer.
just have to be careful as it is license plate frame mounted.
Tazzman is offline
post #7 of 11 (permalink) Old 09-24-2019, 06:58 PM
pitstop's Avatar
Looking for a good one as well for wife's truck. I'll work on it right after I finished installing the new brake kit and atv wheels on the current TRX project. Read some review about brandmotion and they seems to have good stuff.
pitstop is offline
post #8 of 11 (permalink) Old 09-30-2019, 09:13 PM
100 bucks is a pretty low threshold, but thats what I did. Don't mess with the cheap wireless junk, wire it in regardless. If you intend to dash mount the monitor, especially a cheap one, one has to protect it from extreme heat, so get a sun screen for when you park or the monitor won't last. I had to put a camera on my F250 after back surgery, I can't twist and look anymore and was backing into trash cans and mail boxes. Cant get by safely without it now.
2002 F250 7.3L PSD, bought new now at 226K miles, 4R100 Auto, Crew Cab, Short Bed, ITP Regulated Fuel Return system, ITP head to head SS oil cross over, Hutch in tank mod
Harpoon de tank vent, DIESELSITE Dahl 100 Pre-Pump Fuel Filter, DIESELSITE Return Fuel Line Cooler, DIESELSITE Engine Coolant Filter, DIESELSITE Auxilliary Transmission Cooler, DIESELSITE Gage Package, Pyro, Trans & Boost, Extreme Diesel AD injectors, Ford AIS Air Filter System, BTM straight through muffler, Moog Ball Joints, Rancho Shocks, Rotella ELC Coolant ,Stock Engine Program
Modified for I-Pod Connection
We b playing Scotland The Brave to Jimmy Hendrix
Oneof6 is offline
post #9 of 11 (permalink) Old 10-09-2019, 07:18 PM
meteor56's Avatar
Back in July I picked up a wireless, solar powered backup camera off the WalMart clearance table for $49. It was marked down from $139. It's a license plate frame mount for the camera, and windshield mount for the controller/screen. So far it works great. Makes it incredibly easy to hook up to the utility trailer. I don't need it for the 5th wheel. The signal range (33') almost let me put it on the back of the 5th wheel; that would have been great for trailer backing.
You do need supplemental lighting at night.
meteor56 is offline
post #10 of 11 (permalink) Old Today, 09:31 PM
losfinch's Avatar
I bought a real good camera on Amazon for about $20 (later found out that my son't police force cars all use the same camera). I then purchased a 7" video playback screen for about $20 as well. I purchased cable to extend the cameras cable and hooked it into my truck's wiring so that it turns on automatically when I shift into reverse. I also have it wire to a switch so that I can turn it on manually at anytime. So, I think I have about $75 into the whole setup and I've been using it for about 8 years now. It works great. The screen I mounted above my rearview mirror.
Early 99 F350 4X4 CC 7.3 Auto. A.R.E. Topper, bed carpet/bench inserts, Rhino grill guard, AIS w/sleeve, Fuel filler mod, GOS headlight harness, 02-04 Headlights, Rancho HD stabilizer, 06 Telescoping/heated mirrors with C-Btr Mirrors, Hella FF1000, Htr Bypass valve, front receiver hitch, Quadzilla XZT gauges, ITP Pre-pump/In-tank mods, Pioneer P5000UB w/XM radio, 4 Infinity Kappa 682.7cf, Fumoto valve, FIAMM Highway blaster horns, SS HPX, IDM mod, DP F5 (Stock,Drive-thru,60T,80E,120,80E-Mountain,1200), Walker BTM, RR, Dieselsite BRV, BTS Tranny (2nd one :-), 31 row tranny cooler, Bilstein shocks, Amsoil bypass oil filter, Stancor HD Glow Plug Relay, billet thermostat housing, front & rear parking cameras, Aux reverse lights, Heated Seats.
Security: CrimeGuard Alarm with remote notification, DIY jimmi-jammers, door cylinder locks and linkage removed, padlocked rear bench seat hinge, PCM, DIY "pitstop" switch.
losfinch is online now
post #11 of 11 (permalink) Old Today, 09:32 PM
losfinch's Avatar
I bought a real good camera on Amazon for about $20 (later found out that my son's police force cars all use the same camera). I then purchased a 7" video playback screen for about $20 as well. I purchased cable to extend the cameras cable and hooked it into my truck's wiring so that it turns on automatically when I shift into reverse. I also have it wire to a switch so that I can turn it on manually at anytime. So, I think I have about $75 into the whole setup and I've been using it for about 8 years now. It works great. The screen I mounted above my rearview mirror.
  Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > 1999-2007 Upgrades and Aftermarket - General
