Best “performance” muffler to tame the sound of a 4-inch straight pipe? - Diesel Forum - TheDieselStop.com
post #1 of 13 (permalink) Old 07-30-2019, 09:23 AM Thread Starter
iqraceworks's Avatar
Question Best “performance” muffler to tame the sound of a 4-inch straight pipe?
When I bought my 05’ F250 a few year ago, the guy had put a 4” turbo-back straight pipe exhaust on it. It’s a little noisy if you really get on the gas hard, but when you are just cruising around town or down the highway, except for the nice whistle sound…..it’s actually pretty quiet.
But…when I’m towing my camper with my family in the truck, it can get really loud when I’m getting on the gas hard pulling up hills, and stuff that actually requires some power. Anything over 2,500rpms just gets stupid loud….it’s annoying as hell on long 10+ hour road trips.
Is there a muffler I can put in the system that would kill a little bit of that wide open throttle volume, but not get rid of the whistle, or kill the exhaust flow?
If it’s on a 10 now, I would like to dial it back down to a 7…..
2005 F250 6.0 PSD, ARP Studs, Felpro HG's, EGR Delete, IPR Coolant Filter, Bilstein 5100s, Blue Spring Mod, IDP Custom Tunes
iqraceworks is offline
post #2 of 13 (permalink) Old 07-31-2019, 02:22 AM
a freeflow muffler would probably give you what you are looking for.
MBRP has a good muffler
Walker
and there is another that i have seen people use but can't recall the name. it's aero something I believe
03 F350 7.3L Auto CC LB Dually 410's (LS Rear)
PHP/Beans, 1023, SDK, GH tuned/250/100 FF inj's, Irate T4 w/369SXE, Swamps HVHF IDM, BTS Tranny, Strictly Diesel complete fuel system with RR & FB delete.
Autometer Nexus Guages, 4"MBRP, DieselSite Coolant filtration system/billet housing/HP X-Over line. Donaldson Blue(6637)/AFE BHAF, RR Boots/ Billet Plenums, ('06) 26 row Tranny & PS Cooler, LarryB's Genuine Denso Starter
INFRNL is offline
post #3 of 13 (permalink) Old 07-31-2019, 06:55 AM Thread Starter
Just ordered one of the 4" x 30" FTE spiral resonators. I'll have to take a before and after video this weekend when I put it on the truck.
post #4 of 13 (permalink) Old 07-31-2019, 09:33 AM
Big Horn's Avatar
It’s been recommended a lot on TDS and what I put on mine: You can find a lot of previous old posts on this using search word: “Walker BTM”
2002 F350 7.3L / 4R100 - 4WD CC DRW 8’ Box, AIH Delete, Gauges- Pyro, Trans Temp, Boost, Fuel Pressure, TS-6 tuner, Zoodad Mod, Mishimoto 31 row Trans cooler, Mobil 1 ATF, Trans return line ATF filter, Hutch/Harpoon Mod, Air Lift Load Lifter 5000 rear air springs, Rancho 9000 shocks, Timbrens on the front.
Big Horn is offline
post #5 of 13 (permalink) Old 07-31-2019, 02:57 PM
ArcticDriver's Avatar
+1 on the BTM (Big Truck Muffler).
NAPA also sells this under their label for just a bit more.
It cleans up the sound of the exhaust and actually lets me hear my turbo spool better.
I have a 3.5”.
SOLD:
ArcticDriver is offline
post #6 of 13 (permalink) Old 07-31-2019, 05:10 PM
https://puredieselpower.com/products...ler-21471.html
Here's the link for the 4" Walker big truck muffler. $109
DonWarkentin is offline
post #7 of 13 (permalink) Old 08-01-2019, 09:59 AM
Won’t a spiral resinator create higher EGT?
The BTM is a straight-thru design.
SOLD:
post #8 of 13 (permalink) Old 08-01-2019, 03:07 PM
https://www.ftediesel.com/store/pc/v...p?idproduct=24
FTE claims that their spiral resonator will not create higher EGT.
If you prefer the BTM, it is available on Amazon for slightly less ($109.75 for FTE spiral resonator, $91.78 for BTM on amazon).
post #9 of 13 (permalink) Old 08-01-2019, 06:32 PM
Don,
Thats very kind that you do all the legwork on pricing and vendors.
Interesting about it not increasing EGT.
SOLD:
post #10 of 13 (permalink) Old 08-01-2019, 09:20 PM
Here's what FTE says, "No gain in EGT or reduction in flow" https://www.ftediesel.com/store/pc/v...6&idcategory=7
However, previously they said, "There is very little backpressure, no significant egt gain, and the noise cancellation properties are awesome." https://www.cumminsforum.com/forum/f...available.html
So I guess there is either no gain in EGT or no significant egt gain.
post #11 of 13 (permalink) Old 08-03-2019, 09:45 PM Thread Starter
Well, I installed the new 4" x 30" FTE resonator. It did exactly what I wanted it to do....I couldn't be more happier with it. It got rid of that obnoxious "bark" when I was really hard on the gas. I can still hear the exhaust, it's just smoother now....quieter, and not so annoying. At idle, I can still here the turbo whistling....but I don't have as much as that annoying "hairdryer" type sound. It just took everything down at notch. The microphone on my camera is pretty crummy, it doesn't sound like it did much of anything in the videos....but in person, it's night and day.
I can't wait to tow something heavy.....I'm looking forward to being able to get on the throttle hard, without so much annoying volume coming out of the exhaust.
I'm working on editing the videos I took and putting them together....I just might not have time to do it tonight, it's going to take a little bit of time.
post #12 of 13 (permalink) Old 08-13-2019, 12:26 PM Thread Starter
Just a little update......
Got to tow the boat (6,000lbs) this weekend. Man, it's so nice being able to carry on a conversation while pulling up a long hill when you are hard on the throttle No more....BRRRAAAAAAAAAAA!!!!! from the 4" straight pipe. Reply
I can still hear the turbo whistling pretty good with the windows down, but when you get on the throttle........it's sooooo much better. It's louder than a stock truck, but just not annoying as hell anymore. I wish I would have done that as soon as I bought the truck a few years ago!
post #13 of 13 (permalink) Old 08-13-2019, 03:46 PM
Thats great !
Any chance you watch your EGT before and after...just out of curiosity.
SOLD:
  Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > 1999-2007 Upgrades and Aftermarket - General
