Cab lights: OEM or aftermarket?? - Diesel Forum - TheDieselStop.com
 4Likes
post #1 of 22 (permalink) Old 12-05-2016, 03:49 PM Thread Starter
Thinking about adding roof lamps, what are the thoughts from those who have done so?!
Sent from AutoGuide.com Free App
2001 Lariat, F250, 7.3, 6-speed, 3:73, Ford AIS, MBRP 4" turbo back, ATS ported housing, 205 t-stat, Infinity DX w/DP Tuner 80hp tow, coolant filter, Hutched & Harpooned, EGT & Boost gauge. Fuel Mavericks with 285/18, 86k miles(Jan-2017) Bought brand new April 2001.
aclasshog is offline
post #2 of 22 (permalink) Old 12-06-2016, 01:18 PM
I installed after market smoked LED lights on my cab several years ago. They are still going strong. On the after market lights the holes that need to be drilled are very small.
aclasshog likes this.
2002 Ford F-250, 4WD, Line X, Bearcat 880 In Dash CB, Billet antenna, Ventvisors, Dash Cam, RX65
12/03/02 Oil Leak Fixed 7,776 miles
01/02/03 Dead Alternator 8,789 miles
05/24/04 Pwr Steer Hose & Blink Air Bag 35,450
06/03/04 Blink air Bag, No Cruise
01/24/05 Crankshaft Seal 50,424
07/07/06 Pwr Steer Hose 78,764 miles
7/24/07 Drag Link 93,000
08/31/07 Rebuilt Tranny 95,000
11/26/07 Leaking Tranny fluid 99,500
11/12/08 Turned front rotors to get rid of pulsation
09/30/09 Greased slip yoke to get rid of slip
09/30/09 CPS Recall
10/5/09 Driver's side hub went out
2/4/2010 Pass side hub went out
7/22/10 Air Conditioning Compressor went out
7/8/13 Carrier Bearing
12/23/13 Fuel Drain Valve
9/29/14 Idler Pulley
01/4/15 GPR
08/01/15 New Glow Plugs
07/07/16 Up Pipes
08/30/16 New Batteries
241,000 troublesome miles
HoustonStroker is offline
post #3 of 22 (permalink) Old 12-06-2016, 04:47 PM Thread Starter
Rumor has it that since my truck is a lariat, it wont have the factory plug in the passenger side panel. Do you know this to be a fact? I've been trying to find a picture or youtube of the so called plug.
Thanks for the response.
post #4 of 22 (permalink) Old 12-07-2016, 10:21 AM Thread Starter
How much do cab lights affect your overhead clearance? especially on a standard 7ft garage door. Can anybody look at thiers and guess how much further they stick up from the cab?
post #5 of 22 (permalink) Old 12-09-2016, 12:10 AM
I'm curious also about the overhead clearance as I'm planning to buy Recon cab lights.
karlduke is offline
post #6 of 22 (permalink) Old 12-12-2016, 07:49 AM Thread Starter
I'll let you know karlduke, I ordered a set of OEM lights and will be installing soon. I'm more worried about getting them sealed up than anything else.
post #7 of 22 (permalink) Old 12-13-2016, 05:43 AM
Ponce3's Avatar
I went the cheap route and got them from Harbor Freight for $12. I actually bought 2 sets just to have spares
Ponce3 is offline
post #8 of 22 (permalink) Old 12-13-2016, 06:36 AM Thread Starter
How was your install Ponce3? any gotchas or pointers?
post #9 of 22 (permalink) Old 12-13-2016, 08:13 AM
Ponce3's Avatar
Went pretty good. drilling that first hole is the hardest part. lol Measure three times. use painters tape on top to protect and make your marks. Have a shop vac nearby to get rid of those shavings on the roof asap. Do a search. Alot of writeups and videos out there. I just tapped into the headlight switch wiring so they come on with the lights. The kit grounds through one of the screws for each light so theres only 1 wire to run. Use silicone in the holes for added insurance from water infiltration. Pretty easy really.
2002 F-250 Lariat, 7.3 PSD, 4x4 Crew Cab, Auto
8" BDS Lift, Fox 2.0 Shocks, PHP Hydra Chip, 4" Exhaust, GlowShift Gauges, AMP Research PowerSteps, 375/65r16 MT Baja MTZ's, 16x10 ION Alloy 171's
Ponce3 is offline
post #10 of 22 (permalink) Old 12-17-2016, 06:01 PM Thread Starter
Cab lights: OEM or aftermarket??-imageuploadedbyag-free1482019257.254821.jpg
Can anyone bail me out before I ruin a perfectly good truck? I think I am going to sleep on it tonight before drilling the holes.
post #11 of 22 (permalink) Old 12-17-2016, 07:21 PM
Ponce3's Avatar
Middle one should be in the center. next 2 out should be 8" from center. Outer 2 should be 13" further. Make sure your front holes will clear the support beam underneath. When you drop the headliner you'll see it. Heres a good write up. F250 Factory Clearance Light install
Ộ ----- 13"----- Ộ --8"-- Ộ --8"-- Ộ ----- 13" -----Ộ
Ponce3 is offline
post #12 of 22 (permalink) Old 12-17-2016, 07:24 PM
Ponce3's Avatar
Looks good in the pic. I eyeballed mine after measuring. Look at it from different angles on the ground.
Ponce3 is offline
post #13 of 22 (permalink) Old 12-17-2016, 07:31 PM Thread Starter
Ponce, did you drill your holes 5.5" from the windshield seal? Looks like that will clear the support without any problem but I wasnt sure if the 5.5 was from the tip of the cab light or the center for drilling. Thanks for the link, I'm reading a bunch of them tonight.
post #14 of 22 (permalink) Old 12-17-2016, 07:37 PM
Ponce3's Avatar
Depends on which ones youre using.
Ponce3 is offline
post #15 of 22 (permalink) Old 12-17-2016, 07:51 PM
Ponce3's Avatar
Ponce3 is offline
  Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > 1999-2007 Upgrades and Aftermarket - General
