KYB Monomax or Bilstein? - Page 2 - Diesel Forum - TheDieselStop.com
 7Likes
post #16 of 29 (permalink) Old 02-06-2019, 08:09 PM Thread Starter
Good idea but while I have the Monomax for all four corners, I only have the Bilstein 4600's for the front.
Having the Bilsteins and Monomax both in hand, here's a unscientific and maybe meaningless comparison.
When I compare the front Bilstein to the front Monomax and
1) compress both shocks slowly from fully extended to fully compressed, the Monomaxs are much, much harder to compress.
2) compress both shocks suddenly, as in dumping 200lbs on them in about a tenth of a second, the Monomaxs just don't react/compress much; the Bilsteins react and compress fairly quickly and moderately easily.
I wonder if that means anything?
Originally Posted by Logophore View Post
Hey if ur that ocd, and you have both, run that set backwards a while then switch it to how you think it will be good (kyb back, bilstein front) and report the difference here. You wanted an in depth answer, and couldnt find it, so give the next guy more info than you have! This thread is long enough that it will return as a search result for anyone else wanting the comparison. Good luck!
Sent from my moto g(6) play using Tapatalk
1999 F350 DRW Long Bed Crew Cab 4x4
Carries 5000lb+ Lance Camper
DP Tuner chip w/ 60econ, 120race, decel, hi idle
Stancor Glow Plug Relay
VDO gauges
Ford AIS and zoodad mod
MagnaFlow 4" Exhaust and muffler
Bellowed Up Pipes from Int'l
John Wood Eco HD trans, 6.0 cooler and Maghytec tranny pan
Maghytec rear diff cover w/ Mobil 1 75W-140
Mobil 1 ATF in trans/transfer case/powersteering Magnafine filters for tranny and power steering
Airbags, KYB Monomax shocks, Torklift Swaystops, Roadmaster 1.5" Rear Sway Bar
CCV mod
TransferFlow 57 gallon fuel tank
Riffraff fuel and oil crossover
Strictly Diesel fuel tank/pre-pump kit
Air intake heater delete Max A/C assist Braided 4WD shift hoses, Replacement boots for all turbo/intercooler boots, Coolant filtration system, 203*F thermostat
2 layers Dynamat Extreme on interior roof/floor/doors, Dynamat Xorb on Firewall
Alpine IVA1000 and amp, Python Alarm
farnorthdriver is offline
post #17 of 29 (permalink) Old 02-06-2019, 11:22 PM
Not sure u can test them by hand... I think they behave very very differently under a thousand lbs of force on a washboard road when the shock is getting hit maybe 20 times a second... That being said let us know how u like them! Ive got an 02 7.3 ccsb with a 60 gallon aux tank in the back and pull a heavy 5th so id love to hear your experience
ArcticDriver likes this.
Logophore is offline
post #18 of 29 (permalink) Old 02-07-2019, 12:20 PM
Actually, what you have is even better than what he suggested.
Run the Monomax on all four corners for a month. Then switch the fronts to Bilstein 4600's and run them for a month while you leave the Monomax on the rears. Then let us know which way you like better.
DonWarkentin is offline
post #19 of 29 (permalink) Old 02-07-2019, 05:42 PM
ArcticDriver's Avatar
And if you don’t mind, buy a pair of 5100s and then run those up front after the 4600s.
It will help abate your OCA...and mine.
NOS Black CPS. ScanGauge-II. Bilstein 5100. Stancor GPR. Walker BTM. Noco Mod. Michelin Defender LTX 285/75/16.
SOLD:
ArcticDriver is offline
post #20 of 29 (permalink) Old 02-07-2019, 09:21 PM
jleedog's Avatar
After you are all done testing, you can sell me the ones you don't like. For a discount of course, after all, they are used. Im thinking at least 50% off sticker price.
meteor56 likes this.
2002 F250 Super Duty Crew Cab 7.3L Lariat 2WD 131,000mi; 4in turbo back custom exhaust, Garrett GTP38R turbo, Riffraff intercooler boots, Dorman Up-Pipes, Ford Severe Duty AIS, 31 row 6.0 transmission cooler, Scangauge II, ISSPRO EV2 Boost-EGT-Trans temp-Fuel pressure Gauges, DP T-5 Tuner (stock ,60HP tow, Decel, 60HP highway econo, 80HP city econo), Dieselsite coolant filtration, Max Air A/C mod, foglight mod, AIH delete, LED interior, back up camera, hid foglights.
I have AE if you are in San Diego area and need help. Send PM
jleedog is offline
post #21 of 29 (permalink) Old 03-06-2019, 09:39 PM Thread Starter
OK, finally reporting back on my shock experience. Got tied up with work and travel for a while and recently only got around to finishing other items on the truck and getting it out for a test drive.
I've got the KYB Monomaxs on all four corners and it drives noticeably different than the previous Rancho 9000XL's. --The Ranchos had a total of 30,000 miles on them when they came off the truck and all 4 were set to position 9 and came off in good shape.
My perception is the ride with the Monomax is stiffer (in a good way) and more controlled than the Ranchos 9000XL's. Whether they stay this way remains to be seen (In my large amount of research on the Monomax, found a few comments of them being too stiff initially and then getting better). The only additional comment (speculation) I can provide is that possibly if you're not constantly carrying the 5000lb+ load in the bed that I am, maybe the Monomax's would be too stiff. ??
Due to time and other issues (wrenching burnout) I did not put the Bilstein 4600's on the front and then try to compare them to the Monomaxes. I can say from examining the two (Bilstein 4600 and KYB Monomax) side by side, the Bilsteins seemed to have a better fit/finish to them.
So, someone else I guess needs to compare the KYB Monomax to the Bilstein 4600. Any takers?
And FWIW, also let me add I'm extremely suspicious of anecdotal, testimonial type, one data point opinions --like the one I'm providing here. As humans, we make terrible data taking devices and are better served by testing in controlled conditions with a large set of data points; without that, almost anything can be claimed via testimony.
VDO gauges
CCV mod
post #22 of 29 (permalink) Old 03-07-2019, 01:30 AM
Yes, I see your point. What we really need is a large number of testers who will volunteer to compare the KYB Monomax to the Bilstein 4600.
If there are any volunteers who are willing to take part in this project, please identify yourselves.
post #23 of 29 (permalink) Old 03-07-2019, 05:40 PM
I had the KYB's for 8yrs figured it was time for new so I tried the Bilstein 4600 after 1000 miles I took them off and went back to the KYB's the bill's got softer after that amount of time carrying a 3500lb Lance camper in the back lesson learned and the rears leaked same with the steering stabilizer I put on the front (bill's also) LONG LIVE KYB's
redrocker is offline
post #24 of 29 (permalink) Old 03-08-2019, 07:28 AM
Interesting. What are your road conditions?
SOLD:
post #25 of 29 (permalink) Old 03-11-2019, 01:57 PM
CA roads
post #26 of 29 (permalink) Old 03-11-2019, 02:20 PM
Big Horn's Avatar
[QUOTE=farnorthdriver;4656044][SIZE=3]OK, finally reporting back on my shock experience. Got tied up with work and travel for a while and recently only got around to finishing other items on the truck and getting it out for a test drive.
Q.
farnorthdriver- I am interested what it was you didn’t like about the Rancho9000’s? Just curious as I just bought a full set for my 2002 F350 4wd cc drw 8’ box.
2002 F350 7.3L / 4R100 - 4WD CC DRW 8 Box, AIH Delete, Gauges- Pyro, Trans Temp, Boost, Fuel Pressure, TS-6 tuner, Zoodad Mod, Mishimoto 31 row Trans cooler, Mobil 1 ATF, Trans return line ATF filter, Hutch/Harpoon Mod, Air Lift Load Lifter 5000 rear air springs, Rancho 9000 shocks, Timbrens on the front.
Big Horn is offline
post #27 of 29 (permalink) Old 03-12-2019, 02:58 AM
See original post.
post #28 of 29 (permalink) Old 03-12-2019, 04:35 AM
CA roads
That really clears it up.
SOLD:
post #29 of 29 (permalink) Old 03-12-2019, 09:37 AM
Big Horn's Avatar
See original post.
I did read the “original post” ! Said he wanted to improve things and he gave the weight of his tc load—
I was looking for a little more detail, actual conditions- sway, rough roads, sag, etc, as I did an extensive search on dsf when looking at Members feedback on shocks — more than just opinion but actual user experience
Big Horn is offline
  Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > 1999-2007 Upgrades and Aftermarket - General
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Similar Threads
Urgent Help Please: 96 F250 XLT ext cab, 2wd, stock/no lift Bilstein Shocks shorton Power Strokes 1994-1997 General 2 09-04-2011 10:41 AM
icon, bilstein, RCD leveling kits smithw44 1999-2007 Upgrades and Aftermarket - General 1 07-08-2010 02:48 PM
Rear Bilstein Clearance On Stock Height F-250 4X4 pegleg 1999-2007 Upgrades and Aftermarket - General 33 06-24-2006 09:01 AM
Just switched from KYB to Bilstein....... 1MutCJ7 1999-2007 Upgrades and Aftermarket - General 3 11-05-2005 10:59 PM
KYB Monomax or Monroe Gas Magnum creative 1999-2007 Upgrades and Aftermarket - General 13 08-21-2005 05:37 PM
