Starting new thread / pictures for bed removal, air bags, shocks, Hutch mod - Diesel Forum - TheDieselStop.com
 10Likes
post #1 of 39 (permalink) Old 02-21-2019, 02:54 PM Thread Starter
Big Horn's Avatar
I got started today, after breaking my first T-50 stubby on the bed bolts I decided to try something different and it worked tremendously well- much better than grinding (IMO)- I do enough grinding at work! Funny thing is I have seen no mention of this on Diesel Stop, truck forums, or YouTube.
1/2” Milwaukee Drill, stepped 11/16” drill bit— drilled out 6 bolts in 40 minutes, going slow, making sure I stayed centered, and plenty of oil. Once deep enough head of bolt spins off.
Once the bed is off I will either weld nuts to remaining bolt shoulders or sawzall.
aclasshog likes this.
2002 F350 7.3L / 4R100 - 4WD CC DRW 8’ Box, AIH Delete, Gauges- Pyro, Trans Temp, Boost, Fuel Pressure, TS-6 tuner, Zoodad Mod, Mishimoto 31 row Trans cooler, Trans in-line return A/T fluid filter.
Big Horn is offline
post #2 of 39 (permalink) Old 02-22-2019, 09:15 AM
69mach1377's Avatar
I gave up after not seeing them want to back out...figured they wanted to stay more than I wanted them out. lol
2000 F250 XLT 4x4 SC 7.3 w/Auto Tranny w/ TC L/U Sw & shift kit, 3 autometer gages, Super Zoodad, PHP Hydra chip, 4" DP/Exhaust w/dual 3.5" outlets, 275/70/18 Kumho AT51s on 8.5" rims, 08 AlumDiffCvr, Bilsteins, 31 row trans cooler, WW, BPV delete, AIH delete, hutch, harpoon and billet FPR (70psi), trans cooler bypass delete by accident, rear air bags, Jimmijammers.
Jayco 26BHS elite, no RV parks...just the woods if possible.
See my album for a recent pic.
69mach1377 is offline
post #3 of 39 (permalink) Old 02-23-2019, 02:49 PM Thread Starter
Big Horn's Avatar
Bed is off! Went quite well working by myself—ceiling was just high enough
69mach1377 and aclasshog like this.
Big Horn is offline
post #4 of 39 (permalink) Old 02-24-2019, 08:08 AM
Subscribing
2001 Lariat, F250, 7.3, 6-speed, 3:73, Ford AIS, MBRP 4" turbo back, ATS ported housing, 205° t-stat, Infinity DX w/DP Tuner 80hp tow, coolant filter, Hutched & Harpooned, EGT & Boost gauge. Fuel Mavericks with 285/18, 86k miles(Jan-2017) Bought brand new April 2001.
aclasshog is offline
post #5 of 39 (permalink) Old 02-24-2019, 09:43 AM
Nice job!! My 99 has restrictor in the filler right at the door, I did not wack it out when I had my tank out. Not a big deal but every now and then I find a pump with a big nozzle I can't use. If yours has it now would be a good time to wack it. Keep the pics coming.
DENNY
1999 F350 AUTO 4x4 CC LB DRW 4.10
DENNY is online now
post #6 of 39 (permalink) Old 02-24-2019, 11:16 AM Thread Starter
Big Horn's Avatar
The remaining bed bolts—1. pipe wrench & cheater pipe, turned bolt shoulder until nut broke loose from the clip. 2. Cut clip in two with cut off wheel. 3. Tap of the hammer and it all falls apart off of the frame
Big Horn is offline
post #7 of 39 (permalink) Old 02-27-2019, 07:08 PM Thread Starter
Big Horn's Avatar
Sorry all, been trying to move forward but have been tired, I’ve been welding hydraulic 4” schedule 160 pipe all week on a machine outage at work:
Got the air springs modified and fitted: Air Lift, Load Lifter 5000 part # 57298 bought from SD Truck Springs. The application says for ‘71-‘04 F250/F350 Superduty 2WD/4WD w/Reese 5th wheel.
So here was the problem, I laid out the springs in their respective location (there is a Left and a Right. I did not like the fit. I double checked instruction detail which shows “Forward” and and still could not understand why in the world they would lay out the bracket this way. Bracket didn’t catch much of the frame on the forward end and rear of bracket that overlapped the 5th wheel bracket was excessive and holes didn’t line up🙄.
I reversed the top brackets putting the left on the right, and right on the left, looked at the modifications I would have to make to the slots in the top bracket, and fully welded to the 5th wheel brackets. Then I called the “Air Lift Technical department, went over the detailed drawing and they said “go for it”. From what I gathered they try to cover a lot of frame designs with a limited number of brackets.
The finished fit turned out “sweet” and I am posting pictures before painting so that the mods are obvious. Sorry for the extremely long post but figured someone may run into the same issue. I am also including the diagram from the instruction manual so you can see the difference,
Glenn.
Big Horn is offline
post #8 of 39 (permalink) Old 02-27-2019, 07:13 PM Thread Starter
Big Horn's Avatar
Couple more pics:
Big Horn is offline
post #9 of 39 (permalink) Old 02-28-2019, 08:14 AM
69mach1377's Avatar
Your next issue may be getting the bed back on. I did mine with the bed on and the top brackets barely squeezed in, so take some measurements for no surprises.
Of course we have different beds, so hopefully you are good to go.
post #10 of 39 (permalink) Old 02-28-2019, 08:48 AM Thread Starter
Big Horn's Avatar
Thanks 69mach1377— good to always look at all possibilities, earlier I took some measurements and layed my 4’ level across the 5th wheel brackets. The top bracket lip that turns up (stiffener) is going to clear by about an inch on each side.
Big Horn is offline
post #11 of 39 (permalink) Old 03-01-2019, 09:16 AM
69mach1377's Avatar
Nice...mine actually touch, but there is no movement so not an issue.
post #12 of 39 (permalink) Old 03-01-2019, 10:13 AM
Now that you have airbags to adjust hight you could pull the blocks out from under the springs. I dropped the springs all the way to the top of the axle on my 99 and my tail gate is now 5 inches lower. Great for loading/unloading and better side wall clearance for the 5th wheel on uneven ground. Truck sits level when empty and headlights are always aimed right due to adjusting air bags for the load. I ran my air bag lines to the top holes in the license plate. This is also a good time to pop the spare tire key out of the reel if so inclined. What year truck do you have?
DENNY
DENNY is online now
post #13 of 39 (permalink) Old 03-01-2019, 01:21 PM Thread Starter
Big Horn's Avatar
2002 F350
Big Horn is offline
post #14 of 39 (permalink) Old 03-01-2019, 01:27 PM Thread Starter
Big Horn's Avatar
Both rear rotors bad
Big Horn is offline
post #15 of 39 (permalink) Old 03-01-2019, 06:13 PM Thread Starter
Big Horn's Avatar
Originally Posted by DENNY View Post
Now that you have airbags to adjust hight you could pull the blocks out from under the springs. I dropped the springs all the way to the top of the axle on my 99 and my tail gate is now 5 inches lower. Great for loading/unloading and better side wall clearance for the 5th wheel on uneven ground. DENNY
Denny, I’m sending you a PM
Big Horn is offline
  Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > 1999-2007 Upgrades and Aftermarket - General
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Similar Threads
New little secrets thru 07/30/05 Larry M E-Series Vans 18 01-28-2010 03:14 PM
Air Lift Bags and Tanks Are IN!!! Bruce1954 Power Stroke Excursions 21 01-05-2007 01:23 AM
Which springs..help retodd Towing and Hauling 17 03-26-2006 12:30 AM
ATS Ported Housing with stock wheel vs. stock housing with WW DarthSurplus '99 & up Upgrades and Aftermarket - 7.3L Engine 225 03-17-2005 02:43 PM
Here is my little Secret Larry M E-Series Vans 21 04-17-2003 08:23 AM
