Starting new thread / pictures for bed removal, air bags, shocks, Hutch mod - Page 2 - Diesel Forum - TheDieselStop.com
 10Likes
post #16 of 40 (permalink) Old 03-01-2019, 07:19 PM
Got it.
DENNY
1999 F350 AUTO 4x4 CC LB DRW 4.10
DENNY is offline
post #17 of 40 (permalink) Old 03-02-2019, 12:16 PM Thread Starter
Big Horn's Avatar
Well, I’ve been to NAPA, and called Oreilys, Advanced Auto, Auto Zone, nobody has the Dana 80 axle to hub O-ring. Had to order online.
2002 F350 7.3L / 4R100 - 4WD CC DRW 8’ Box, AIH Delete, Gauges- Pyro, Trans Temp, Boost, Fuel Pressure, TS-6 tuner, Zoodad Mod, Mishimoto 31 row Trans cooler, Trans in-line return A/T fluid filter.
Big Horn is offline
post #18 of 40 (permalink) Old 03-02-2019, 06:52 PM Thread Starter
Big Horn's Avatar
A screw driver wasn’t going to get her done but an old bumper jack handle/lug wrench and big hammer did! Took bearing out, removed old Teflon, clean out hub, put bearing back in (I didn’t forget&#x1f609 pressed in seals and mounted new rotors.
aclasshog likes this.
Big Horn is offline
post #19 of 40 (permalink) Old 03-07-2019, 04:09 PM Thread Starter
Big Horn's Avatar
2002 F350 4wd cc drw
Q. Does anyone have the torque specs lb-ft for the rear axle flange (to hub) bolts? I’ve been all over the forum and web. I’m finding other references for Dana 80 (Dodge) with axle flange bolts at 95 lb-ft. ? Don’t know if that’s right.
At one time I had seen a write up—but now I can’t find it. In It was listed a Ford part # thread lock
Q. Can I use the blue locktite on these bolt threads
Thanks!!!!
Big Horn is offline
post #20 of 40 (permalink) Old 03-08-2019, 12:16 PM Thread Starter
Big Horn's Avatar
Got the hubs and axles buttoned up. And the Amsoil added. 4 quarts is not quite enough even with half a bottle of Slip Lock additive added per instructions. Descaled all the loose rust with my needle gun (comparison jn picture of bottom already peened cleaned)
Coated with “Ospho” and needs a 24 hr cure.
Found root cause of right rear rotor scored up so badly- caliper bracket slide pin was locked up solid. Tried penetrating oil and pipewrench- just twisted it off. Heading to town to pick up two loaded calipers for the rear. I think Denny mentioned earlier if they looked like the original calipers replace with new loaded ones, the piston boots look pretty wore too—good call Denny!
Big Horn is offline
post #21 of 40 (permalink) Old 03-09-2019, 02:12 PM Thread Starter
Big Horn's Avatar
I think it’s been mentioned before about the lousy set-up for adjusting the parking brakes. I never had trouble with my old Chevy’s over the years but the brake spoon I had wasn’t going to work.
Here’s a picture of the screwdriver I modified— easy to turn the star wheel and enough room to see as I was turning it.
Big Horn is offline
post #22 of 40 (permalink) Old 03-15-2019, 05:01 PM Thread Starter
Big Horn's Avatar
What a pain in the rump- two more to go
Big Horn is offline
post #23 of 40 (permalink) Old 03-15-2019, 05:09 PM Thread Starter
Big Horn's Avatar
Does anyone know why this cable (see picture) is ran though the bed support channel and bolted to the frame?
Is it factory or something that was added when the 5th wheel was installed?
Big Horn is offline
post #24 of 40 (permalink) Old 03-15-2019, 05:21 PM
bugman's Avatar
My Photos: (12)
That was done afterwards.
Where is the other end attached? I could be just for a good ground.
bugman is offline
post #25 of 40 (permalink) Old 03-15-2019, 05:25 PM Thread Starter
Big Horn's Avatar
Both ends (lug) were on the same bolt, attached through the frame— all I can think of is some sort of safety strap?
Big Horn is offline
post #26 of 40 (permalink) Old 03-15-2019, 05:42 PM
That cable was from a recall that ford did to stop beds from coming off in wrecks
Big Horn likes this.
Buffalohead1 is offline
post #27 of 40 (permalink) Old 03-15-2019, 06:49 PM Thread Starter
Big Horn's Avatar
Thanks- that’s certainly is what it looks like..... I really don’t want to drill a big hole in my new bed channel though. Hard to believe 8 bolts wouldn’t hold the bed on in a wreck and with the addition of the 5th wheel rails across the inside of the bed and bolted to the frame I think putting the strap back on would be a waste of time— IMO
Big Horn is offline
post #28 of 40 (permalink) Old 03-16-2019, 09:17 AM
69mach1377's Avatar
aka the cya cable...lol
2000 F250 XLT 4x4 SC 7.3 w/Auto Tranny w/ TC L/U Sw & shift kit, 3 autometer gages, Super Zoodad, PHP Hydra chip, 4" DP/Exhaust w/dual 3.5" outlets, 275/70/18 Kumho AT51s on 8.5" rims, 08 AlumDiffCvr, Bilsteins, 31 row trans cooler, WW, BPV delete, AIH delete, hutch, harpoon and billet FPR (70psi), trans cooler bypass delete by accident, rear air bags, Jimmijammers.
Jayco 26BHS elite, no RV parks...just the woods if possible.
See my album for a recent pic.
69mach1377 is offline
post #29 of 40 (permalink) Old 03-16-2019, 10:19 AM Thread Starter
Big Horn's Avatar
I suppose you’re right—isn’t that a shame what it’s come to
Big Horn is offline
post #30 of 40 (permalink) Old 03-16-2019, 05:25 PM
Bighorn, did you replace those bed struts? I'd be interested to see how you removed the old ones without damaging the bed.
2001 Lariat, F250, 7.3, 6-speed, 3:73, Ford AIS, MBRP 4" turbo back, ATS ported housing, 205° t-stat, Infinity DX w/DP Tuner 80hp tow, coolant filter, Hutched & Harpooned, EGT & Boost gauge. Fuel Mavericks with 285/18, 86k miles(Jan-2017) Bought brand new April 2001.
aclasshog is offline
  Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > 1999-2007 Upgrades and Aftermarket - General
Similar Threads
New little secrets thru 07/30/05 Larry M E-Series Vans 18 01-28-2010 03:14 PM
Air Lift Bags and Tanks Are IN!!! Bruce1954 Power Stroke Excursions 21 01-05-2007 01:23 AM
Which springs..help retodd Towing and Hauling 17 03-26-2006 12:30 AM
ATS Ported Housing with stock wheel vs. stock housing with WW DarthSurplus '99 & up Upgrades and Aftermarket - 7.3L Engine 225 03-17-2005 02:43 PM
Here is my little Secret Larry M E-Series Vans 21 04-17-2003 08:23 AM
