Stupid and thought twice about it - Diesel Forum - TheDieselStop.com
 1Likes
  • 1 Post By klhansen
post #1 of 8 (permalink) Old 03-26-2019, 12:04 AM Thread Starter
JJEdwards's Avatar
So I just thought I would try some therapy and post this to try and make myself feel better. First turbo job BTW. Did a turbo rebuild and had some difficulty getting the up pipe clamp off. Well I used a pry bar on the turbo and I think I bent the up pipes flange. Upon reinstall, instead of loosening the up pipes, I fastened the turbo to the up pipes first then "attempted" to fasten the turbo to the pedestal...very bad idea. The bolts were very difficult to get onto the pedestal but I kept on going. My only fear was this happening, oil everywhere. Probably half to a full gallon. Literally shot one of the o'rings out. I'm typing this and wondering if I should hit the button to post it.......embarrassing! Now I'm wondering if I should buy a new pedestal. I'll be taking it all back out and see how the bolts thread back on. Stupid and lazy decision to not loosen the up pipes. My wife is out of town on work, I'm without my truck and have another day out of work to make it right. I'll be borrowing one of my teenagers cars (which I pay for) in the meantime I guess. Don't be too hard on me. LOL
Jared
2000 7.3 PSD 4x4 Auto Trans., CC, short box 207,500 miles.
PHP Hydra, Bilstein 5100's, Bilstein steering stabilizers, Auto Meter 3 gauge pod--EGT, Trans Temp & Boost, Deep Trans Pan, Rotella ELC and T6 oil, DieselSite 203*, Riffraff Billet wheel, 4" turbo back MBRP 5" straight pipe, Donaldson 6637 blue, 20" Fuel wheels wrapped with 37" MT's
Security: Ravelco (for the pro's), Viper (for the rookies), The Club 1100 Steering Wheel Lock (visual deterrent).
JJEdwards is offline
post #2 of 8 (permalink) Old 03-26-2019, 07:40 AM
Don't beat yourself up over it. Sometimes you get the bull, and sometimes he gets you. When I installed my 38R I did not have to loosen the up pipes. It took a bit but I held my tongue right and it fell into place. Some have to loosen the up pipes to install the turbo, it won't go on any other way. They are kind of like old small block Chevy exhaust manifolds. They come off, but sometimes they won't go back on. In fact, they made a tool to keep the manifold from warping on the chebbies. Anyway, get a new pedestal and new bolts and try again. May be a good time to get a ebpv delete pedestal and turbo outlet?
2000 F350 DRW 7.3
tomlin is offline
post #3 of 8 (permalink) Old 03-26-2019, 04:57 PM
klhansen's Avatar
My Photos: (180)
I doubt you damaged the pedestal, but that's possible.
Turbos are a PITA to get in place. And the up-pipes connections are also a PITA to get at if you leave them loose. A couple of us once worked at least an hour trying to finally get the pin aligned to the up-pipe wye and turbo bolted in place.
Don't feel bad about your "event".
But then again, I've never done anything like that.
), AIS,
regulated return,
klhansen is offline
post #4 of 8 (permalink) Old 03-27-2019, 01:53 AM Thread Starter
JJEdwards's Avatar
You guys input helps a lot. Thanks for talking me down from the ledge!!! What I did learn in this process (by the way have owned this truck for only a year) is that it has an EBPV delete and bellowed up pipes. Looking at the positives here as you can see. Hoping to get it going by the weekend. I'll report back with the results.
Here's a photo of what I had to build to even begin this work. All scrap wood and no cuts made, lol. Will deconstruct when finished. Truck is tall from previous owner that I plan on dropping within the next year. Incredible truck BTW!
System won't let me even post a 25 kb pic. "Max file limit exceeded" I'll try again later.
post #5 of 8 (permalink) Old 03-27-2019, 01:55 AM Thread Starter
JJEdwards's Avatar
Here's the pic...
post #6 of 8 (permalink) Old 03-27-2019, 05:39 PM Thread Starter
JJEdwards's Avatar
Had to order a new pedestal. Noticed the one I took out had a bolt in the armature hole (I think that's what it's called) plugging it. Any chance the new blank pedestal will make any difference?
Jared
post #7 of 8 (permalink) Old 03-27-2019, 09:15 PM
klhansen's Avatar
My Photos: (180)
Yeah, some sort of topside creeper is a must for working that far back over the engine. Or at least some serious padding. Always seems like the hood bumpers wind up in some strategically dangerous spot.
JJEdwards likes this.
), AIS,
regulated return,
klhansen is offline
post #8 of 8 (permalink) Old 03-31-2019, 12:54 PM Thread Starter
JJEdwards's Avatar
Got it all back together couple days ago and everything went great. The up-pipes weren't bent and the turbo and new pedestal went on relatively easy. The up-pipe pin alignment is truly a PITA like you said. Oh what fun it is! I could do this job in my sleep now though. Thanks for all the advice.
Jared
  Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > 1999-2007 Upgrades and Aftermarket - General
Similar Threads
stupid accident. put gas in my tank....... swapwap '99 & up 7.3L Power Stroke Engine and Drivetrain 5 01-11-2006 11:28 PM
Stupid Question imelmo '99 & up Upgrades and Aftermarket - 7.3L Engine 2 08-06-2005 07:18 PM
stupid question quackrz 1999-2007 General Questions 4 07-03-2005 01:40 AM
Ok, time for another round of "Stupid things I have done" ziggster40 6.9L IDI Diesels (Not Power Strokes) 41 05-04-2005 10:07 PM
