Sun visors - Diesel Forum - TheDieselStop.com
post #1 of 5 (permalink) Old 07-15-2019, 10:14 PM Thread Starter
demoes4x's Avatar
Sun visors
Has anyone upgraded their sun visors on a 2000 year model with ones from a 2011 to 2015 with home link I'm wondering if they're even the same length or if they mount on the same way.
EARLY 99' F350 7.3 CC 4X4 LB. DRW. FABTECH 3.5" FRONT LEVELING KIT - AUTOMETER BOOST, PYRO, TRANS, WATER, OIL TEMP, FUEL & AIR PRESSURE - WW2 - AIS INTAKE - 4" SS MBRP COOL DUALS TURBO BACK - JOHN WOOD TRANS - RIFFRAFF BOOTS - 6.0 TRANS COOLER - CCV MOD - PROVENT 200 - DP TUNER NO START, STOCK, 40T, 80E, 120 RACE - 35" TOYO MT'S - 22" AMERICAN FORCE EVOS - FOX 2.0 RESEVOIR SHOCKS - UPGRADED POST 99' 10MM HUB ASSY'S - SLOTTED BRAKE ROTORS - MAG-HYTEC TRANS PAN & DIFFERENTIAL COVERS - ITP SS HP-X - ITP REGULATED RETURN - HEATER BYPASS VALVE - AIRDOG - DIESELSITE COOLANT FILTER - DIESELSITE 203* TS WITH BILLET HOUSING - DC PERF 190 AMP ALTERNATOR - ON-BOARD AIR - HORN BLASTERS - 13' LARIAT INTERIOR.
demoes4x is offline
post #2 of 5 (permalink) Old 07-16-2019, 07:42 AM
RT
RT's Avatar
I did my 03 with a pair from a 2011 to get the garage door opener. The power connection is different, so I had to get a pigtail from Tousley Ford. The screw mounting pattern is the same, but the pivot that recesses into the center hole is larger so you have to enlarge it with a dremel. Theyíre a bit larger so when you swing them down, the driverís side hits my gauge pod whereas the old ones didnít. So- not a direct bolt in, but they will work.
RT is online now
post #3 of 5 (permalink) Old 07-16-2019, 08:09 AM Thread Starter
demoes4x's Avatar
Did your visors look like mine.
demoes4x is offline
post #4 of 5 (permalink) Old 07-16-2019, 08:15 PM
RT
RT's Avatar
My old ones did.
Sent from my iPad using Tapatalk
RT is online now
post #5 of 5 (permalink) Old 07-16-2019, 10:27 PM Thread Starter
demoes4x's Avatar
Ok, I was thinking perhaps the 2011 sun visors would not be long enough to reach the clips above the rear view mirror where they snap in place. Thanks RT.
demoes4x is offline
  Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > 1999-2007 Upgrades and Aftermarket - General
