Superduty headlights - Diesel Forum - TheDieselStop.com
 5Likes
LinkBack Thread Tools
Old 12-04-2014, 12:20 AM Thread Starter
So just got a 2000 7.3 and pretty much only complaint I have is the headlights are the worst I ever seen. Bad enough I hit a deer first night I had it. No damage thank god. So I did install a 30" led bar on bumper hooked direct to high beams and 2 4x4 cube led for low beams. Question is what are best replacement headlights. While assemb and not just bulbs. Thanks
Polock is offline
Old 12-04-2014, 10:41 PM
SlopeTruck's Avatar
My Photos: (29)
'01 + clear lensed housings are a direct fit, use the same bulbs and throw way more light than the '99-'00 "glaucoma" lights. Can sometimes pick them up pretty cheap.
'05-'07 lights look better but require you to cut the header panel and splice a different pig tail on the wire (part I really didn't like as it's smaller gauge wire.)
Both are way brighter.
'00 Excursion Limited, V/B code springs, 35" BFG, open element intake, 4" dp+ exhaust, F350 rear swaybar, TW 4 pos. chip, FF 160 injectors.
SOLD '00 F350 Lariet CC 4X4 on 37" Iroks, 325K miles, pulled most stuff off and put on the EX.
SOLD '95 F350 CC 4X4 (ex-slope truck) flatbed on 35" BFG and H2 rims.
Play/plow truck '91 F350 on 40X17X15's, 351W, CC bobbed 3', winches front/rear, lots of DIY stuff.
SlopeTruck is offline
Old 12-04-2014, 11:32 PM
klhansen's Avatar
My Photos: (180)
What he ^ said.
You can get a pair for just over $200 from AutoNation Ford White Bear Lake | Parts & Accessories
Here's the part no's you need.
2C3Z-13008-AACP Left
2C3Z-13008-ABCP Right
They come complete with bulbs and adjusters.
), AIS,
regulated return,
klhansen is offline
Old 12-05-2014, 08:22 AM
RT
RT's Avatar
You can also get TYC from RockAuto for $28 each. I've got a set and they are as good or better quality than the OEM. Even came with new bulbs when I ordered mine.
RT is offline
Old 12-05-2014, 12:14 PM
Feedback Score: 3 reviews
We have a USA made harness and better bulbs, best non Hid lighting when used in clear housings also true Projection Hids if you want the best possible lighting..
caryt is offline
Old 12-05-2014, 09:44 PM
strokesmoke94's Avatar
DP Tuner has some really nice ones if you are looking for projection LED's with halo's and your checkbook don't mind taking a hit. It looks like their website is currently down for maintenance tho.
Sent from AutoGuide.com Free App
'99 Ford F250 7.3 4WD CC Lariat Auto Trans. K&N Filter Turbo back 3.5" Exhaust
strokesmoke94 is offline
Old 12-06-2014, 01:26 PM Thread Starter
The halo sound good. But I couldn't take it anymore the way it was. So I installed the LED bars. Man what a improvement. I think I'll just buy the 01 clear lenses.
Also. Does this forum have a app for tapatalk?
Polock is offline
Old 12-07-2014, 12:46 AM
I think it does but I'm not sure. I use AutoGuide. It works really nice, in fact, everything I've been doing on here is from that app. Ever heard of it? Ya gotta have an iPhone tho.
'99 F250 7.3, CC, SB, Lariat, Auto, 4x4, 265/75R16's, 3.73 Gears, K&N Drop-In, 3.5" Turbo Back Straight Thro.
Old 12-12-2014, 06:47 PM
I bought these
And will be using a LED direct fit bulb. https://www.lifetimeledlights.com/
The LED bars are for off road use and are too bright and blind other cars.
2011 F450 K/R ALL Stock and staying that way
2001 F250 Lariat. BTS, DP Tuner, Banks inter-cooler, Banks Turbo upgrades, Banks Exhaust, Banks Exhaust brake,
edinning is offline
Old 12-13-2014, 03:30 PM
Googs's Avatar
These one seem to be in the right price range.
03 F250 4x4 CC 7.3ltr 4R100HD rebuilt, 160,000 Klms
GTP38R , Turbo-master , IH Bellowed up pipes, RiffRaff CAC boot kit, AIH delete, .
4" Turbo back exhaust ,Banks power elbow, LPG (Gas over diesel) DP F6 tuner, 40hp tow, 60hp tow, 80hp tow, 60hp, 80hp, 120hp race, Decel, 1200 RPM.
RiffRaff 6637 intake ,pre filter, Snorkle
Custom made trans cooler with twin thermo fans ,water to oil cooler
Scangauge 11,AutoMeter Trans temp, pyro ,Water/Oil temp, Fuel Pressure, Boost.
Longrange 120 ltr fuel tank and transfer pump, 15,000 lb winch, Warn winch bar, Lightforce HID spot lights, HID headlights, Black Widow Drawer System, Snugtop Canopy with gull windows, Fr & Rr ARB Diff locks, Hornblaster Train horns, Post fuel pump filter, RiffRaff FRx and HPx , Bilsteins x4, Onboard compressor , Air tank and water traps, Billet door handles, Alpine headset, Alpine overhead DVD player, Rockford Fosgate sub, Alpine amp and CD changer.
Googs is offline
Old 12-13-2014, 07:50 PM
losfinch's Avatar
I got some Dorman replacements headlights 2004 year version from Summit Racing. I am real pleased with them and how they project so much better than the OEM 1999 style and also some other off brand cheapos I had before. I'd recommend them...about $40 each IIRC.
Early 99 F350 4X4 CC 7.3 Auto. A.R.E. Topper, bed carpet/bench inserts, Rhino grill guard, AIS w/sleeve, Fuel filler mod, GOS headlight harness, 02-04 Headlights, Rancho HD stabilizer, 06 Telescoping/heated mirrors with C-Btr Mirrors, Hella FF1000, Htr Bypass valve, front receiver hitch, Quadzilla XZT gauges, ITP Pre-pump/In-tank mods, Pioneer P5000UB w/XM radio, 4 Infinity Kappa 682.7cf, Fumoto valve, FIAMM Highway blaster horns, SS HPX, IDM mod, DP F5 (Stock,Drive-thru,60T,80E,120,80E-Mountain,1200), Walker BTM, RR, Dieselsite BRV, BTS Tranny (2nd one :-), 31 row tranny cooler, Bilstein shocks, Amsoil bypass oil filter, Stancor HD Glow Plug Relay, billet thermostat housing, front & rear parking cameras, Aux reverse lights, Heated Seats.
Security: CrimeGuard Alarm with remote notification, DIY jimmi-jammers, door cylinder locks and linkage removed, padlocked rear bench seat hinge, PCM, DIY "pitstop" switch.
losfinch is offline
Old 05-23-2018, 06:05 PM
ArcticDriver's Avatar
I pulled this old thread up to say I found a very good price of $111.00 on Genuine Ford headlight assemblies at a place called TascaParts.com:
2C3Z*13008*AA (Right-Driver): https://www.tascaparts.com/oem-parts...ly-2c3z13008aa
And
2C3Z*13008*AB (Left-Driver): https://www.tascaparts.com/oem-parts...ly-2c3z13008ab
But then I read where RT mentioned TYC Brand for considerably less.
RT, are your TYC still holding up well these few years later? Any UV fading or cloudiness?
SOLD:
ArcticDriver is offline
Old 05-23-2018, 07:08 PM
RT
RT's Avatar
They look brand new. Not even a hint of cloudiness.
ArcticDriver likes this.
RT is offline
Old 05-23-2018, 07:56 PM
Thanks for the feedback.
I just placed my order at Rock Auto for a savings of $180.
SOLD:
Old 05-24-2018, 08:43 AM
69mach1377's Avatar
Do you have a part# or link?
2000 F250 XLT 4x4 SC 7.3 w/Auto Tranny w/ TC L/U Sw & shift kit, 3 autometer gages, Super Zoodad, PHP Hydra chip, 4" DP/Exhaust w/dual 3.5" outlets, 275/70/18 Kumho AT51s on 8.5" rims, 08 AlumDiffCvr, Bilsteins, 31 row trans cooler, WW, BPV delete, AIH delete, hutch, harpoon and billet FPR (70psi), trans cooler bypass delete by accident, rear air bags, Jimmijammers.
Jayco 26BHS elite, no RV parks...just the woods if possible.
See my album for a recent pic.
69mach1377 is offline
  Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > 1999-2007 Upgrades and Aftermarket - General
