Superduty headlights - Page 2 - Diesel Forum - TheDieselStop.com
 5Likes
post #16 of 44 (permalink) Old 05-24-2018, 10:42 AM
ArcticDriver's Avatar
Scroll down to TYC for $26.79 each.
https://www.rockauto.com/?carcode=13...parttype=10762
69mach1377 likes this.
SOLD:
ArcticDriver is offline
post #17 of 44 (permalink) Old 05-24-2018, 03:08 PM
Greazydiesel's Avatar
Headlights Depot in Pompano Beach has an amazingly large selection of lights in all price ranges, I've done about 4 trucks with their lights and have no complaints. I'd post a link but can't, not enough posts yet.
GD
Greazydiesel is offline
post #18 of 44 (permalink) Old 05-25-2018, 07:02 AM
I just bought a set from Headlights Depot...
The 05-07 headlights upgrade for my Y2K-X...
I haven't had time yet, to take the old ones out ,and cut the header panel to put them in...
Looking forward to upgrading the looks of my truck
In the box, the headlights look pretty good
They come with everything you need ....
Bulbs, Pig tail adapter, and some inadequate instructions...
Price was good...$107 ????
XS_SUV
Graupp is offline
post #19 of 44 (permalink) Old 06-15-2018, 01:23 PM
Well I have purchased both an original Ford headlight ($144) and TYC ($26) headlight in the Aero style with the 2002+ lens design that has a smooth lens vs the earlier model years fluted lens.
I was fully expecting to see a bit lesser quality in the TYC which would be completely understandable given the price difference of $118.
I am surprised to say that even with my trusty magnifying glass I cannot find anything superior in the quality or build of the Motorcraft. In fact, the TYC actually weighs slightly more. The molds are nearly identical. Inside the lens, the designs are identical. The seams where the clear lens meets the grey housing appears equally sealed for water tightness.
The only visual difference are the adjuster screws on the Ford are metal while the TYC are plastic.
The only test remaining is to see how the plastic lens on the aftermarket TYC holds up to UV light over a few years but up here at 8,300' I always treat my plastic with the Meguiars Plast-X Clear Plastic Protector or similar wax so I can't really do that UV test.
Bottom line, RT just saved me about $236 by suggesting the TYC brand from Rock Auto.
Thanks RT.
SOLD:
post #20 of 44 (permalink) Old 06-15-2018, 05:22 PM
69mach1377's Avatar
Thanks for the update.
I use the clear headlight film on mine to protect them from several things including sun light. Xpel brand lately.
2000 F250 XLT 4x4 SC 7.3 w/Auto Tranny w/ TC L/U Sw & shift kit, 3 autometer gages, Super Zoodad, PHP Hydra chip, 4" DP/Exhaust w/dual 3.5" outlets, 275/70/18 Kumho AT51s on 8.5" rims, 08 AlumDiffCvr, Bilsteins, 31 row trans cooler, WW, BPV delete, AIH delete, hutch, harpoon and billet FPR (70psi), trans cooler bypass delete by accident, rear air bags, Jimmijammers.
Jayco 26BHS elite, no RV parks...just the woods if possible.
See my album for a recent pic.
69mach1377 is online now
post #21 of 44 (permalink) Old 07-20-2018, 08:48 AM
69mach1377's Avatar
Thanks RT.
Still happy with them? Got any pics of them installed? Any issues with adjustment?
post #22 of 44 (permalink) Old 07-20-2018, 12:09 PM
Yes, still happy.
Just installed a pair on the 2nd truck since it makes the trucks look so well taken of.
Equal to factory originals in all regards...i.e adjustments and light dispersement.
installation is simple except removing the old ones is a bit of a PIA. Much easier to remove batteries to gain access but driver side is still a bit tricky. Its the bottom attachment that is tough but the two upper attachments just require removal of 2 clips. This would be the case for any Aero style light.
SOLD:
post #23 of 44 (permalink) Old 03-27-2019, 02:58 PM
I just installed these on mine.
2000 7.3 PSD
Crew Cab
Auto Tran
2 x 4
Lariat Edition
SuperChips Programmer
BTM Muffler
EGT, Turbo Boost, and Trans Temp Gauges
rprice is offline
post #24 of 44 (permalink) Old 03-27-2019, 10:45 PM
losfinch's Avatar
I'm sorry to report that the Dorman ones I bought back when from Summit Racing both had the little chrome piece inside of the light that covers the actual bulb both popped loose after about 6 months of use and have been rattling around inside of the lenses for a couple of years now. To tell you th e truth I can't see a difference in the light output so I've just left them for now...kind of tacky, I know...but they work. I just wouldn't ever recommend the Dorman brand of lights to anyone after my experience with them.
TWO4ONEPRICE likes this.
Early 99 F350 4X4 CC 7.3 Auto. A.R.E. Topper, bed carpet/bench inserts, Rhino grill guard, AIS w/sleeve, Fuel filler mod, GOS headlight harness, 02-04 Headlights, Rancho HD stabilizer, 06 Telescoping/heated mirrors with C-Btr Mirrors, Hella FF1000, Htr Bypass valve, front receiver hitch, Quadzilla XZT gauges, ITP Pre-pump/In-tank mods, Pioneer P5000UB w/XM radio, 4 Infinity Kappa 682.7cf, Fumoto valve, FIAMM Highway blaster horns, SS HPX, IDM mod, DP F5 (Stock,Drive-thru,60T,80E,120,80E-Mountain,1200), Walker BTM, RR, Dieselsite BRV, BTS Tranny (2nd one :-), 31 row tranny cooler, Bilstein shocks, Amsoil bypass oil filter, Stancor HD Glow Plug Relay, billet thermostat housing, front & rear parking cameras, Aux reverse lights, Heated Seats.
Security: CrimeGuard Alarm with remote notification, DIY jimmi-jammers, door cylinder locks and linkage removed, padlocked rear bench seat hinge, PCM, DIY "pitstop" switch.
losfinch is offline
post #25 of 44 (permalink) Old 03-27-2019, 11:32 PM
@losfinch
Thats the kind of feedback that helps.
SOLD:
post #26 of 44 (permalink) Old 03-28-2019, 08:05 AM
Sorry about your issue with the headlights. On my AKKORN lights, there seems to be access to the inside via retainer clips holding the lens. Do you not have that on the Dorman? See the silver clips on mine. There are three more clips at the bottom of each light.
TWO4ONEPRICE is offline
post #27 of 44 (permalink) Old 03-28-2019, 10:30 AM
I have had the TYC brand for 10 years or more. The lens is still clear. I just ordered a new TYC passenger headlight because I hit a deep pothole and broke the headlight where it adjusts.
2002 F350 7.3 psd supercab dually 2wd, AIS, Moog joints, Bilstein, Michelin Defender LTX, Dieselsite coolant filter, red ELC, prepump spin-on fuel filter, 260,000 miles, hutch/harpoon mod, marinco mod, scan gauge ll, Zoodad, Dieselsite boots, pedestal delete, CNC Fab w/ crossover oil lines, 6.0 trans cooler, replaced oil pan, Walker BTM, Denso starter, bellowed up pipes, rebuilt oil cooler, billet dip stick adapter, HD glow plug relay
1974 CJ6 ... off the frame needs work
2013 Expedition... wife's car
Panhead ... 53 motor, 51 tanks, B grind cam, S&S carb, points, drum brakes ... It doesn't just sit in the garage
panhead george is offline
post #28 of 44 (permalink) Old 06-21-2019, 03:19 PM
The OEM manufacturer for the early models 99-04 is a company called Visteon. They are not made by Ford or Motorcraft.
mmsafd is offline
post #29 of 44 (permalink) Old 07-20-2019, 04:31 PM
IIRC Visteon is a ford company and has been for years. I used to work at Ford Microelectonics/visteon over 20yrs ago.
I recently replaced my headlights on my 03 with factory ford/visteon lights as i will not use aftermarket parts. I bought them from a ford dealer on ebay, paid $226 shipped for the pr. also bought better quality bulbs (not the high dollar ones either)which made a huge difference. I can actually see the road at night now.
just in case, I also bought the headlight harness from dfuser because i didn't feel like sourcing my own parts this time around. I think it helped but not as much as many claim. the quality is good but could still be better.
biggest improvement was headlight housings and bulbs. they came with sylvania bulbs but I took those out.
03 F350 7.3L Auto CC LB Dually 410's (LS Rear)
PHP/Beans, 1023, SDK, GH tuned/250/100 FF inj's, Irate T4 w/369SXE, Swamps HVHF IDM, BTS Tranny, Strictly Diesel complete fuel system with RR & FB delete.
Autometer Nexus Guages, 4"MBRP, DieselSite Coolant filtration system/billet housing/HP X-Over line. Donaldson Blue(6637)/AFE BHAF, RR Boots/ Billet Plenums, ('06) 26 row Tranny & PS Cooler, LarryB's Genuine Denso Starter
INFRNL is offline
post #30 of 44 (permalink) Old 07-21-2019, 07:37 AM
INFRNL,
The UV clouds up headlight housings very bad here.
I replaced my first trucks headlights using genuine Ford from White Bear Lake. I replaced my current trucks housings with aftermarket (TYC ?) and I think the light pattern is slightly worse. The moldings might be slightly different than genuine Ford.
I do pay the extra for Sylvania SilverStar Ultra Halogen. They last about 18-24 months for $25/each.
SOLD:
  Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > 1999-2007 Upgrades and Aftermarket - General
