Updating Big Al - Diesel Forum - TheDieselStop.com
 4Likes
  • 1 Post By DENNY
  • 1 Post By DonWarkentin
  • 1 Post By Big Horn
post #1 of 9 (permalink) Old 03-27-2019, 02:47 PM Thread Starter
Updating Big Al
Iíve started updating my 2000 Powerstroke. I started by putting it in the shop to get the PCM updated, to check a small leak, and a general checkup. Then I ordered new OEM leather seat covers, new grill, new LED headlights, new tires, new stereo with GPS touchscreen, backup camera, as well as getting it painted as soon as the pollen settles down.
Before and after some of the front end upgrades and tires.
2000 7.3 PSD
Crew Cab
Auto Tran
2 x 4
Lariat Edition
SuperChips Programmer
BTM Muffler
EGT, Turbo Boost, and Trans Temp Gauges
rprice is offline
post #2 of 9 (permalink) Old 03-27-2019, 09:48 PM
Nice!! Having headlights that work are great!! What kind of stereo? Is the backup cam hard wire or bluetooth?
DENNY
TWO4ONEPRICE likes this.
DENNY is offline
post #3 of 9 (permalink) Old 03-28-2019, 01:17 AM
Looks great!
DonWarkentin is offline
post #4 of 9 (permalink) Old 03-28-2019, 07:17 AM
I got this stereo from Crutchfield.
TWO4ONEPRICE is offline
post #5 of 9 (permalink) Old 03-30-2019, 08:57 PM
I worked on the front seats today. Very proud of my efforts. Replaced the worn leather upholstery with OEM leather replacements. After 4 - 5 hours, I completed this task. Now, I need a little sunshine and heat to shrink the leather to a better fit. After this, itís off to the paint shop for exterior coating.
post #6 of 9 (permalink) Old 03-30-2019, 08:59 PM
Sorry about the screwed up pics. They were correct in my photos.
post #7 of 9 (permalink) Old 03-30-2019, 10:04 PM
Big Horn's Avatar
Originally Posted by rprice View Post
I’ve started updating my 2000 Powerstroke. I started by putting it in the shop to get the PCM updated, to check a small leak, and a general checkup. Then I ordered new OEM leather seat covers, new grill, new LED headlights, new tires, new stereo with GPS touchscreen, backup camera, as well as getting it painted as soon as the pollen settles down.
Good looking headlights- were they easy to change over?
2002 F350 7.3L / 4R100 - 4WD CC DRW 8í Box, AIH Delete, Gauges- Pyro, Trans Temp, Boost, Fuel Pressure, TS-6 tuner, Zoodad Mod, Mishimoto 31 row Trans cooler, Mobil 1 ATF, Trans return line ATF filter, Hutch/Harpoon Mod, Air Lift Load Lifter 5000 rear air springs, Rancho 9000 shocks, Timbrens on the front.
Big Horn is offline
post #8 of 9 (permalink) Old 03-30-2019, 10:05 PM
Big Horn's Avatar
Originally Posted by TWO4ONEPRICE View Post
I worked on the front seats today. Very proud of my efforts. Replaced the worn leather upholstery with OEM leather replacements. After 4 - 5 hours, I completed this task. Now, I need a little sunshine and heat to shrink the leather to a better fit. After this, it’s off to the paint shop for exterior coating.
Nice!
Big Horn is offline
post #9 of 9 (permalink) Old 04-01-2019, 06:04 PM
They were pretty easy to change. I used a 4Ē cutting wheel to trim out the necessary area to make room for the new lights. Love them. Bright and better looking than the old dull stock.
  Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > 1999-2007 Upgrades and Aftermarket - General
Similar Threads
Cummins big cam help Dat1128 General Diesel 0 12-13-2018 06:52 AM
Transmission temps on big loads on big grades Fritz_Stubbe 6.7L Power Stroke Engine and Drivetrain 19 02-10-2017 12:58 PM
p1211 with big oil? [email protected]! dynotronics1 '99 & up Upgrades and Aftermarket - 7.3L Engine 78 06-18-2006 02:13 PM
you have to hear this! WW and Banks Big Head install quandry. charkly '99 & up Upgrades and Aftermarket - 7.3L Engine 6 05-12-2006 11:09 PM
ROLLING BIG POWER AND A TURBO QUESTION jetski86 '99 & up Upgrades and Aftermarket - 7.3L Engine 17 03-03-2005 05:20 PM
