While the truck bed is off..........what else? - Page 2 - Diesel Forum - TheDieselStop.com
 1Likes
post #16 of 24 (permalink) Old 11-21-2018, 09:11 AM
Thinking of doing h/h mod. Know i dont know. RT are u using big boys (truckers) pump?
early 99 f250 auto 190000 miles ts6 chip, riffraff frx, 6637 filter with riffraff cover edpv delete 4in exhaust tru- cool max,dedc tow mirrors with lights/heat,glow shift boost,egt,trans, fuel, gauges. hopkins agility brake control,pyle backup camera,firestone air bags,marinco plug, 265/75r 16 cooper discoverer a/t3 tires sinister diesel coolant filter,Bilstein 5100 stancor gpr.
stumpman is offline
post #17 of 24 (permalink) Old 11-21-2018, 01:05 PM
RT
RT's Avatar
No- standard pump at our local Kroger. The pump at Chevron and Shell both do it too.
RT is offline
post #18 of 24 (permalink) Old 11-21-2018, 02:59 PM
ArcticDriver's Avatar
I have not done the harpoon and this is the first I have heard of issues with it spitting out.
Have all of you cut one tube or both? I don’t know if it makes any difference, I am just curious.
As for foaming, in my travels, I have found some stations foam more than others but I have not logged which ones.
NOS Black CPS. ScanGauge-II. Bilstein 5100. Stancor GPR. Walker BTM. Noco Mod. Michelin Defender LTX 285/75/16.
SOLD:
ArcticDriver is offline
post #19 of 24 (permalink) Old 11-21-2018, 03:13 PM
Any idea if tank size has any thing to do with it? From what i have read it is recommended to cut off as much as possible. How long is the tube anyway?
stumpman is offline
post #20 of 24 (permalink) Old 11-21-2018, 05:07 PM
I followed the directions from all the information on this site and definitely do not use the trucker pump.
I have learned to listen with a very close ear and as soon as I hear it gurgling then that's a fair warning that she's ready to spew. Not sure what I did wrong but I sure would like to have it back. If I were to throw caution to the wind and let the nozzle cut off itself, it would projectile spew.
2001 Lariat, F250, 7.3, 6-speed, 3:73, Ford AIS, MBRP 4" turbo back, ATS ported housing, 205 t-stat, Infinity DX w/DP Tuner 80hp tow, coolant filter, Hutched & Harpooned, EGT & Boost gauge. Fuel Mavericks with 285/18, 86k miles(Jan-2017) Bought brand new April 2001.
aclasshog is offline
post #21 of 24 (permalink) Old 11-22-2018, 01:53 PM
klhansen's Avatar
My Photos: (180)
I cut the vent tube off as close as I could. There's probably 1/2 inch left.
Mine will puke out fuel if I wait for the cutoff, but just a touch over the fill tube. So I listen to the sound coming out the fill tube and slow down the nozzle before it cuts off. Our fuel up here foams really bad, so I have to nurse it in very slowly to get it full. I usually fill till I can see fuel in the neck.
), AIS,
regulated return,
klhansen is offline
post #22 of 24 (permalink) Old 11-22-2018, 04:36 PM Thread Starter
Big Horn's Avatar
So with that said I fail to see the difference, 6 to one, 1/2 dozen the other, if I have to nurse the fuel pump handle to get tank full or nurse the gas pump to keep fuel from puking out all over.
One of the stations I stop at has the big truck fuel handle and fills up must quicker without tripping out from foam. I am glad this information came to light rather than trusting the harpoon mod ad being a great improvement over stock which I now am in serious doubt.
2002 F350 7.3L / 4R100 - 4WD CC DRW 8 Box, AIH Delete, Gauges- Pyro, Trans Temp, Boost, Fuel Pressure, TS-6 tuner, Zoodad Mod, Mishimoto 31 row Trans cooler, Mobil 1 ATF, Trans return line ATF filter, Hutch/Harpoon Mod, Air Lift Load Lifter 5000 rear air springs, Rancho 9000 shocks, Timbrens on the front.
Big Horn is offline
post #23 of 24 (permalink) Old 11-22-2018, 08:30 PM
Originally Posted by RT View Post
I would spend some time with a wire brush and chassis paint - there are a lot of areas you'll have access to now that you won't when the bed is back on. You could also clean up and undercoat the entire underside of the bed.
The Strictly Diesel kit uses a Baldwin BF1212 which is a fuel filter/water separator. It will only separate free water and has to be drained periodically. Still, a great improvement over stock.
Get the Strictly Diesel kit and run a Donaldson P553203 filter.
2002 F-250 CCLB 4x4 XLT, 7.3, ZF-6 with Midwest Short-throw shifter, ESOF, 3.73 R&P, HPx line, FRx, Racor prefilter before pump, Amsoil bypass filter, Coolant filter too
txgp17 is offline
post #24 of 24 (permalink) Old 11-23-2018, 10:37 PM
I did the harpoon mod years ago. When I fill up it doesn't spit fuel out and I can still put another 2 gallons in roughly till it's all the way to the top. I always fill to the top to get accurate fuel mileage reading. I have to pump the last 2 gallons in pretty slow because of the foam though. I think the mod is just slightly better than the stock setup, can't recall anymore.
I believe I cut both tubes as close to the edge as possible using pvc cutters. So whatever that leaves (approx 3/4", IDK) I could also be mistaken as that was years ago now, but this is what comes to mind.
03 F350 7.3L Auto CC LB Dually 410's (LS Rear)
PHP/Beans, 1023, SDK, GH tuned/250/100 FF inj's, Irate T4 w/369SXE, Swamps HVHF IDM, BTS Tranny, Strictly Diesel complete fuel system with RR & FB delete.
Autometer Nexus Guages, 4"MBRP, DieselSite Coolant filtration system/billet housing/HP X-Over line. Donaldson Blue(6637)/AFE BHAF, RR Boots/ Billet Plenums, ('06) 26 row Tranny & PS Cooler, LarryB's Genuine Denso Starter
INFRNL is offline
  Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > 1999-2007 Upgrades and Aftermarket - General
