Diode Dynamics: SL1 LED Headlights for Chevrolet Silverado! USA Made! See Video! - Diesel Forum - TheDieselStop.com
 1Likes
  • 1 Post By Diode Dynamics
post #1 of 11 (permalink) Old 05-24-2019, 03:59 PM Thread Starter
Supporting Vendors
Diode Dynamics's Avatar
SL1 LED Headlight for Chevrolet Silverado
Diode Dynamics is pleased to offer the USA-made SL1 LED headlight for Silverado applications.
SL1 LED Headlight. If you're looking to improve your visibility at night, you've probably seen many options available for LED upgrades. There's plenty of LED bulbs on the market, but they all have their shortcomings. They're too big to install, have no hotspot in the beam pattern, or they simply stop working after just a few months. With its compact size, optically correct output, thermally-modeled cooling, and boost-mode electrical circuit, the SL1 LED finally provides a true upgrade in performance.
Street Legal Output. Don't be fooled by high lumen numbers or "projector specific" bulbs. Your Silverado’s headlights are designed to focus light. If the light source is out of focus, it doesn't matter how bright it is - you won't have a focused hotspot of light to shine down the road - just more glare. Some generic options have such a poor optical design, they might leave you wondering “how are LED headlights legal?!”
To correct this, Diode Dynamics' SL1 LED Headlight Bulb was engineered with advanced optical design software, to perfectly match the halogen filament location. This allows the SL1 to focus light just like the original halogen headlights, preserving the focus and hotspot, with no added glare. It produces a functional beam pattern with zero glare, which we call Street Legal.
Tested to Perform. We test the SL1 in factory car headlights and measure the entire beam pattern using specialized equipment. The entire beam pattern is mapped, and we compare the total output to the original equipment, confirming that the SL1 headlight bulb shines more light in the hotspot, without adding extra glare on the road. The test results speak for themselves: in most lamps, there is 30-70% more light output in the critical hotspot, with zero glare. Thanks to optical engineering, testing, and validation in the application, the SL1 is the #1 LED headlight bulb for reflector and projector headlights.
Staying Cool. You may have seen bulbs that use large straps for cooling, or fans that just make noise. These bulbs run hot, resulting in degradation of output after a few months. When it comes to cooling, proper engineering is required to efficiently remove heat from the bulb. In the SL1, a copper core board, thermal phase-change material, and thermally-modeled zinc casting get heat to the base, where base fins release it, designed for aerodynamic performance in conjunction with the flow rate and pressure of the Sunon bearingless micro fan. The result is a highly-effective and reliable cooling system, keeping the bulb running at maximum potential.
Fitment. With its patent-pending design, the SL1 LED fits where other bulbs won't, without cutting or modification. There's no hanging metal straps, just a compact bulb that plugs right in, with a nylon-reinforced shroud. Only slightly larger than a standard halogen bulb, it fits behind dust caps and in tight spaces. The base sizes are keyed for exact applications, not one-size-fits-all, and the compact driver easily tucks away.
Reliability. Every part of the Diode Dynamics' SL1 LED Headlight Bulb is engineered with more expensive OEM-grade features to assure quality, such as the Sunon MagLev fan and PCB wire connectors" In short, these are designed, tested, and built to a much higher standard than your average imported led headlight conversion kit. The Diode Dynamics' SL1 LED Headlight Bulb will keep performing in your Ram truck for years, and is backed by a three-year warranty.
Specifications
Measured Lumens: 1630 (per bulb)
Color Temp (CCT): 5700K Power (watts): 20.2
Operating Voltage: 5-16V
Current (amps @ 13.2V): 1.58 Polarity:
Polarity Specific LED Emitter: Luxeon Z ES
Connector(s): OEM-Size Plug and Play
Driver Features: External, Waterproof, Constant Current
Materials: Copper PCB, PP-TD30 Base, Zinc Heatsink
Cooling: Active, Mag-Lev Microfan
Compliance Ratings: FMVSS108 Beam Pattern, SAE J575 Durability Test
Click To Order Your Chevrolet Silverado LED Headlight Replacements:
Diode Dynamics SL1 Low Beam LED Headlight for 1999-2006 Chevrolet Silverado
Diode Dynamics SL1 High Beam LED Conversion Kit for 1999-2015 Chevrolet Silverado
Diode Dynamics SL1 Low Beam LED Headlight for 2007-2015 Chevrolet Silverado
Diode Dynamics SL1 Low Beam LED Headlight for 2016-2017 Chevrolet Silverado 2500/3500
*Diode Dynamics Anti-Flicker Modules are required for these applications*
If you have any questions, please don't hesitate to post, PM, email [email protected]
PM us for the free-shipping code* (U.S. forum members only)
Thanks for looking!
Jake H.
Diode Dynamics
Diode Dynamics is offline
post #2 of 11 (permalink) Old 05-29-2019, 10:29 AM Thread Starter
Supporting Vendors
Think having LED headlight bulbs shine light 360-degrees is a good idea? Think again! Check out this video to see why!
post #3 of 11 (permalink) Old 06-03-2019, 04:29 PM Thread Starter
Supporting Vendors
Don't forget to shoot us a PM for FREE USPS shipping on ANY U.S order!
Jake H.
Diode Dynamics
post #4 of 11 (permalink) Old 06-04-2019, 11:23 AM Thread Starter
Supporting Vendors
Are your headlight bulbs getting too got? Watch this video to find out!
post #5 of 11 (permalink) Old 06-04-2019, 12:58 PM Thread Starter
Supporting Vendors
How hot an LED headlight bulb gets has a BIG impact on how bright it will be over time and how long it will last. Check out this video to see if your headlights are getting too hot!
post #6 of 11 (permalink) Old 06-05-2019, 01:08 AM
Will you be making these in an H13/9008 for Ford trucks?
2labs. is offline
post #7 of 11 (permalink) Old 06-06-2019, 04:13 PM Thread Starter
Supporting Vendors
I believe so!
We currently have a dual-filament version of the SL1 in the works, which will unlock a variety of sizes we don't yet offer. As soon as I hear anything from my engineering team, I'll be sure to share!
Jake H.
Diode Dynamics
2labs. likes this.
post #8 of 11 (permalink) Old 06-21-2019, 02:40 PM Thread Starter
Supporting Vendors
In our latest video, we answer one of the most popular questions about headlight upgrades: Which is better, HID or LED? Check it out!
Jake H.
Diode Dynamics
post #9 of 11 (permalink) Old 07-09-2019, 12:59 PM Thread Starter
Supporting Vendors
Measuring Headlight Output | Diode Dynamics
How are headlight output patterns measured at the factory level? How do you test to see if a headlight is meeting SAE and DOT beam pattern requirements? Here at Diode Dynamics, we've invested in a goniometer to accurately measure and map the entire beam pattern and ensure our products are adding light output without adding extra glare.
Check out the video to see how it works!
Jake H.
Diode Dynamics
post #10 of 11 (permalink) Old 07-25-2019, 10:23 AM Thread Starter
Supporting Vendors
It's no diesel, but the SL1 LED Headlight Bulbs are the same! Check out the lux measurements on this 2015 Silverado 1500!
Jake H.
Diode Dynamics
post #11 of 11 (permalink) Old 08-07-2019, 04:33 PM Thread Starter
Supporting Vendors
Our SL1 LED Headlight Bulbs were built to last. And we've done the testing to prove it. Check out a behind-the-scenes look into our lab where we conduct thermal, vibration, and electrical testing to ensure years of reliable performance without flickering or failure!
Jake H.
Diode Dynamics
  Diesel Forum - TheDieselStop.com > Vendors > Diode Dynamics
