'05 F250...no 12v power from 7-way trailer plug? - Diesel Forum - TheDieselStop.com
 1Likes
  • 1 Post By bugman
post #1 of 11 (permalink) Old 08-03-2018, 09:32 PM Thread Starter
iqraceworks's Avatar
Question '05 F250...no 12v power from 7-way trailer plug?
I just hooked up a new brake system on my camper, and when I was testing things out...I noticed that I'm not getting any 12v power from the 7-way plug on the truck. The blinkers work, running lights work, no errors on the TBS. But I'm not getting any 12v power from the plug in order to charge my trailer battery.
I did some research on the form, and from what I could find....every year truck has a different relay and/or fuse for the 12v trailer plug circuit.
Can someone point me in the right direction for my 05' F250? It doesn't have some goody feature like it does for the trailer brakes where it doesn't turn them on until you are going over 5mph does it? Any info would be a huge help!
Thanks!!
2005 F250 6.0 PSD, ARP Studs, Felpro HG's, EGR Delete, IPR Coolant Filter, Bilstein 5100s, Blue Spring Mod, IDP Custom Tunes
iqraceworks is offline
post #2 of 11 (permalink) Old 08-04-2018, 12:35 AM
SnowRunner's Avatar
I know on my '05, the ignition needs to be in the on position to get power. My fuse is under the hood also.
'05 F250 CrewCab Diesel
'04 Jeep Wrangler Unlimited, 4" lift, 35's
SnowRunner is offline
post #3 of 11 (permalink) Old 08-04-2018, 09:06 PM Thread Starter
Thanks for all of the help guys! I found the problem......there was a 20a fuse under the dash that was blown. I replaced it, and everything is good now. But for some reason....now all of a sudden, I'm getting random "trailer disconnected" errors from TBS. I hate this OEM TBC!!!!!
post #4 of 11 (permalink) Old 08-04-2018, 09:55 PM
bobofthenorth's Avatar
You've got a boogie connection somewhere, probably on the ground side. I don't like that "feature" of the factory controller either but its likely better than just putting power to a connection that doesn't allow the brakes to come on fully. If you keep your connectors and wiring in good condition you won't have the message to look at.
2006 F250 6.0 4x4
bobofthenorth is offline
post #5 of 11 (permalink) Old 08-04-2018, 10:03 PM Thread Starter
I went through and checked everything .....ohmed all the wires out with a multimeter, everything is good. Even when I get the "trailer disconnected" error.....the blinkers and brakes still work fine. If there was no ground.....nothing would work.
I don't know if the factory TBC is looking for a certain resistance from the brakes or what...but it's way too touchy. I have no idea why they made it so touchy.
post #6 of 11 (permalink) Old 08-05-2018, 08:11 AM
Then the problem is likely right in the plug itself - the pins aren't making a good connection. They don't last forever - sometimes its easier to just change them out. Its not that there's no ground or no connection - you've got a high resistance connection somewhere and the controller is detecting that.
2006 F250 6.0 4x4
post #7 of 11 (permalink) Old 08-05-2018, 10:43 AM
bugman's Avatar
My Photos: (12)
The lights may work off of the ground through the hitch, they are not connected directly to the ground wire on the plug. Where the disconnect message might be the bad ground through the plug where it won't see the ground through the hitch.
bugman is offline
post #8 of 11 (permalink) Old 08-06-2018, 06:57 AM Thread Starter
Thanks for the help guys. I went through the trailer and re-did all of the ground connections on the brakes. That fixed the problem...no more random "trailer disconnected" faults. Must have been just a funky ground....crazy how sensitive the OEM TBC is.
Thanks again!
post #9 of 11 (permalink) Old 08-06-2018, 07:51 AM
I don't like that its so sensitive either but....
Trailer brakes take a lot of power and they're kind of important. So even while I'm getting annoyed at the "trailer disconnected" message I recognize that it is telling me there's a problem. As I posted earlier, a dumb controller that just sends power to the trailer would be less annoying but if that power isn't activating the brakes then it kind of defeats the purpose of a brake controller.
2006 F250 6.0 4x4
post #10 of 11 (permalink) Old 08-06-2018, 11:06 AM
bugman's Avatar
My Photos: (12)
Just one thing if someone finds this thread in the future, 99% of any and all trailer electrical problems can be traced back to a bad ground.
bobofthenorth likes this.
bugman is offline
post #11 of 11 (permalink) Old 08-06-2018, 12:38 PM Thread Starter
Yep....and it doesn't have to be a "bad" ground....it can just be not as good as the TBC wants it to be. The thing is really way too sensitive.
