2000 F250 7.3L - Water In Fuel Tank - Diesel Forum - TheDieselStop.com
 2Likes
post #1 of 21 (permalink) Old 02-23-2017, 08:33 AM Thread Starter
Catch-All's Avatar
Unhappy 2000 F250 7.3L - Water In Fuel Tank
Patient: Ford F-250 7.3L Lariat Crewcab
Diagnosis: water/ condensation in the fuel tank
Treatment: fuel additive - "Diesel Kleen" or something like that - that emulsifies the water so it can be burned off. Supposedly it also de-gels and de-sludges the tank.
Prognosis: still fuxated, need advice.
Twice I've had problems with my truck where I let the tank get down to where the Fuel Low idiot-light came on. Each time, the engine began knocking and running poorly. And each time, I de-watered the Fuel/Water Separator, filled the tank up and the problem went away. The symptom is too much water getting into the Fuel/Water Sep (by the way, the fuel contamination idiot-light doesn't come on). But the cause of the disease is there's got to be too much water at the bottom of the tank for the Diesel-Kleen to be able to absorb and burn off.
I bought one of those El Cheapo siphons from an auto parts store but I can't seem to get the curves and kinks out of the clear plastic tubing. I want to get it pretty much straight so that when I remove the fuel-cap and feed the tube into the tank, I'll be sure it's going to the very bottom of the tank where the water is. Can anyone suggest a better way to de-water my fuel tank without it costing me an arm & a leg?
Thanks,
Mark/ Catch-All
2000 F-250 Lariat crew-cab. Bought used in early 2007 at 140k miles, now it's a little over 200k. Basic chip job via SuperTuner at Towing setting. Air Raid air filter. DieselSite thermostat and new housing. Dents repaired and Repainted white by MAACO. Aftermarket LED lights for pickup bed brake light and tail lights. Aftermarket headlights - CCFL halo lights. New fuel/water sep drain valve. New starter motor. New Glow Plug Relay. New alternator & serp belt. New tires all around (NEVER buy Uniroyal or Michelin - they're all junk and they don't honor their warranty). Repaired transmission housing & brake lines that WalMart dinged up during an oil & filter change. Truxedo roll-up tonneau cover. New upper & lower ball joints at 206k miles. New steering box. New tailgate. NEXT PROJECTS: DIY truckbed rust removal & heavy-duty coating, de-water fuel tank.
Catch-All is offline
post #2 of 21 (permalink) Old 02-23-2017, 11:03 AM
yan7gin's Avatar
Take it out and clean it. it is not to much work and you'll be sure that everything is clean.
what fuel filter do you have in? I would suggest to stick with the OEM one.
F350 2002 7.3
auto, 37/13.5/20 open country, Bushwaker cut-out flare, Bilstein 5100, Maxtow gauges (EGT, Trans temp, Boost), 4 inch diamond eye turbo back axel drop with BTM muffler, S&B intake, RR AIH plug, billet FPR with gold spring, CNCfab Sgt 1 HPOP, CNCfab HPOP line with cross over, CNCfab 4 line fuel kit, ARP heads stud, RDP plenum reinforcing insert, complete CAC intercooler boot kit, full engine seal and gasket kit, 360* turbo rebuilt, WWII, EGPV delete, dark blue CPS, Hydra chip with SDK tunes, Polished compressor manifold, HD coolant, 203* thermostat, Transgo HD kit, Energy suspension bushing kit, front and rear diff fully rebuilt with 4:88 gear ratio, Z36 powerstop heavy hauling brake kit, headlight relay mod, Fumoto drain valve AND STICKER
F350 2008 6.4 (sold)
TT 26' Springdale 2014
7x17 enclose trailer (shop) 2012
yan7gin is offline
post #3 of 21 (permalink) Old 02-23-2017, 12:53 PM
ArcticDriver's Avatar
Why have you diagnosed it as water in fuel?
When you drain the fuel bowl into a clear glass jar do you see water and diesel?
If there is water in your tank then I think the Power Service 9-1-1 is better at removing water:
https://powerservice.com/wp-content/...B-8000_HR1.pdf
If you decide to drop the tank as mentioned above then it would be worth cleaning the two small filters (attached photo) and inspecting the pick-up "foot". These can crack off.
Name:	Screen Shot 2017-02-23 at 11.50.55 AM.jpg
NOS Black CPS. ScanGauge-II. Bilstein 5100. Stancor GPR. Walker BTM. Noco Mod. Michelin Defender LTX 285/75/16.
SOLD:
ArcticDriver is offline
post #4 of 21 (permalink) Old 02-23-2017, 04:09 PM Thread Starter
Catch-All's Avatar
Yan7Gin and Arctic Driver - Thanks for replying!
I'm using the Fram fuel/water filter. And yes, every time I've had the Low Fuel light rough-engine issues, I drained water out of the fuel/water separator filter bowl. I used a turkey baster to get it damn near bone dry and sure enough I could see the water at the bottom of the clear glass I siphoned it into.
Mark/ Catch-All
ArcticDriver likes this.
post #5 of 21 (permalink) Old 02-24-2017, 08:20 AM
69mach1377's Avatar
Maybe its your fuel source?
2000 F250 XLT 4x4 SC 7.3 w/Auto Tranny w/ TC L/U Sw & shift kit, 3 autometer gages, Super Zoodad, PHP Hydra chip, 4" DP/Exhaust w/dual 3.5" outlets, 275/70/18 Kumho AT51s on 8.5" rims, 08 AlumDiffCvr, Bilsteins, 31 row trans cooler, WW, BPV delete, AIH delete, hutch, harpoon and billet FPR (70psi), trans cooler bypass delete by accident, rear air bags, Jimmijammers.
Jayco 26BHS elite, no RV parks...just the woods if possible.
See my album for a recent pic.
69mach1377 is offline
post #6 of 21 (permalink) Old 02-24-2017, 11:10 AM
Rather than the 9-1-1 product I recommended above, here is the Power Service product that is specifically for your situation:
Clear-Diesel Fuel & Tank Cleaner | Power Service
You could use this until you have the time to drop the tank.
And here are the vendors in Louisiana:
Where to Buy | Power Service
I have found it at Wal-Mart in Florida.
SOLD:
post #7 of 21 (permalink) Old 02-24-2017, 11:19 AM
Mark/ Catch-All
In my research, there appears to be a general concensus to avoid FRAM filter products.
You can find RACOR and Motorcraft fuel filters online that are competitive with FRAM pricing.
SOLD:
post #8 of 21 (permalink) Old 02-24-2017, 06:45 PM
yan7gin's Avatar
I would suggest to stick with oem
F350 2002 7.3
yan7gin is offline
post #9 of 21 (permalink) Old 03-23-2017, 07:55 PM Thread Starter
Catch-All's Avatar
still fuxated
Okay, I finally had a chance to buy some of that stiff, opaque plastic tubing to attach to the siphon. The only problem is that when I took off the fuel cap and stuffed the hose in, it would only go about 2 or 3 feet and then stop.
*it felt kinda mushy when it bottomed out and wouldnt go in further
*I didn't hear any hard plastic-to-metal "tink" sounds when I stuffed the hose in
*the end of the hose wasn't wet with diesel fuel despite the tank being 1/2 - 5/8's full
Why can't the hose reach the bottom of the tank? Is there some kind of anti-siphon feature in F-250 fuel tanks to prevent theft? I mean....***, right?
As for fuel additives, my local Advance Auto carries both 9-1-1 and Diesel Kleen - I bought a quart of each. I'll alternate additives each time I fill up.
Meanwhile, I bought a new fuel/water sep drain valve from NAPA and installed that. At least now I can drain off the water periodically as it accumulates in the bottom of the filter.
post #10 of 21 (permalink) Old 03-24-2017, 03:22 PM
yan7gin's Avatar
As i remember its a stait shot to the bottom of the tank...
That what the drain on the fuel bowl is for, drain your fuel/water periodically
Sent from AutoGuide.com Free App
F350 2002 7.3
yan7gin is offline
post #11 of 21 (permalink) Old 03-24-2017, 05:21 PM
I linked this in Post #6.
The 9-1-1 will remove some water but the Power Service Silver bottle won't handle much water as you describe.
This is the product to buy and I sometimes see it at Wal-Mart:
SOLD:
post #12 of 21 (permalink) Old 03-27-2017, 07:28 AM
The second concern is how you are accumulating so much water in your fuel tank.
Does the truck sit for long periods? Are you using farm fuel stored in above ground tanks?
And a third concern is using a Biocide because 9-1-1 and PS Silver jugs are not Biocides.
SOLD:
post #13 of 21 (permalink) Old 03-29-2017, 09:52 AM Thread Starter
Catch-All's Avatar
It doesnt sit long but I drive such short distances that I only have to fuel up twice a month. Not using farm fuel. I buy from name-brand fuel stations.
post #14 of 21 (permalink) Old 03-29-2017, 10:45 AM
Texkenusmc's Avatar
I droped my tank when I had your issue to make sure I got it all. What part of La are you in? I am by Lake Charles
Texkenusmc is offline
post #15 of 21 (permalink) Old 03-29-2017, 12:05 PM Thread Starter
Catch-All's Avatar
I'm over here by the north shore of Lake Pontchartrain, in Mandeville. Y'all got some good fishin' over in your redneck of the woods, especially big doormat flounder.
