2002 7.3 powerstroke weird noise on startup - Diesel Forum - TheDieselStop.com
post #1 of 2 (permalink) Old 08-30-2019, 01:50 PM Thread Starter
I have a 2002 7.3 powerstroke and Sometimes right after I start the truck it makes almost like an air escaping noise from underneath it, somewhere under the motor. I just had a new oíriley ultima starter put in about a month ago and a mechanic said that he thinks itís the new starter but Iím not sure. Itís also not an exhaust leak everything is solid. Just wondering if anybody has experienced this or has any ideas of what it is because Iím clueless??? Hereís a link to a video I took of it:
https://youtu.be/RHwBRLZUCrA
7-point-3 is offline
post #2 of 2 (permalink) Old 08-30-2019, 02:56 PM
klhansen's Avatar
My Photos: (180)
Welcome to TheDieselStop
In my opinion, that's just the starter spinning down. I wouldn't worry about it too much unless it gets much worse.
), AIS,
regulated return,
klhansen is offline
