7.3L Won't start Super fast clicking sound - Diesel Forum - TheDieselStop.com
post #1 of 10 (permalink) Old 08-28-2018, 08:27 PM Thread Starter
Started this morning Went to went to start it this afternoon, does nothing if you open the door and pull the key out of the ignition super fast clicking sound Any idea Ok batteries are Bosch 900 amp 1400 cca 2 years old at most I will swap my old batteries out with Some 1 year old batteries I also have a charger that will run a repair cycle before charging and if I can
Get the truck running I can test the alternator with the charger So I try this first before I swap
D Kinney is offline
post #2 of 10 (permalink) Old 08-28-2018, 08:43 PM
jleedog's Avatar
Batteries?
2002 F250 Super Duty Crew Cab 7.3L Lariat 2WD 131,000mi; 4in turbo back custom exhaust, Garrett GTP38R turbo, Riffraff intercooler boots, Dorman Up-Pipes, Ford Severe Duty AIS, 31 row 6.0 transmission cooler, Scangauge II, ISSPRO EV2 Boost-EGT-Trans temp-Fuel pressure Gauges, DP T-5 Tuner (stock ,60HP tow, Decel, 60HP highway econo, 80HP city econo), Dieselsite coolant filtration, Max Air A/C mod, foglight mod, AIH delete, LED interior, back up camera, hid foglights.
I have AE if you are in San Diego area and need help. Send PM
jleedog is offline
post #3 of 10 (permalink) Old 08-28-2018, 10:55 PM
klhansen's Avatar
My Photos: (180)
Or battery cable connections.
2 year old batteries aren't "new" or necessarily good.
), AIS,
regulated return,
klhansen is offline
post #4 of 10 (permalink) Old 08-29-2018, 12:38 AM
Batteries only last about two years in these trucks, because it takes so much power to start them.
DonWarkentin is offline
post #5 of 10 (permalink) Old 08-30-2018, 11:56 AM
The starting power required has little to do with battery live. Heat is the big killer of batteries. Mine usually last 6 years or so, we seldom see temps over 70 degrees. It could be a diode in the alternator, it will not properly charge and will not trigger the ALT light. I have had this happen twice. I would check that once you get it running.
DENNY
DENNY is offline
post #6 of 10 (permalink) Old 08-30-2018, 03:58 PM
ArcticDriver's Avatar
I think.both of you have valid points.
Heat is a killer but I think a frequent heavy draw on a lead acid starter battery also shortens battery life. Such as that from glow plugs and starter demands of a cold engine.
Proper battery and charging system maintenance by making sure all cable connections are bright & tight, cleaning posts, using felt washers, occasionally topping off with a goid charger, etc can all help to protect the batteries.
I have also read the common practice of trickle chargers is also a battery killer.
And, again, you guys are both right, 2-5 years is the typical life of a lead acid battery.
SOLD:
ArcticDriver is offline
post #7 of 10 (permalink) Old 08-30-2018, 07:50 PM
That's why I switched to Odyssey extreme 65-PC1750T batteries, because I was only getting two years per set of batteries. Hopefully, I will get at least six years with these.
post #8 of 10 (permalink) Old 09-13-2018, 12:45 PM
losfinch's Avatar
Just wondering why trickle chargers are considered battery killers?
Early 99 F350 4X4 CC 7.3 Auto. A.R.E. Topper, bed carpet/bench inserts, Rhino grill guard, AIS w/sleeve, Fuel filler mod, GOS headlight harness, 02-04 Headlights, Rancho HD stabilizer, 06 Telescoping/heated mirrors with C-Btr Mirrors, Hella FF1000, Htr Bypass valve, front receiver hitch, Quadzilla XZT gauges, ITP Pre-pump/In-tank mods, Pioneer P5000UB w/XM radio, 4 Infinity Kappa 682.7cf, Fumoto valve, FIAMM Highway blaster horns, SS HPX, IDM mod, DP F5 (Stock,Drive-thru,60T,80E,120,80E-Mountain,1200), Walker BTM, RR, Dieselsite BRV, BTS Tranny (2nd one :-), 31 row tranny cooler, Bilstein shocks, Amsoil bypass oil filter, Stancor HD Glow Plug Relay, billet thermostat housing, front & rear parking cameras, Aux reverse lights, Heated Seats.
Security: CrimeGuard Alarm with remote notification, DIY jimmi-jammers, door cylinder locks and linkage removed, padlocked rear bench seat hinge, PCM, DIY "pitstop" switch.
losfinch is offline
post #9 of 10 (permalink) Old 09-13-2018, 02:07 PM
RT
RT's Avatar
I think that has to do with the evolution of trickle chargers. The old ones were simply low amperage chargers - nothing to stop them when the battery was fully charged so they would slowly cook a battery to death. The newer ones have sophisticated algorithms that control the charging - constantly monitoring the battery voltage and only applying current as necessary. I have the NOCO Genius chargers on both of my antiques. They have a very sophisticated charging system and I've got 10+ years on the batteries in those vehicles with no issues whatsoever.
RT is offline
post #10 of 10 (permalink) Old 09-13-2018, 04:12 PM
https://www.batteriesplus.com/blog/power/charge-on
I have a NOCO but I still find it more reassuring to unhook my batteries when I am gone for any length of time.
SOLD:
