'99 7.3L early model or late model - Diesel Forum - TheDieselStop.com
 1Likes
post #1 of 17 (permalink) Old 11-25-2018, 02:20 PM Thread Starter
how can I tell if my truck is a early model 99 or a late model 99
DanThrt is offline
post #2 of 17 (permalink) Old 11-25-2018, 02:23 PM
Mark Kovalsky's Avatar
My Photos: (6)
Get the month and year of manufacture off the data tag in the driver's door opening.
Mark
Former
Automatic Transmission Engineer 1988-2007
Mark Kovalsky is offline
post #3 of 17 (permalink) Old 11-25-2018, 02:39 PM
klhansen's Avatar
My Photos: (180)
What Mark said.
If it's got a 12/98 build date on the sticker it could go either way. The "official" transition date was 12/7/98.
The early 99's would have a Powerstroke badge on the front fenders, versus a door badge on the 99.5's, although that's not a definite clue to cutoff due to some carryover parts.
The early '99 had a shorter turbo pedestal and smaller intake plenum connections, also no intake air heater on the turbo outlet spider (one relay instead of two - Glow Plug, and IAH relays on the later trucks, just behind the fuel filter in the valley). There are also a few differences that aren't obvious, like different injectors.
), AIS,
regulated return,
klhansen is offline
post #4 of 17 (permalink) Old 11-26-2018, 01:31 AM Thread Starter
I bought the truck from my brother-in-law and I think he pressure washed the sticker off I thought there was another way but I wasn't sure of exactly how or where
DanThrt is offline
post #5 of 17 (permalink) Old 11-26-2018, 05:10 AM
Look at sticker on engine valve cover, it should have engine build date. also 4 bolts holding turbo compressor on
early 99 f250 auto 190000 miles ts6 chip, riffraff frx, 6637 filter with riffraff cover edpv delete 4in exhaust tru- cool max,dedc tow mirrors with lights/heat,glow shift boost,egt,trans, fuel, gauges. hopkins agility brake control,pyle backup camera,firestone air bags,marinco plug, 265/75r 16 cooper discoverer a/t3 tires sinister diesel coolant filter,Bilstein 5100 stancor gpr.
stumpman is offline
post #6 of 17 (permalink) Old 11-26-2018, 08:28 AM
My Photos: (6)
There are several other ways listed in this thread.
Mark
Former
post #7 of 17 (permalink) Old 11-27-2018, 07:20 AM Thread Starter
That is where it was on the driver side valve cover it said 24 Mar 98 and on the other cover. It said 99 international great info thanks alot now I know what I got .it. seems to run great but has a slight miss after it warms up.
DanThrt is offline
post #8 of 17 (permalink) Old 11-27-2018, 08:21 AM
When was last oil change?
stumpman is offline
post #9 of 17 (permalink) Old 12-14-2018, 03:42 PM
sd73man44's Avatar
Location: midwest, Tecumseh, MI, Standish Pond and River Raisin
My early 99 has a different air box element, referenced to Vin number. Also has powerstroke emblem on front fender.
'99 7.3L SD F250 4X4 manual 6 speed - original.
"We got a lot of stupid politician's in this country" C.S.
sd73man44 is offline
post #10 of 17 (permalink) Old 12-14-2018, 04:07 PM
sd73man44's Avatar
Also the door tag is 02/98 making it one of the PP builds. It was my test vehicle at Ford when we did evaluations on dual mass flywheel. I bought the truck on the ‘B’ Plan in mid ‘01. You wouldn’t believe what I paid for it, I was the only person that drove the truck. $15.3. They call those the good Old days. Ha.
Texkenusmc likes this.
post #11 of 17 (permalink) Old 12-14-2018, 06:02 PM
The stock air filter on the early 99 is something to keep an eye on. Original ford part off vin number is the way to get the correct size. I had to return aftermarket filter to NAPA because it was just a bit too long. I was tempted to just make it fit but did not.
DENNY
DENNY is online now
post #12 of 17 (permalink) Old 12-14-2018, 06:45 PM
sd73man44's Avatar
Probably a few ‘98 parts used on (PP) pre-production builds when suppliers couldn’t get production tools up and running to meet tight schedules. I‘ve had some problems with replacement rear brake cables fitting and working properly. Could be the new parts were intended for a F350 or F550, etc. The springs inside the rear hat rotors seem too darn fat and NAPA insists they are the the correct parts??? The emergency brakes are pretty important especially when you have the manual transmission and pull trailers. I replaced all the cables but the main ‘long’ interconnecting was 3” short so I had to reuse the original.
post #13 of 17 (permalink) Old 06-13-2019, 10:29 AM
Make sure your e brake warning light works. Paid $350 for new shoes and the wife promptly took them out the next day because no light. My fault, I should have fixed it right away.
early 99, cone intake, stock 3.5" exhaust, muffler deleted. Edge Evolution CS
Barchetta is offline
post #14 of 17 (permalink) Old 06-14-2019, 07:34 AM
69mach1377's Avatar
So you probably can't interchange the turbos between early and late?
2000 F250 XLT 4x4 SC 7.3 w/rebuilt 4R100, 3 autometer gages, Super Zoodad, PHP Hydra chip, 4" DP/Exhaust w/dual 3.5" outlets, 275/70/18 Kumho AT51s on 8.5" rims, 08 AlumDiffCvr, Bilsteins, 31 row trans cooler, WW, BPV delete, AIH delete, hutch, harpoon and billet FPR (70psi), rear air bags, Jimmijammers.
Jayco 26BHS elite, no RV parks...just the woods, lakes and streams if possible.
See my album for a recent pic.
69mach1377 is offline
post #15 of 17 (permalink) Old 06-14-2019, 01:42 PM
klhansen's Avatar
My Photos: (180)
In order to put a later turbo on an early '99 you'd need the pedestal, collector, up-pipes, outlet spider, plenums, boots, and probably need to modify or replace the exhaust downpipe. I'm sure I missed something.
), AIS,
regulated return,
klhansen is offline
