99 - all air goes to defrost vents - Diesel Forum - TheDieselStop.com
post #1 of 7 (permalink) Old 09-16-2019, 08:52 PM Thread Starter
Regardless of selected position, all air from the heater/air conditioning comes out the defrost vents along the front window. What is the most likely problem? (1999 F250 crewcab). Thanks
johnbeck is offline
post #2 of 7 (permalink) Old 09-16-2019, 08:56 PM
bugman's Avatar
My Photos: (12)
Vacuum leaks
Sent from my SM-J737V using Tapatalk
bugman is online now
post #3 of 7 (permalink) Old 09-17-2019, 09:32 AM
Check the vacuum distribution under the glove box.
2000 Excursion 7.3L Diesel 4x4, BTS Tranny, AFE intake,Stage1 Single Shot Injectors , GTP38R turbo, EBV delete, 6 position TS chip, Adrenaline HPOP
kcastle is offline
post #4 of 7 (permalink) Old 09-17-2019, 09:50 AM
Mine did that and it was the vacuum pump replaced and all is good do you hear the pump running when you turn the key on it's on the passenger side fender wall hope this helps
redrocker is offline
post #5 of 7 (permalink) Old 09-17-2019, 03:16 PM
bugman's Avatar
My Photos: (12)
Go down to the auto parts store and pick up a dozen or so vacuum lines caps.
Then once you find the vacuum distribution box you can remove hoses and cap off one or two at a time until you get air out of the vents or somewhere besides the defrost. Odds are if your truck is a 4x4 the leak is on the lines to the front hubs.
post #6 of 7 (permalink) Old 09-20-2019, 07:46 AM Thread Starter
Vacuum leak
Thanks, excellent suggestions. I'm crawling under the dash today!
johnbeck is offline
post #7 of 7 (permalink) Old 09-21-2019, 06:47 AM
ford_doctor's Avatar
Defrost is the default position when the supply vacuum is lost. Personally, I would start at the vacuum source especially if the truck is a diesel with an electric vacuum pump and electronic shift on the fly 4X4 if equipped. As suggested you can eliminate some components and lines by bypassing the 4X4 solenoid (can stick in the exhaust position) and vacuum reservoir with some test hoses and sections of lines. A vacuum pump with a gauge is your best friend here but not absolutely necessary.
2019 Ford Fusion ENERGI Titanium Plug-in Hybrid
Diesel Technician Society
Diesel Mentor Directory
ford_doctor is offline
