Air conditioner system pressures - Diesel Forum - TheDieselStop.com
post #1 of 3 (permalink) Old 08-07-2019, 03:31 PM Thread Starter
Hi all -
I am thinking I need to give my AC system a little top up. I have searched far and wide (and even looked in the factory service manuals), but I cant seem to find anything that explains what the high and low side pressures should be, and under what conditions (engine RPM, fan on high or one step below high, ambient temperature, etc.).
2002 F250 XLT 4WD SC SB with 6 Speed and Manual Shift Transfer Case. Pillar pod-o-gauges, Warn Premium Hubs, AIS, Fumoto, Edge 3 leveling kit on the front (with adjustable track bar), 4 blocks on the rear, Eaton Posi, Bilstein 5100s and 285 X 75 X 16 BFG MTs all around. Oil pan coated with POR-15. Fleetrite ELC and Dieselsite coolant filter (plus new water pump). New O-Rings on the injectors.
Shamish is offline
post #2 of 3 (permalink) Old 08-07-2019, 04:00 PM
JJEdwards's Avatar
Although not universal, the chart below is a what I use and it has produced great results on my 2000. The refrigerant quantity should be listed on a sticker under the hood.
2000 7.3 PSD 4x4 Auto Trans., CC, short box 207,500 miles.
PHP Hydra, Bilstein 5100's, Bilstein steering stabilizers, Auto Meter 3 gauge pod--EGT, Trans Temp & Boost, Deep Trans Pan, Rotella ELC and T6 oil, DieselSite 203*, Riffraff Billet wheel, 4" turbo back MBRP 5" straight pipe, Donaldson 6637 blue, 20" Fuel wheels wrapped with 37" MT's
Security: Ravelco (for the pro's), Viper (for the rookies), The Club 1100 Steering Wheel Lock (visual deterrent).
JJEdwards is offline
post #3 of 3 (permalink) Old 08-07-2019, 06:30 PM Thread Starter
Thank you for the response!
I saw this table on the interweb...along with a bunch of other information. One person on another forum had some nice charts that showed H and L side pressure vs temperature. One for less than 100 deg F ambient and one for above 100 deg F ambient. The problem is that the numbers for 100 Deg F did not match on the two charts!
I know the "right" way to do things is to measure the amount of refrigerant that goes into the system.
Knowing that you had some luck with this chart gives me some confidence and I will use it. Worst case, I will just have to go to the dealer and have them evacuate and refill the system...
...the fact is the AC is pretty good on my truck and the only reason I am going to tinker with it is that I need to juice the AC on my 2012 4Runner which is DEFINATELY in need of a charge. Strange that the Toyota needs attention before the Ford, but I have about 95,000 on the Toyota and about 80,000 on the Ford (which gets about 500 miles a year).
All in all, I don't mind spending a few $$$ on these two vehicles which have been really good to me. My worst case scenario is where I have a major mechanical failure on the truck or some duma$$ runs into me and totals it. I am not sure what I would do after that.
Happy motoring everyone
Shamish is offline
