Another 7.3 rough idle till warm post. IPR? CPS? Injectors? - Page 2 - Diesel Forum - TheDieselStop.com
post #16 of 32 (permalink) Old 08-12-2019, 11:05 PM Thread Starter
Okay so the voltage between to two larger posts should stay around 12.5~ with the key on and off? And I saw in one of the previous replies that a voltage drop of anything more than .5 means that my glow plugs aren't working.
Btw thank you for your input
Whiskey_helpz is offline
post #17 of 32 (permalink) Old 08-13-2019, 12:29 AM Thread Starter
Update. So I was wrong in my previous post. The big post opposite of the constant has 11.5V when the key is turned on and slowly climbs to 11.9 over a few seconds.
post #18 of 32 (permalink) Old 08-13-2019, 11:53 AM Thread Starter
post #19 of 32 (permalink) Old 08-13-2019, 04:22 PM
ArcticDriver's Avatar
Did you follow the link “No Start” in KLHanson’s signature?
That eliminates any guesswork.
It sounds like you may have some GPs that need replacing but the only way to test is using those instructions in “No Start”.
Just to get you thinking of parts, you will want to stick with Motorcraft brand GPs and it might be worth doing all 8 if you are getting in there since they are only $9/each.
If you need a new GPR, then check out the Stancor-White Roger. Its big and outlasts the others based on the feedback forum.
Can be found here:
https://www.dieselorings.com/16-009-...lug-relay.html
The “No Start” instructions will tell you what needs replacing.
NOS Black CPS. ScanGauge-II. Bilstein 5100. Stancor GPR. Walker BTM. Noco Mod. Michelin Defender LTX 285/75/16.
SOLD:
ArcticDriver is offline
post #20 of 32 (permalink) Old 08-13-2019, 10:28 PM Thread Starter
How do I find this no start link?
post #21 of 32 (permalink) Old 08-13-2019, 11:30 PM
Big Horn's Avatar
Make sure you are on “Full Version” and not Mobile, then look at klhansen’s profile. You will see it listed- click on it and it will take you to the sticky note he has set up.
2002 F350 7.3L / 4R100 - 4WD CC DRW 8 Box, AIH Delete, Gauges- Pyro, Trans Temp, Boost, Fuel Pressure, TS-6 tuner, Zoodad Mod, Mishimoto 31 row Trans cooler, Mobil 1 ATF, Trans return line ATF filter, Hutch/Harpoon Mod, Air Lift Load Lifter 5000 rear air springs, Rancho 9000 shocks, Timbrens on the front.
Big Horn is offline
post #22 of 32 (permalink) Old 08-14-2019, 01:33 AM
klhansen's Avatar
My Photos: (180)
Here's a direct link https://www.thedieselstop.com/forums...e-first-75094/
), AIS,
regulated return,
klhansen is offline
post #23 of 32 (permalink) Old 08-17-2019, 02:45 PM Thread Starter
Update. I changed all 8 glow plugs. Tried to start it this morning, no luck. Had both batteries load tested and the guy at autozone said the were both at 100%. So far I've replaced the GPR, CPS, glow plugs, and changed the oil using 15-40 Rotella with Hotshot stiction eliminater. Has a new ICP from the previous owner. I've also cleaned the battery connections. Truck has some blowby but won't blow the cap off. If it is plugged in for a couple hours it fires right up at 45 degrees. Still racking my brain. Any help is appreciated.
post #24 of 32 (permalink) Old 08-17-2019, 03:01 PM Thread Starter
This is a video of me trying to start the truck around 45 degrees out without being plugged in
post #25 of 32 (permalink) Old 08-17-2019, 03:07 PM Thread Starter
post #26 of 32 (permalink) Old 08-18-2019, 09:08 AM
Did you test the new GPR using the “No Start” instructions just to confirm its working?
So its still exactly like before? It starts quickly when the block heater is plugged in but does not start when not plugged in?
And you have inspected the ICP? Unless you replaced it yourself with a Motorcraft ICP then you can’t really be sure. New ICPs can fail. But the fact it runs good as soon as it turns over indicates the ICP has not failed completely.
You mentioned you had it scanned but did not mention the type of scanner. Most parts store code readers do not read Ford specific codes as was mentioned earlier.
You really need to download an App or buy a ScanGuage-2 and read some engine values or its just more throwing money after it and hoping to get lucky.
SOLD:
post #27 of 32 (permalink) Old 08-18-2019, 10:06 AM Thread Starter
I tested the GPR and verified that it is working. I tested all 8 glow plugs and I am getting around 1.6-1.5 ohms. I have an app but the bluetooth obd2 scanner that i have isn't compatible with that specific app. I am currently waiting on one from Amazon but as you know I'm in Fairbanks and it takes alittle time for things to ship up here.
post #28 of 32 (permalink) Old 08-26-2019, 10:12 PM Thread Starter
Update. So I got an Edge Insight cts2 and have been monitoring it for about 2 days now. What should I be looking for in terms of monitoring? My ipr duty cycle is about 6% at idle. Icp sits at about 480 psi at idle. I've done alittle reading on other threads and those values seem low. Thank you for any input
post #29 of 32 (permalink) Old 08-26-2019, 10:35 PM Thread Starter
At wot @~70mph I'm getting about 2400-2600 icp psi and ipr duty cycle slowly climbs to about 60-65%
post #30 of 32 (permalink) Old 08-26-2019, 11:59 PM
klhansen's Avatar
My Photos: (180)
IPR of 6% at idle is a bit low, but 480 psi ICP is good. That in itself would indicate a possibly partially obstructed edge filter.
But your ICP at max power of 2400-2600 psi is fine as well and IPR duty cycle of 60-65% is within limits for a stock tune.
Is it running OK?
), AIS,
regulated return,
klhansen is offline
