ATF transmission fluid as fuel additive??? - Page 2 - Diesel Forum - TheDieselStop.com
 1Likes
post #16 of 20 (permalink) Old 05-25-2018, 10:24 PM
RT
RT's Avatar
There is nothing wrong with running ATF as fuel in a 7.3. The problem is that it does zero to increase lubricity when added to diesel which is at least one point of an addictive. It would be like adding a quart of diesel to every tank of diesel when the quart cost $8.
Sent from my iPad using Tapatalk
RT is offline
post #17 of 20 (permalink) Old 05-26-2018, 08:38 AM
badbart's Avatar
I think they were more interested in the 30% fuel savings. I think diesel was costing nearly $4 a gallon back then.
2011 F350 4x4 XL Crew Cab Dually
2010 Keystone Fuzion 405 Toyhauler
badbart is offline
post #18 of 20 (permalink) Old 05-26-2018, 08:56 AM
RT
RT's Avatar
Exactly. If you get it for free, clean it (centrifuge or ultrafiltration) and run it. But donít pay full price and add it to your fuel expecting a benefit.
RT is offline
post #19 of 20 (permalink) Old 05-26-2018, 11:44 AM
79jasper's Avatar
Since some want to bring up legality....
It's also illegal since it's untaxed.
Sent from my SM-G892A using Tapatalk
79jasper is online now
post #20 of 20 (permalink) Old 05-26-2018, 12:51 PM
bugman's Avatar
My Photos: (12)
There is a certain amount that you can run before you have to pay taxes on it.
It was discussed way back when in the Alternative Fuels section.
Much the same as manufacturing your own bio.
79jasper likes this.
bugman is online now
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
